  Soarer Central * Mechanical - Common * Help, every soarer problem known to man Previous Previous    Next Next
David Anstiss
v8
Thursday, December 29, 2005 - 04:17 pm, by:  David Anstiss (Too66c) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
where do i start, i have a miss when cold (see prev post) i have replaced plugs, leads, rotors, caps still i have a miss. could it be fuel pump ? it also surges at about 5000rpm. Next i went on holidays and left my baby undercover at home came home after a week and my speedo is going irratic, then my electric window died it wont go up or down motor is going but no movement, b then to top it all off i went for a drive down the coast and my power steer line dropped down on the ground rubbed through and i had to pay $300 for a mobile dude to fix it anyone have any fixes or ideas bits anything please help
i am running out of cash only had the car four months i love the car but these problems are killing me
UZZ-32 V8 Soarer #138
Friday, December 30, 2005 - 10:18 am, by:  Dan McColl (Hoon) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
The window thing :
http://soarercentral.com/sc-forum/messages/284/23447.html
The dash : http://soarercentral.com/sc-forum/messages/282/20178.html
The surging is possibly the fuel pump ecu. there have been a number of these playing up of late.
Run a search and you will find all the info you need. Just about every problem you will encounter will have been encountered and solved before.
Also check out the archives. Good luck. :-)
Adam Foster
SC400 Limited GT
Friday, December 30, 2005 - 03:18 pm, by:  Adam Foster (Adam) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
the miss when cold could be crank angle sensor
Ben Williams
none
Friday, December 30, 2005 - 03:48 pm, by:  Ben Williams (Benzini) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Sounds like a fair bit of bad luck there David! Don't be put off by it! I would be checking the fuel pump controller as Dan suggested. Have you tried running the fuel pump on a higher voltage level? If that still doesn't fix it I would then look at the ISC valve or the fuel filter. Adam's suggestion is a good one too.
The fuel pump controller isn't too hard to pull out. Maybe try and find a member who'll help you and swap with there own controller to see if that's the problem.
Sunday, January 01, 2006 - 05:29 pm, by:  Dan McColl (Hoon) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Maybe the miss could be the igniters, but these seem to generally play up when hot.
Ed Fitzgerald
limerick
soarer uzz32
Monday, January 02, 2006 - 02:09 am, by:  Ed Fitzgerald (Fitzy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
i had something similar . try the coil packs.crank angle sensor on mine played up when hot
Richard Baird
Perth, WA
1.3 Litre..!!
Tuesday, January 03, 2006 - 10:14 pm, by:  Richard Baird (Richo) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
The igniters play up when cold too....!!
Marius Hainal
TT manual
Thursday, January 05, 2006 - 11:31 am, by:  Marius Hainal (Torque) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I also have an intermittent bad idle when cold ; are igniters the ones that plug into the spark plugs , the plastic thingies ?
Where would you get those ; and how can you diagnose if that's the fault exactly ?
I also thought the crank angle sensor to play up when hot not cold ...
Marius Hainal
TT manual
Thursday, January 05, 2006 - 11:32 am, by:  Marius Hainal (Torque) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Damn ; didn't realise you guys have V8's not sport cars :-)
Thursday, January 05, 2006 - 01:06 pm, by:  Dan McColl (Hoon) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Don't get me started, I'll give you a run through black spur and we'll see who has the sports car.
The thingoes on top of your plugs are the coils, they have been known to play up on the TT's. I'm not sure where or even if they have igniters. Hopefully someone with a bit more TT knowledge will come along shortly. Good luck.
It could also possibly be the idle control valve. Run a search. :-)
