  Soarer Central * Mechanical - Common * CRACKED TAILSHAFT COUPLING Previous Previous    Next Next
Avin Luther
vic
Soarer uzz31 Limited
Friday, August 11, 2006 - 02:01 pm, by:  Avin Luther (Lex_luther) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
hi i got a road worthy inspection today ot clear a defect notice and have been told i have a cracked tailshaft coupling.
What do i need to fix this? can i do it myself?
anyone got parts in melbourne?
Graham Dollisson
I have more Leylands than Don
Friday, August 11, 2006 - 04:25 pm, by:  Graham Dollisson (Alloyvee) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
It's only rubber. Surely that wouldn't cost much new from Toyota!! Oh yes it does.
Friday, August 11, 2006 - 04:46 pm, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
>$300 each.
Saturday, August 12, 2006 - 11:20 am, by:  Don Bagnall (Baggs) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hey Avin,
as Neil says, these things quite commonly have fine cracks in them (it's sorta normal), and rarely require replacing, and as Peter has said, they ain't cheap (around $300!).
It sounds to me more like an inexperienced tester assuming that if it's got visible cracks it's rooted, which is not normally the case.
If however it really IS stuffed, here is the part number for ewe (Baaaa!)
37511 - 24010 COUPLING, FLEXIBLE UZZ3# (1991 - 1997)
Saturday, August 12, 2006 - 12:45 pm, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
And, there are 2. One at each end of the driveshaft.
Lew Radbourn
jzz30 ute / uzz30/ 2 X uzz31
Saturday, August 12, 2006 - 01:18 pm, by:  Lew Radbourn (Marlew) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Avin
Tell the drongo tester that if you can sit in the LUSH leather seats.and not be shaken out of them, then thay are fine.
as Don said above minor cracking is a common thing to happen to any rubber coupling.
Have a look at ya front bushes mate thay will have small cracks (but thay aren't stuffed are thay ?)
if all else fails drive to Geelong mate and see Phil at Geelong tune up and tell him ya need a RWC.
Saturday, August 12, 2006 - 01:33 pm, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
At what point do they need to be replaced though?
Lew Radbourn
Saturday, August 12, 2006 - 04:15 pm, by:  Lew Radbourn (Marlew) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
when you get a strong vibration happening
OR when you can put a small screw driver straight through it.
Saturday, August 12, 2006 - 05:05 pm, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Fairy Nuff! Thanks.
supercharged
Saturday, August 12, 2006 - 06:14 pm, by:  Greg Nikitiuk (Jestr) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
is this SMS talk Peter?
Shane McInnes
JZZ30 GT-TL Manual
Saturday, August 12, 2006 - 06:45 pm, by:  Shane McInnes (Soarin_tt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
lol That's Gold.
Avin Luther
vic
Monday, August 14, 2006 - 04:01 pm, by:  Avin Luther (Lex_luther) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
well i bought a second hand one from my favourite wrecker ToyRolla in Epping, it was $90 which i thought was a bit steep but given the new price.
it has no cracks.
Got under the car to swap it but couldnt get the bolts to even budge! not enough room to move with the resonators running either side, and when i realy lent onthe bolts, the rubber would move!
F&*%...
need a bloody hoist so i can get a long enough bar onto them.
Considering the mechanic only picked up the coupling and worn front tyres, i am pretty happy to stick with him.
Ross Pesina
Soarer T, Soarer TT, Supra TT,
Reg: 08-2006
Saturday, April 23, 2011 - 04:42 pm, by:  Ross Pesina (Ross79) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Just digging up an old thread.
I am getting a rwc and have been told that the coupling is cracked.
Can anyone confirm if the TT and V8 couplings are the same?
Saturday, April 23, 2011 - 07:13 pm, by:  Daniel Clarke (Dieseltrain) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
TT coupling is stronger . the V8 one looks smaller and doesnt have as much rubber thats for sure . Try and get a TT one if you can .
Ross Pesina
Reg: 08-2006
Saturday, April 23, 2011 - 11:25 pm, by:  Ross Pesina (Ross79) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks Daniel that's exactly what I needed to know.
Aaron Mead
Celsior 1UZ-FE Mines, JZZ30 1.5JZ-GTE To4z
Sunday, April 24, 2011 - 10:00 am, by:  Aaron Mead (Aaron) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
smear silastic over the cracked one, let it dry and trim the edges and voila, looks just like the non genuine ebay ones. Of course if they are in need of replacing then just replace them.
