Author |
Message |
Lew Radbourn
Trader Queensland jzs147 92 / 95 jzz31 98' / jzz30 ute92' / uzz30 93'/ 2 X uzz31 92' s
Posts: 1652 Reg: 07-2005
| Marlew work van getting power up grade well the time has arrived and the little work van is being modified. after being beat by a suzuki swift by 0.3 kw it was time to do something about the lack of power. the little van is a Toyota lite ace 91' model when i bought this van it was a mess so the old motor came out and a 5K went in (1500cc) but i had a drama with the gearbox NO 5th gear. the poor little thing at 90Kmph you were half expecting the motor to jump up on the seat beside you. That in its self wouldn't have been a biggy as the motor would have sat there quite easily hahaha. Any way; After measuring up every thing under the van and then the donour motor and box. Earlier this week the job has started. the old motor and box come out,then a couple of crossmembers as well. just a little bit of the back of the van has been used up as well. Now the time comes to see if the every thing will go in the massive hole i have created and line up to the diff????? After a little juggling and moving around the place. IT BLOODY FITTED. Yesterday was the day to make the crossmembers for the engine mounts and also the gearbox crossmember today is finish off all crossmembers then start mounting the Go bits stay tune more to come as it gets done |
Craig Webber
DieHard Vic TT
Posts: 513 Reg: 07-2005
| Photo's photo's photo's |
Lew Radbourn
Posts: 1665 Reg: 07-2005
| tonight Craig |
Paul Drane
TryHard QLD V8 Limited
Posts: 387 Reg: 07-2005
| Here is a photo Craig...... Howz that
Craig Webber
DieHard Vic TT
Posts: 515 Reg: 07-2005
| There alway one.hahahaah |
Lew Radbourn
Posts: 1667 Reg: 07-2005
| Good on ya Paul; dramas with the internet at home so pics will have to wait a little bit. Craig ring me when ya can |
Goo Roo Qld UZZ32 ( V8 )
Posts: 1498 Reg: 07-2005
| Can I have the old van engine? It's about time I did something to increase my cars performance. |
Lew Radbourn
Posts: 1671 Reg: 07-2005
| Perry; that will make it a 5.5lt 12 cylinder mate you will only bitch about the fuel used to run it. hahaha IN THE SHED |
Craig Webber
DieHard Vic TT
Posts: 516 Reg: 07-2005
| Answer your dam phone. Left message will ring you tomorrow being Saturday. |
Ben Daniel
DieHard WA Twin Turbo
Posts: 828 Reg: 03-2006
| Lew, you are all kinds of crazy ! Cant wait to see the van |
Justin Hughes
Goo Roo VIC TT
Posts: 1107 Reg: 07-2005
Craig Webber
DieHard Vic TT
Posts: 517 Reg: 07-2005
| Oooo arn't we a pretty boy |
Craig Webber
DieHard Vic TT
Posts: 519 Reg: 07-2005
| You'll be able to change the plugs as you drive check the oil.Good thinking Mate.Going to be a bit warm on your side, better keep those heat shield on those turbo's. |
Lew Radbourn
Posts: 1679 Reg: 07-2005
| Craig ; problem solvered mate I made a down swept manifold and put a T67 Greedy single turbo on it.the turbo sits just above the engine mount. and the top of the manifold is about 5" away from the engine cover. But yes the heat shield will go on as well i start making the new intake manifold tomorrow as that has to be lower as well. the throttle body will be about the height of the power steer pump in the pic below NO air con pump OR power steer pump power steering is going on the van (Nissan silvia) that rack and pump looks like it will JUST about bolt straight in there ...(famous last words)hehehe |
Lew Radbourn
Posts: 1683 Reg: 07-2005
Lew Radbourn
Posts: 1684 Reg: 07-2005
Aaron Mead
Goo Roo NT TT
Posts: 1010 Reg: 03-2006
| Good arm rest/card table. |
Craig Webber
DieHard Vic TT
Posts: 520 Reg: 07-2005
| A MAD man at work hahahaha hahahaha hahahahah |
Lew Radbourn
Posts: 1686 Reg: 07-2005
| at least this way i will have a console. normaly it is a little seat that a baby could sit on.. if i make the console right i recon i could have a real nice leg of lamb just about cooked by the time i get to canberra i could even throw in a couple of spuds and roast them as well.HAHAHAHHAHAHAHA
Aaron Mead
Goo Roo NT TT
Posts: 1015 Reg: 03-2006
| I gotta bulge just looking at that! |
Jeff Smith
DieHard NSW TT Limited 13.295@102mph\165kph,13psi
Posts: 938 Reg: 07-2005
| THAT'S MAD Friggin unreal. ultimate stealth. |
Jeff Smith
Posts: 939 Reg: 07-2005
| We have to see a 1/4 mile time out of this! I've got a fat just looking at it.Haha |
Lew Radbourn
Posts: 1756 Reg: 07-2005
| well things are progressing along nicely. the front section of the floor has been cut out and radiator mounted. also front of van has been cut to mount another air intake for the radiator intake manifold is being welded up. the drive shaft is on (cute little thing) about 7" long from uni to uni . if that spits out i won't even hear it hit the ground. and my computer arrive this morning (thanks Andrew) this is going to be scary. |
Jeff Smith
Posts: 985 Reg: 07-2005
Lew Radbourn wrote on Monday, January 29, 2007 - 03:03 pm:this is going to be scary.
Haha.....I cant wait to see running video's of this.And 1/4 mile run slip. |
Phil Gibson
DieHard WA '94 black/black UZZ31
Posts: 906 Reg: 07-2005
| jeeezus thats crazy enough to get on Toymods |
Richard Baird
TryHard Perth, WA rubber band
Posts: 258 Reg: 07-2005
| Damn nuts Lew..... And i love it...!!!... |
Lew Radbourn
Posts: 1846 Reg: 07-2005
| well things are moving slowly along; front bumper has been cut and meshed. front mount has been fitted. tunnel from front of car to motor has been completed. i sat here for 2 hours on sunday sorting out what wires went were for the haltech (only to find out several wires had been cut back and thay were wires that i needed) and started the rewiring of the engine and coil packs. single 3" exhaust is finished. things will slow down on the van now whilst i move workshops. the aim is to have it all done with in the next 2 months. |
Joshua Rowland
DieHard Victoria TT GTTL(Manual)
Posts: 944 Reg: 08-2005
| Sounds great, cant wait to see it and get a ride in it. |
Brett Harrison
TryHard QLD JZZ30
Posts: 134 Reg: 09-2005
| is that going to be a burnout promotion car or what ! wasn't aware you were moving lew, i'll have to drop in been a while |
Adam Lonergan
TryHard Victoria UZZ32
Posts: 495 Reg: 08-2005
| Brett, I think Lew needs this so he can move premises VERY quickly |
Troy Tappenden
TryHard WA JZZ30 (TT)
Posts: 408 Reg: 07-2005
| Awesome... Just awesome... Quarter Mile times when it's done or you get banned from the web site Lew! Ha ha kidding! Good work mate! |
Chris Davey
Goo Roo QLD Corona
Posts: 1315 Reg: 07-2005
| First time I have seen this. Looking good Lew As others have said, need 1/4 times There is a damn quick 1jz hiace from NSW. Runs 11.1's but the mph is down because of the brick like aerodynamics Liteact being a bit "lighter" ironically should be good. What diff are you using? brakes? chute? What is the stock weight of a liteace? |
Lew Radbourn
Posts: 1898 Reg: 07-2005
| Chris; weight? Mate i have no idea but i can push it around the workshop easily with the motor and box in it. Chris i recon the weight would be around 1 ton I will take it down and weigh it when its finished diff? that will be a hilux limited cut down with ladder bar set up eventually using the hilux rear brakes the front brakes i am still thinking about that one possibly a set of TT soarer . chute? may have too. that will come later, I don't want to go over board with chutes as the car will be still street driven right now but before it is track ready it will be fully role caged . Being a very short and narrow wheel base this thing is going to be scary. fuel system is now done carter lift pump 2lt surge tank 044 main pump 540cc injectors. intercooler is in position with air ducts in place Just need to do the pipe work for intercooler this week end and then the wiring starts |
Troy Tappenden
Posts: 447 Reg: 07-2005
| Hey Lew, it's been a while! Can us people from outside the Gold Coast get an update on what is happening/happened since your last post? Interested to find out |
Jeff Smith
Goo Roo NSW TT Limited
Posts: 1381 Reg: 07-2005
| Second that troy! |
Mustafa Akgul
Goo Roo NSW Big Mac
Posts: 1422 Reg: 07-2005
| Lew how is this beast coming along? |
Lew Radbourn
Trader Queensland jzs147 92,93,95 TT's / uzz30 93'/ 2 X uzz31 92' s
Posts: 2092 Reg: 07-2005
| Well guys its that close i can smell the rubber burning. having dramas with the Haltech what a pain in the arse system it is. The Van is at another workshop getting the Haltech sorted out if it comes down to it by next friday and nothing has been done to it i will rip the haltech out and ram it up some ones clacker and put a microtec in By looking at the Microtec site it will be a heaps easier system to fit and even i could get it done in a day |
Mustafa Akgul
Goo Roo NSW Big Mac
Posts: 1424 Reg: 07-2005
| Lew I have used EMS ecu`s before and there latest ecu the 8860 is the go mate. can do anything you could dream of. and its only about $1300-1450 http://www.enginemanagementsystem.com/ |
Mustafa Akgul
Goo Roo NSW Big Mac
Posts: 1426 Reg: 07-2005
| http://www.enginemanagementsystem.com/ECU%20Specifications_files/Motorsport.pdf |
Joe Radisic
TryHard WA 2JZ GTE & Skyline V35 GT-8
Posts: 402 Reg: 10-2006
| Hi Lew, which Haltech are you using? |
Chris Davey
Goo Roo QLD Corona
Posts: 1458 Reg: 07-2005
| Microleb Lew. Easiest to install by a mile. Works bloody brilliantly on my car Absolutely love it! |
Goo Roo NSW I have a Cadillac and a Supercharged Manual V8
Posts: 4144 Reg: 07-2005
| Lew, Have a look at Denis's van http://youtube.com/watch?v=zlwwugUgDzc |
Chris Davey
Goo Roo QLD Corona
Posts: 1459 Reg: 07-2005
| Not that we condone that sort of behaviour but it ripped a decent skid |
Colin Kirkpatrick
DieHard NSW Soarer UZZ31 & UZZ32
Posts: 575 Reg: 07-2005
| How about this nice 520hp VW Van on the race track! http://youtube.com/watch?v=8XvjVvFdMIY&mode=related&search=
Lew Radbourn
Posts: 2093 Reg: 07-2005
| Joe; E6X Chris; Microleb? Neil; I recon i won't need the brakes to get it motivated to start off.hehehehehe O yer Neil my truck! sittin on the engine when finished not enough leg room if the motor is up front (quad cam) The back and side of block (drives side) sits right were the clutch pedal was. and it has to be a lazy under the arse as well the rear of the front leafs will be right at the end of the standard chassis then the lazy after that so i can add 2 meters to the lenght it all starts next week end |
Lew Radbourn
Posts: 2094 Reg: 07-2005
| Chris: hahahahahah I just found out what the hell Microleb was. bloody hell! I also read the post that you put up on toymods when you fitted yours I recon i have the same drama with the heltech so now i don't feel so bad |
Chris Davey
Goo Roo QLD Corona
Posts: 1460 Reg: 07-2005
| hehe, yeah that is what I call em Does a great job though. You mean the problem I was having with the wolf? Never had any issues with my microleb (that I can think of) |
Lew Radbourn
Posts: 2096 Reg: 07-2005
| No mate just the wiring diagrams not being correct I was told on the haltech that BOTH cam angle sensors had to be wire in and a mate down here told me about the wiring on the CAS being the wrong way from what microtec states. I really think i am going to have to bite the bullet and buy a microtec |
Lew Radbourn
Trader Queensland jzs147 93 TT / uzz30 93'/ 2 X uzz31 92' s
Posts: 2109 Reg: 07-2005
| well it finally fired 2 days ago YEEEE HAAAAAA I took it for a very short blast down the street yesterday and i recon a couple of toilet rolls will be hanging in the cab some were.LOL All i have to do now is sort out the auto computer (as it stays in first) But the sucking noise from the T67 sucking through the pod is ear drum splitting. and then all of a sudden BANG the little van just goes nuts...heheheheheheheh this is going to be so much fun to drive so today engine covers will be made and heaps of insulation fitted for heat and sound. Its getting close guys so close i can smell .the rubber all ready.hehehehehehehe |
Richard Baird
TryHard Perth, WA V-Sex
Posts: 367 Reg: 07-2005
| Crazy fooker Lew........and I love it...!! Are you running the standard ECU with the auto or aftermarket controller? Don't forget the vids too.....LMAO |
Jeff Smith
Posts: 1448 Reg: 07-2005
| Hahaha Great stuff mate! I can't wait to see it in action.On you tube |
Chris Davey
Goo Roo QLD Corona
Posts: 1480 Reg: 07-2005
| Great work Lew! What ecu did you end up going with? You have probably checked it already but the speed sensor at the rear passenger side of the auto will need to be connected for the auto to change out of 1st gear. I had that issue initially More pics? Entering for rescheduled Jambo?!?! |
Richard Baird
Posts: 368 Reg: 07-2005
| Thats true Chris normally if the speed sensors aren't connected it won't upshift.... |
Lew Radbourn
Posts: 2110 Reg: 07-2005
| chris; I stayed with the Haltec it turned out the ignitor was screwed.and i have two wires arse about. I am just getting into the supra stick computer as we speek to see what settings i have. I have taken some more pics which i will put up tonight. this new laptop i have doesn't have the program yet to shrink the pic's but the pc at home does. |
Joe Radisic
Posts: 434 Reg: 10-2006
| Good stuff Lew you'll need some wheely bars as well, so it doesn't flip on its arse hahaha. |
Lew Radbourn
Posts: 2111 Reg: 07-2005
| Chris any chance of getting your mobile number so i can talk to you about this tranny drama 0425749436 cheers Lew |
Lew Radbourn
Posts: 2112 Reg: 07-2005
| pics as promised; it doesn't take up to much of the cab area.
Lew Radbourn
Posts: 2113 Reg: 07-2005
Jeff Smith
Posts: 1451 Reg: 07-2005
| This is cool,Hahaha Ultimate stelf.You gotta love that! A b1tch to change a timing belt.hahaha .....Hoo care's Hay! |
Lew Radbourn
Posts: 2114 Reg: 07-2005
| hahahahaha Jeff Nar mate the cam belt is easy ...there is more room than the soarer has. BUT if the cam covers have to come off the engine has to be dropped or i have to cut about 15mm out of that cross brace just above them. up date..... well i found out last night i had a wire connected in the wrong spot (rpm signal) and now i have to sort out some sort of speed signal for the supra stick. thats my job for this morning then i better get and do some paying work.LOL |
Christian Molenda
TryHard QLD T
Posts: 438 Reg: 07-2005
| Coming along nice lew... good to see. Just gotta take it to somebody to tune it now. you could almost enter it in the jamboree... which has been re-scheduled to the 2nd (i think) of november |
Lew Radbourn
Posts: 2115 Reg: 07-2005
| WE HAVE A WORKING TRANS YEEEEEEEE HAAAAAA |
Lew Radbourn
Posts: 2116 Reg: 07-2005
| TUNE TIME, TUNE TIME, TUNE TIME.hahahahahah |
Chris Davey
Goo Roo QLD Corona
Posts: 1481 Reg: 07-2005
| So which speed sensor did you have to use? Who is tuning it? Great news. Enter for Jambo! I wanna race |
Lew Radbourn
Posts: 2118 Reg: 07-2005
| Chris I used the speedo drive one. and after talking to Ben last night the penny dropped to what i was doing wrong. also i had two wires arse about, as soon as i changed them and put in some correct settings (thanks heaps Ben) it started changing through the gears i am going to take it to Hi Torque on the coast here. i am just about to ring them to book it in (fingers crossed every thing goes well) hehehehehehe chris plenty of time for racing mate lets get this thing right the first time. BUT yer later mate.hahahahahah |
Lew Radbourn
Posts: 2123 Reg: 07-2005
| she left for the tuners about an hour ago so lets see what happens on the dyno guys start praying the motor stays intact."O" toyota gods PLEASE help this engine stay in one piece.heheheheheh |
Chris Davey
Goo Roo QLD Corona
Posts: 1488 Reg: 07-2005
| Need more confidence Lew! If it helps any, my mate had a t67-25g on his stock soarer apart from FCD (stock injectors) and ran it up to 26psi with it untuned on stock ecu. Motor never died...surprisingly Can't wait to hear how it all turns out! |
Lew Radbourn
Posts: 2124 Reg: 07-2005
| Chris; Yer mate it should be OK (fingers crossed) the motor sounds good before hand so we will see over the next couple of days BUT it still doesn't stop me thinking about what if!!! i just don't want to have to pull that motor out .hehehe not right now any way. |
Joe Radisic
Posts: 448 Reg: 10-2006
| This thing has 450rwhp super charged v8 totally MAD
Chris Davey
Goo Roo QLD Corona
Posts: 1491 Reg: 07-2005
| Goddammit Joe! I got the email notification and didn't even check who wrote it. I thought Lew posted that he just made 450rwhp! Not saying he won't but that would be bloody impressive for a first tune session with this engine that he was worried a little about letting go On the edge of my seat for the dyno figures BTW don't know if I missed it but what version of T67 is it? 20g 25g? |
Lew Radbourn
Posts: 2125 Reg: 07-2005
| Chris 25g is what it is Joe; hehehehehehehehe so i arn't the only crazy c-nt around hehehe makes me feel better i recon there should be a Van drags meeting organised |
Lew Radbourn
Posts: 2126 Reg: 07-2005
| well the saga continues just found out this morning that the Haltech has an internal problem it can't pick up on the water sensor. so now it will have a basic tune and then the computer sent to haltech to sort it out. a word of warning some 2nd hand computers are a right royal pain in the arse. |
Christian Molenda
TryHard QLD T
Posts: 453 Reg: 07-2005
| im feeling your pain mate... not good! bet your regretting not getting the microtech now.. Hope it all goes well and dont cost you an arm and leg with the temp sensor fix. i have similar probs with the way my ecu is set up. The water temp sensor it wired in but the jumper was never changed in the emanage. somehow this is altering the temp signal to the stock ecu and messing with things.. atleast i know under load when it is hot its ok to boot it. |
Joe Radisic
Posts: 453 Reg: 10-2006
Chris Davey
Goo Roo QLD Corona
Posts: 1492 Reg: 07-2005
| Bad luck Lew. Hope it all gets sorted out quickly. |
Lew Radbourn
Posts: 2132 Reg: 07-2005
| picked the van up last night, I still have to send the haltech off to be checked over BUT the van can still be driven (sort of) the tune has restricted the revs to 4000 and boost to 3-5 psi, BUT even at that its instant steering lock.hahahahahahha at 40-50kms it is on 3psi of boost and wants to launch its self down the road not forgetting it has been limited to 4000rpm the gearbox is changing But as Ben pointed out to me on the phone that the speed sensor isn't the best sensor to run the supra stick from so i have to check out some other sensor to run it from not really fussed about that as it will be manually changed most of its life. so monday the haltech gets sent off for repairs and then its back to the tuner for a decent run on the rollers |
Lew Radbourn
Trader Queensland / Gold coast jzs147 93 TT / uzz30 93'/ 2 X uzz31 92' s
Posts: 2161 Reg: 07-2005
| the saga continues; Haltech found that some one had doctered the ECU taking the temp sensor chip off the circuit board. WHY ?? god only knows so it is on its way back from Sydney today. Fingers crossed it express post. word of warning guys DO NOT BY A 2ND HAND ECU unless you have driven the car it has come out of. even if the person is one of ya close mate friend or fo and pulled it out of the car for you |
Paul Heginbotham
Tinkerer Queensland 2.5 TT
Posts: 11 Reg: 10-2007
| That's a bummer Lew. Did you get the same ECU repaired or purchase another one? |
Lew Radbourn
Posts: 2162 Reg: 07-2005
| Paul; mate this little ECU was not going to beat me so it was the same one Now Haltech have checked it all out so it SHOULD be in tip top condition (fingers crossed) |
Justin Cook
Goo Roo QLD JZZ30 TT
Posts: 1047 Reg: 07-2005
| Sorry Lew, I feel guilty, I will apologize, even though I had noooo idea. I certainly didn't tamper with it as you know. Interestingly, I would love to know why they took the temp sensor chip of the circuitboard. How they knew what to take off, the desire to do that, and how it could possible work with it missing? Could be to make the ecu run in cold mode all the time, but 1) its a programmable ecu, who cares you could program around this anyway. 2) you can just wire a resistor in to get around it. Absolutely confusing.... |
Justin Cook
Posts: 1048 Reg: 07-2005
| Although Karim, did give some excuse about the car not running well when I bought it off him due to injectors changing, and all it needed was a tune. Obviously there was something more wrong with it than that... |
Andrew Meiers
DieHard Victoria TT
Posts: 690 Reg: 07-2005
| Good to hear lew. Glad you have it sorted, that would have Fxxked me up completely. Not good with electronics! |
Lew Radbourn
Posts: 2166 Reg: 07-2005
| Andrew; hahahahaha Your not good with electronics imagine how i feel. Mate if i can't see it then i'm screwed so electronic's really stuffs me up. Justin; mate i am not blaming you at all. it is just a learning curve that we all have to go through BUT don't ever introduce me to Karim i will tear his head of and crap down his neck.hehehehehe he didn't tell you the full history of what has been done or what was going on. people like that i have no time for. |
Scott Ferguson
DieHard Alberta Soarer GTT-L
Posts: 827 Reg: 07-2006
Lew Radbourn wrote on Friday, October 26, 2007 - 08:30 am:BUT don't ever introduce me to Karim i will tear his head of and crap down his neck
No, no. YOU'LL SHOVE A WRENCH SO FAR UP HIS ARSE YOU'LL BE ABLE TO CARVE YOUR INITIALS INTO TOMORROW'S SH!T!!! (sorry getting a little too creative.) Just chiming in to say that i can't wait to see this thing going. I killed myself laughing when i first saw what you were doing Lew and watching this thing get built is awesome. |
Lew Radbourn
Posts: 2170 Reg: 07-2005
| Scott; hahahahahahahahahaha thats a good one mate. don't know about carving in tomorrows crap but i recon my arm will be long enough to pull his heart out through the same hole. i sat down last night and worked out that this ecu and other parts of the kit (stuffed ignitor.stuffed coils.)and then paying some one to sort out these problems. i could have fitted a NEW E11 haltech and had it tuned |
Joe Radisic
Posts: 483 Reg: 10-2006
Lew Radbourn wrote on Saturday, October 27, 2007 - 07:45 am:i could have fitted a NEW E11 haltech and had it tuned
Learning curves!!!! |
Lew Radbourn
Posts: 2171 Reg: 07-2005
| Joe; yer mate it is just that. learning curve that is why i have posted the head aches i have been having Justso may be it might help other readers to be carefull when buying 2nd hand ecu's |
Jeff Smith
Goo Roo NSW GT30/37r Single
Posts: 1533 Reg: 07-2005
| What a bummer! As they say "you get what you pay for" Skimping corners only ends in tears,As I did the same thing with cheap turbo's....The lesson here is spend the $ and reap the rewards. |
Ken Stevens
Tinkerer Qld Soarer tt
Posts: 9 Reg: 08-2007
| Hey Lew! I was at movie world last night in the scooby doo coaster queue. And something dawned on me! I found out why you are doing up this van for real!!! Its because you're a scooby doo fan, you're doing up "The Mystery Machine"!! woo haaa! |
Nathan O'connor
Tinkerer qld jzz30
Posts: 29 Reg: 02-2006
| All the best with the tune tomorrow, fingers crossed it all holds together |
Lew Radbourn
Posts: 2182 Reg: 07-2005
| Thanks Nath we shall see what we see |
Paul Heginbotham
Posts: 26 Reg: 10-2007
| Any news yet? |
Lew Radbourn
Posts: 2184 Reg: 07-2005
| Well i have just got back to the workshop from the dyno. 5 hrs of dyno time and the result was not to bad. i was actually expecting more. BUT we didn't push the boost through the roof. I have a small leak in the intake gasket around number 2 and just behind the throttle body so when the result was shown i thought thats enough then the dyno guy said youbetter add another 10% to the result as the dyno is out so in total i have a toyota lite ace that will kick arse. you ready now .HAHAHAHAHAHAHHA 234rwkw@16 psi also it weighs with a full tank of fuel and me in it 1.42 ton |
Jeff Smith
Goo Roo wollongong NSW GT30/37r Single
Posts: 1585 Reg: 07-2005
| Congrats Mate! Awsome stuff. Now for the 1/4 time! |
Goo Roo QLD TT with a T-66
Posts: 1232 Reg: 07-2005
| That van is SO DANGEROUS! Count me IN for a drive Lew ! hahah |
Will Schultz
Tinkerer new south wales tt
Posts: 57 Reg: 05-2007
Lew Radbourn wrote on Tuesday, November 06, 2007 - 07:56 pm:234rwkw@16 psi
Holy crap thats nuts. |
Richard Baird
Posts: 382 Reg: 07-2005
| Hey Lew what diff is in that thing? God bless Toyota...!! |
Lew Radbourn
Posts: 2185 Reg: 07-2005
| James On the way home from the cruise mate (my place) we will have a little blast |
Craig Webber
DieHard Vic TT and LS400
Posts: 616 Reg: 07-2005
| You fcuken MAD Man. I was up there a couple of week's ago,and have seen it in person. It's a neat bit of work. Must have been that bit that came of my car that that push it up there hehehe. The Van not dangerous it the nut in it(Lew). And thank's mate for the relay did the job all back up and working. So what date will you be down with as. |
Lew Radbourn
Posts: 2186 Reg: 07-2005
| Richard HAHAHAH the standard lite ace diff mate thay are only a baby 7" diff but have some mean mother teeth in there.it is a 4.3:1 ratio i have another one sitting on the side that i have a mechanical LSD centre to fit in it. but i have to make sure the axles will fit in the centre thay are actually an AE86, Tarago,diff Craig leaving here on the 26th so i will see you on the week end following i will be in Ballarat at mums and Josh's then reepas. then Anglesea to see my brother then to your place and finaly home again. to be back here by the 2nd some thing like that "O" yer its great not hitting the rev limiter any more. we played with the supra stick so it would stop trying to jump off the rollers so some of the settings are screwed now i will have to sort them out this week some time and also fit the manual controls for the trans. so i really can't foot it to well right now. but it has scared me all ready.hehehehehhehe ME a NUT........ NEVER just a some one that doesn't want to grow up. heheheheh |
Paul Drane
DieHard QLD V8 Limited
| Awesome stuff Lew |
Paul Heginbotham
Posts: 27 Reg: 10-2007
| Good news Lew!! Congrats on a job well done. Who would have thunk |
Lew Radbourn
Posts: 2187 Reg: 07-2005
Paul Heginbotham wrote on Tuesday, November 06, 2007 - 11:18 pm:
Who would have thunk HAHAHAHAHHAHAHAHHAHAH Well probably 2 other cars know by now not to mess with the Van hahahahahaha |
Chris Davey
Goo Roo QLD Corona
Posts: 1497 Reg: 07-2005
| if you hav e a T series rear end I can see it dieing at the first launch at the strip! Sprinter guys break them with 4agte's! Go hiace G series with hilux centre. 3.7:1 I would recommend if you can find them. |
Chris Davey
Goo Roo QLD Corona
| BTW good dyno result I made 230rwkw@15psi with smaller turbo so it probable is a little understated if the tune is good Depending on weight you should be able to trap around 115mph which is good for an 11 with about 1.7 60 ft |
Lew Radbourn
Posts: 2188 Reg: 07-2005
| Chris Looking into the diff situation and the hilux will go in there when i find a good one. the van weighs 1.42 ton with a full tank and me in it. |
Chris Davey
Goo Roo QLD Corona
Posts: 1499 Reg: 07-2005
| Good stuff In a normalish more aerodynamic vehicle, I get 117mph for 1.42t or 3124lbs and 249rwkw. So probably about 115mph with your brick For ref, there is a guy with a gt35 1j that was running 32psi with a pretty decent tune on c16 and he was trapping 122mph. Ran 11.1 though cause it launches like a mofo! A cressida with similar power will trap around 125-127mph and AFAIK they are a tad heaver than hiace at 3350-3400lbs plus driver Can't wait to see your van race! Have to get vids! I am off to Japan in a month so I may not be able to get there to watch or race you Unless you want to race at streetcar shootout on 24th Nov BTW for your ref most hilux's are 1410mm drum to drum whereas hiace's are 1470mm. I have hiace in my car and it isn't shortend so I am limited to using wheels with high +ve offset. 15X6.5's with +45 at the moment. Fronts 15X4 -10 |
Tai Johnsen
TryHard QLD UZZ31 - V8
Posts: 393 Reg: 04-2006
| Nice work Lew!!! No way in hell i would take that thing down the 1/4.... I feared for my life when it had 2HP and was going 43km/h Drive over an ant and you'll be in the wall My prediction = then death |
Lew Radbourn
Posts: 2190 Reg: 07-2005
| Tai; "O" ye of little faith!!!!!!!!! hahahahahahahah I have raised the front up a little and put new shocks and stuff under the front. It is still very tight in the arse end but that can't be helped (YET) With the weight between the front and back axles it actually sits better on the road and is nothing for it to hit 170kms an hour and feel not to scary at that speed. mind you i only did it once and when thay(nuts)dropped back to were thay should be i felt a little more comfortable. HAHAHAHA really it does sit better on the road. just trying to sort out the shift pattern on the auto controller i seem to have got it fairly well right up top just have to do some minor adjustments for cruise. then set up the manual controls. |
Will Schultz
Posts: 61 Reg: 05-2007
Lew Radbourn wrote on Thursday, November 08, 2007 - 03:57 pm:and is nothing for it to hit 170kms an hour
Ok now i really believe your nuts |
Will Schultz
Posts: 73 Reg: 05-2007
| I met Lew yesterday at the caltex a bit north of sydney to pick up my exhaust. As we headed towards sydney he gave the van a bit coming up my right side. I must say its somewhat embarrassing watching a little blue liteace fly past your soarer like your standing still. The van is awesome and sounded sweet.It was pi#@ing rain to so i doubt i saw the half of it |
Jeff Smith
Goo Roo NSW GT30/37r Single T
Posts: 1721 Reg: 07-2005
Will Schultz wrote on Tuesday, December 04, 2007 - 06:52 pm:I must say its somewhat embarrassing watching a little blue liteace fly past your soarer like your standing still.
Hahahahaha........Good one lew.I would like to see a video of it in action.At the strip of course. |
Lew Radbourn
Posts: 2227 Reg: 07-2005
| Will; Mate tender hooks allong the road Pissing down??? forget cats and dogs go straight to cows and elephants. i eventually stopped about 60kms east of Albury that night So about 19hrs driving. |
Will Schultz
Posts: 75 Reg: 05-2007
| Bloody hell.My arse would be numb after 6 hours driving let alone 19.And cows and elephants is right. At least it didn't hail on us |
Lew Radbourn
Posts: 2230 Reg: 07-2005
| Will mine was numb i was glad i only had a 45ltr tank that way every 3.5 -4 hrs i would have to get out |
Brett Moloney
DieHard Queensland Supercharged UZZ31
Posts: 621 Reg: 07-2005
| Might be time for some video action soon Lew! |
Lew Radbourn
Posts: 2479 Reg: 07-2005
| The dramas have started.hehehehehe well little ones any way; about a month ago i melted the forward friction plates in the trans. the only good thing about that was the trans stopped slipping hehehehehehheehhe the diff also decided it was time to end its life. well i can't blame it for giving up. Poor little thing... So Aristo auto with shift kit has now been fitted just connecting the B&M pro rachet shifter and MV's auto computer box thingy. Diff is a 2wd hilux (pick that up on Monday) Exhaust has been changed to a nice neat side pipe because the diff housing was belting the 3" exhaust pipe to death over bumps. with the diff going in it next week i can then work out how far i have to cut out the back to run mini tubs the tyres will be 31" high on 15" rims and am looking at around 10-11" wide. i will see how i feel when the time comes. any way that about it for now. |
Lew Radbourn
Posts: 2480 Reg: 07-2005
| Below is Pics of the interior as a finished product and the other is athe turbo manifold at full revs on the dyno when it was being tuned.. "O" yer the engine cover doubles up as a good pillow as well.heheheheheh
Scott Ferguson
Posts: 958 Reg: 07-2006
| Lew, what is there to fitting a pro ratchet? Is is just the shifter that changes or do you have to manualize the auto as well? Oh and by the way you are slightly insane, but i love the van |
Lew Radbourn
Posts: 2481 Reg: 07-2005
| Scott Mate you don't have to manualize the auto to fit one. The shifter is a great idea for drag racing. You can just belt the lever and you know it will only hit the next gear until you belt it again. SLIGHTLY INSANE????????????? hahahhaha NAR mate I've lost it.hahahahahahaha i think it all started because the year we moved up here from VIC it was one of the hottest summers up here and my workshop was so small i had no room to put any thing so i thought i better use it or loose it!!! I lost it.LOL |
Scott Ferguson
Posts: 959 Reg: 07-2006
| Well, if you're gonna lose it... seems like a good way to go! Do you use the MV auto's brackets to mount or did you make your own? |
Lew Radbourn
Posts: 2483 Reg: 07-2005
| Good idea to talk to mike if he has all the bits just get them direct from him |
Scott Ferguson
Goo Roo Alberta Soarer GTT-L
Posts: 1014 Reg: 07-2006
| Lew do you use the MV shift control box with the b&M? |
Lew Radbourn
Posts: 2530 Reg: 07-2005
| Scott; Mate i haven't yet used the MV's shift controller I have had some dramas with coupling 2 push/pull cables together so i can select the gears properly I have got to get a single cable made up next week So with this drama I will leave the supra stick in the van until i get the cable. the B&M is in I now have an Aristo auto in and a G series Hilux diff this morning i am replace the rear wheel bearings as one is making some noises. Other than that with a LSD diff in it now it is Bloody awsome to drive I have now got 2 diff centres 4.8 and 4.1 ratios once i tub the bum with the drag slicks then i will decide what ratio will stay in it. with a 4.8 ratio diff and 26 " high wheels it is reving about 4000 rpm at 100kmph so with 29 1/2"high slicks i am yet to see what happens |
Mike Thomas
Tinkerer AB JZZ30 GTTL
Posts: 94 Reg: 09-2007
| can i just ship my soarer to you lew to be worked over? lol probably cost me less in the end than blowing it up a few times myself.. what a riot... nice job on that van |
Lew Radbourn
Posts: 2532 Reg: 07-2005
| Mike i wish ya could mate. I will help ya out as much as possible Via Emails mate. those figures you quoted in the last email will be very easy to get more with the correct items in place. |
Lew Radbourn
Posts: 2568 Reg: 07-2005
| Up date; Had a few leaks in the intake manifold due to warping when it was made (now machined flat) It will have to go back in on the dyno shortly for a check up just to make sure after the manifold being corrected. Well after fitting the 4.8 diff in the van it was screeming its tits off. so out it came. it now has a 3.58:1 4 pinion LSD out of a 2002 hilux. F**K me does this thing fly down the M1 now. 2000rpm and its doing 105kmh Supra stick has been removed and a MV Auto controller has now been fitted combining the controler with a B&M pro ratchet shifter is a very good combination the best control over the auto so now with more control it shoots off like the rocket it should be. also having the B&M in there you have 3 gears on the shifter and also control over the O/D and torque converter lock Via a switch. hahahahahahha Still getting used to that side it doesn't like it when ya forget to switch the O/D off and then try to take off. But if ya forget to unlock the torque converter BOY O BOY what a difference that makes. So now it is Brake up grade time for the front the backs are hilux all ready so that is good. |
Chris Davey
Goo Roo QLD Corona
Posts: 1608 Reg: 07-2005
| Hi Lew, is the 3.58:1 diff out of a manual hilux? They would be the ones marked as an A series diff but are still 8" and interchangable with the old g series right? Also, if you don't mind me asking, how much do they go for? |
Goo Roo QLD XTR T-66 Turbo
Posts: 1838 Reg: 07-2005
| So is it done yet Lew ? Is it coming out at Powercruise? I wont be attending though unfortunately. I still have some work for you mate YOu should say you are closing down more often... great way to generate instant business hahah |
Lew Radbourn
Goo Roo Queensland / Goodna uzz30 93'super charged . 502Hp Toyota lite ace
Posts: 3318 Reg: 07-2005
| HAHAHAHHAHAHHAHAHAH Well bugger me I didn't realise how long ago i did that van. Well it is still going But is very close to be pulled down and the running gear transplanted into another body. It now has a 1.5j in it with 150Hp shot of nos down its throat. it still has heaps more potential BUT in the van body that is rusted out it is not a wise move It has 502Hp it is on Youtube under Ballistic brick dyno run. |
