Author |
Message |
Craig Moore
TryHard SA V8 Uzz31
Posts: 119 Reg: 07-2005
| I did a search but was unable to find the part # I have been trying to find this damm leak for weeks and it has been driving me mad, today I found the #$%^%$#..... It is the "O" ring behind the pump hose fitting. I need the part number for the "o" ring for the lower fluid hose from the power steering fluid bottle to the pump. The "O" ring is located behind a fitting bolted to the pump. I also need the number for the hose. Thanks if anyone can help |
Moderator New Zealand I have WAY less Soarers than Hayden :-(
Posts: 5869 Reg: 05-2005
O'Ring part number: 90301 - 12003 Hose part number: 44348 - 24030
Craig Moore
TryHard SA V8 Uzz31
Posts: 120 Reg: 07-2005
| Thanks Don. |
DieHard Western Australia Bugatti Veyron
Posts: 619 Reg: 04-2006
| speaking of which, I topped my power steering reservoir up 2 weeks ago to stop this groaning feedback through the steering and now it looks like its returning again. Don, would you suggest I have other problems (like Craigs)or would it simply be air from the first time making its way through the system again ? |
Posts: 5870 Reg: 05-2005
| It's possible you've got a leak Adam, but it's probably a teensy one if it's taken a couple of weeks to rematerialise so to speak. Have a close look at the top of the pump (where Craig's was leaking, plus the usual hose connection points.
Roger Costello
TryHard WA UZZ31 V8 Limited, UZZ32 no 867
Posts: 326 Reg: 07-2005
| Also check the high pressure idle up vacuum switch on the PS pump high pressure outlet. The diaphragm can go leaky and PS fluid is slowly sucked into the inlet manifold. Common symptoms are disappearing PS fluid and a bit of blue smoke when the engine is first started in the morning. If there is PS fluid wetting the inside of either vacuum hose attached to the switch it is cactus. You can either replace it with a new one (around $150 plus labour) or as some have done in the past put a brass bung in its place with some thread tape and block off the vacuum hoses until you want to fix it properly. Its purpose is to compensate for high power steering loads while parking by passing some additional air to the inlet manifold but the engine ECU will normally compensate enough if you disable the switch. |
Posts: 622 Reg: 04-2006
| I just had to top it up again, it was very low - second time in a week !! I'll see how it goes for the rest of the week |
Junk Filterer South Australia GT4.0 V8
Posts: 7160 Reg: 11-2004
| Like you expect it to get better? |
Posts: 623 Reg: 04-2006
| OK well I checked under the car thismorning - after topping it up last nite and leaving it rest and yes my suspicions were correct. I think there is a leak in it and you were correct Peter. Problem is now how to fix it and where do i look.. |
Goo Roo North Island JZZ31
Posts: 2268 Reg: 10-2005
| Hmm, if it's a V8, get it looked at ASAP as it'll most likely be destroying your alternator. |
Posts: 626 Reg: 04-2006
| That'll be right |
Posts: 629 Reg: 04-2006
| Are V8 and the TT power steering reservoir / pump compatible with each other? |
Roger Costello
Posts: 329 Reg: 07-2005
| No. |
Posts: 630 Reg: 04-2006
| stupid soarer... |
Posts: 633 Reg: 04-2006
| OK I high pressure cleaned under the hood tonite and made everything oil free. Hopefully tomorrow I will be able to see where the leak is coming from. Ive lost about 50ml in 3 days of topping it up. I have a feeling it is the hoses tho. I can see some oil seeping thru. OK I checked it thismorning and i see 3 stress fractures in the hose connecting the reservoir to the pump. Hopefully i can replace that and get new clamps to fix the problem. Where can I get that hose from ? |
Posts: 5878 Reg: 05-2005
| Toyota Adam. Part number: 44348 - 24030 Clamps: 90467 - 21005
Posts: 642 Reg: 04-2006
| OK Don I had a good look at it today and under the car and OMG there is oil EVERYWHERE!!!! Its like dripping a the laundry tap. However i think its actually the power steering pump - because there is lots of fresh oil all around it. The hose as suggested is fine. After reading up on the planet soarer site i have a feeling i have blown a seal and oil is gushing out of that little hole on the pump. |
Posts: 7192 Reg: 11-2004
| "Yes sir, the stuffed alternator that you ordered? Coming right up sir..." |
Posts: 643 Reg: 04-2006
| Im trying to get it looked at tomorrow - before the alternator blows itself up from drowning in oil! How can this happen so suddenly ? |
Posts: 2294 Reg: 10-2005
| Fair bit of pressure going on in there. Or if you mean how can the alternator get stuffed so quickly, I think the PS fluid attracts a lot of dust and grit and this is what wrecks your alternator. I think it'd be a good idea to get it out and get an auto electrician to service it while you are at it. |
Posts: 645 Reg: 04-2006
| I have been told i need a new PS kit with new seals etc and that driving it any further will cause more damage - hence a blown alternator. I have been quoted just over $400 to have it all fixed .. |
Craig Moore
TryHard SA V8 Uzz31
Posts: 122 Reg: 07-2005
| Don't forget when you do the pump to replace the "O" ring that started this thread. It's not in the kit so you have to order it as well. Follow the details on the PlanetSoarer site and you can't go wrong. You have to drop the alternator to make it easy to get to the pump lower mounting bolts so it's up to you if you want to get it checked/cleaned/repaired at the same time. |
Posts: 7196 Reg: 11-2004
| The bearing isn't in the kit, worth doing, available from bearing shops. I read that the P/S fluid eats the insulation on the windings in the alternator or something like that. |
Darryn Dewar
DieHard Gisborne UZZ30 Soarer
Posts: 681 Reg: 09-2005
| The O-Ring that Don highlighted should be in the kit |
Posts: 651 Reg: 04-2006
| Ive decided to drop the car off at my mechanic monday and he is pulling it apart and fixing it, all parts, oil etc included, drive in and drive out. I dont have the time or expertise to do it myself. |
Chris Papas
Tinkerer NSW V8
Posts: 19 Reg: 11-2006
| Is it possible to have a small crack in the power steering reservoir, at the bottom. I've notices oil sitting at the base of the PS reservoir. I've checked the hoses and they seem ok. Could it be coming from somewhere else ? |
Posts: 771 Reg: 04-2006
| Chris get it fixed ASAP !!!!!!!!!!!!!!! FRom driving mine with a similar problem for less than 2 weeks I had to spend over $700 to rebuild the alternator / PS pump and the rest. |
Posts: 7472 Reg: 11-2004
| Adam, he is referring to the reservoir, not the pump, though it's possible that fluid could still get into the alternator maybe. |
