  Soarer Central * Soarer Diagnostics * Automatic Transmission Diagnostics Previous Previous    Next Next
Open in new windowError Codes SC400 (V8) 42 to 67Admin
Open in new windowError Codes SC300 (3 Litre) 42 to 64Peter Nitschke
Harry Lemmens
Sunday, November 21, 2004 - 03:55 am, by:  Harry Lemmens Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Toyota Soarer / SC400 Automatic Transmission Diagnostics
Auto Trans Cutaway" title="Auto Trans Cutaway
Transmission Internals
Diagnostic Procedure
The 1UZFE (V8) Automatic transmission trouble codes are accessed via the “Normal” engine diagnostics. (IE: TE1 and E1 connected together.)
The following procedures show how to enter the diagnostics modes for the Automatic transmissions used in the SC300 and SC400. (The TT procedure is identical!)
Since the transmission also relies on a throttle position sensor, brakes and the selected gear, a test procedure for those items is also shown below. (See Terminal TT diagnostics.)
Auto Diag 1" title="Auto Diag 1
Figure 1 Automatic Transmission Diagnosis Procedure (part 1)
Auto Diag 2" title="Auto Diag 2
Figure 2 Automatic Transmission Diagnosis Procedure (part 2)
Cancelling Error Codes
Auto Diag Cancel codes" title="Auto Diag Cancel codes
Figure 3 Cancellation of Automatic Transmission Trouble Codes.
Error Codes SC400 42 to 67
Auto DTC codes" title="Auto DTC codes
Figure 4 1UZFE Automatic Transmission trouble codes.
Error Codes SC300 42 to 64
The following codes are specific to the SC300 automatic transmission!
Figure 5 SC300 (3 litre) Automatic Transmission trouble codes.
Obviously, the SC300 auto transmission is NOT identical to the SC400 transmission! however, this transmission is similar to the transmission used in the TT, and therefore the diagnostic codes may be more appropriate.
There are no electronic diagnostics for the manual transmission (SC300). This is curious, as monitoring of the vehicle speed sensor/s is a component that would have been testable. (And, is a relatively common source of trouble!)
The following diagnostic applies to the SC400, SC300, and the Twin Turbo Soarers. It tests most of the possible switch inputs to the automatic ECU, as well as the sub throttle position sensor.
Figure 6 Terminal TT diagnostics.
Harry Lemmens
Sunday, November 21, 2004 - 11:07 am, by:  Harry Lemmens Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
A PDF version of this document is available for download.
Right Click your mouse on the Attachment below and use Save Target As to direct it to an appropriate location on your local Hard Disk. That way you will always have the document on hand for quick and ready reference!
application/pdfAuto Tran Diag.pdf
Auto Tran Diag.PDF (560.3 k)
