  Soarer Central * Mechanical - Common * Quick BFI question Previous Previous    Next Next
Scott Wilkes
Tasmania
92 TT Factory Manual
Reg: 10-2008
Monday, January 26, 2009 - 08:39 am, by:  Scott Wilkes (Scottywilkes) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
ive had the front of my box cutout for a while now, there was a small increase in power. Made a top cover etc.
What im wondering is that behind the filter there is another large plastic shroud.
I think its to do with sound coming back and deadening it. Has anyone removed this as well?
Its only a very small entrance into the inlet piping, i thought maybe by removing it it would open it up even more.
Soarer Limited UZZ31 V8
Monday, January 26, 2009 - 09:21 am, by:  Mike Beck (Gold_40gt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hmmm take a picture, I can picture what your referring to.
The TT box my have different part again compared to the basic V8 one.
Scott Wilkes
Tasmania
Reg: 10-2008
Monday, January 26, 2009 - 10:14 am, by:  Scott Wilkes (Scottywilkes) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
this is the part i am refering to here
I think it would be like a sound deadener, but it would also act as quite a large restriction i would think
Monday, January 26, 2009 - 11:21 am, by:  Mike Beck (Gold_40gt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Ah yes, I see it.
My guess it would have been a trick by the Japanese engineers to quieten the turbo sounds which come from the intake.
Can you remove that piece?
Scott Wilkes
Tasmania
Reg: 10-2008
Monday, January 26, 2009 - 11:26 am, by:  Scott Wilkes (Scottywilkes) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
cant remove it, but you can hack it out LOL, so you reckon its fine to hack it out? Got nothing better to do today and its out, would be interesting to see if it creates alot more flow
Monday, January 26, 2009 - 01:22 pm, by:  Mike Beck (Gold_40gt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yeah I would get rid of it, looks to be a sound suppressing device.
Joe Russell
Marlborough
4.0 V8 GT-L
Reg: 10-2008
Monday, January 26, 2009 - 01:46 pm, by:  Joe Russell (Joe_r) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I say rip it.
Scott Wilkes
Tasmania
Reg: 10-2008
Monday, January 26, 2009 - 02:01 pm, by:  Scott Wilkes (Scottywilkes) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
well i ripped it out.
Bugger me is it alot louder when in boost, you can hear it really sucking.
Also changed the note of my BOV quite substantially.
Dunno if i lost power or made it lol, its a really hot day so its not the best day to test. But it does sound alot meaner, may have to loosen the BOV a bit though, sounds like theres the slightest hint of compressor surge goin on.
Monday, January 26, 2009 - 02:43 pm, by:  Mike Beck (Gold_40gt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Scott Wilkes wrote on Monday, January 26, 2009 - 02:01 pm:
Hehe, well that confirms it was to reduce all that noise :-)
Great DIY mods.
Paul Ince
E-JZZ30-ACPZZ (93 TT Auto)
Reg: 01-2009
Monday, January 26, 2009 - 08:40 pm, by:  Paul Ince (Incey) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Since I changed to a pod filter I have noticed more air noises. Especially flutter/cough when coming off boost fast. Also get some 'sucking noise' but no where near what I get with the pod on my ute, a turbo diesel. What does compressor surge sound like?
XTR T-66 Turbo
Tuesday, January 27, 2009 - 12:54 pm, by:  James Harris (Haro) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
CH CH CH CH CH CH CH
David Tra
qld
Reg: 11-2007
Tuesday, January 27, 2009 - 03:13 pm, by:  David Tra (Bookie) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
depending on what turbo you are running, it may sounds like this,
(theres no hard evidence that compression surge causes damage)
http://au.youtube.com/watch?v=298ubnyu69Q&NR=1
or this (mine sounds like this on 15psi)
http://au.youtube.com/watch?v=V2TThg2FBOA&feature=related
or this
http://au.youtube.com/watch?v=TGMCWy7Czxs (mine on low boost)
Hope that helps
Paul Ince
Reg: 01-2009
Tuesday, January 27, 2009 - 04:26 pm, by:  Paul Ince (Incey) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks for the links, I spose I could've searched youtube for that but didn't think it would be there so well demonstrated. I'll have to do some recording with someone else on the throttle and see if its similar. Once I get a box around the pod I probably won't notice it so much anyway.
David Key
B.C.
Soarer 1JZ TT
Reg: 01-2009
Saturday, January 31, 2009 - 02:00 pm, by:  David Key (David_k) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I'm still confused at to exactly what piece was removed... I'm sure after a quick look at mine I'll notice something...
Scott Wilkes
Tasmania
Reg: 10-2008
Saturday, January 31, 2009 - 02:49 pm, by:  Scott Wilkes (Scottywilkes) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
the part within the box, that funnels into the actual intake is what i removed, with it removed it allows the air to be pulled through the whole airfilter with much less restriction.
Instead of that little circle there, its not all open
David Key
B.C.
Soarer 1JZ TT
Reg: 01-2009
Sunday, February 01, 2009 - 11:08 am, by:  David Key (David_k) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
That whole piece is removeable? Awesome. I'm on it!
Scott Wilkes
Tasmania
Reg: 10-2008
Sunday, February 01, 2009 - 12:52 pm, by:  Scott Wilkes (Scottywilkes) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
its removable with a dremel lol, u gotto cut it out.
Careful where its shallow, i managed to cut a small slice out of the actual box lol, nothing a bit of araldite and some nicely cut black plastic cant fix.
You will get a substantial increase in induction noise, it will change the noise of your BOV and you will get slightly more power.
Not bad for 10 minutes of cutting, cleaning and making 100% certain theres no plastic shavings in there that will make its way into the turbo impellers lol
