  Soarer Central * Trim and Interior * Handbreak refurbishing Previous Previous    Next Next
Mal Nicholson
W.A
Reg: 01-2009
Thursday, January 29, 2009 - 12:10 pm, by:  Mal Nicholson (Soarermal) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi everyone. I have been reading up on this a bit but am still unsure how its done. I have seen a few photos of soarers with after market handbreaks ie wood grain, chrome. and I have been told the only way to get it to come off is to cut it them weld a aftermarket handbreak onto the existing leaver. is this really the only way to get it off? has anyone taken theirs off? and how? I am not refering to the handbreak boot, that just slides off. :-)
Mitchell Comfort
Reg: 11-2008
Thursday, January 29, 2009 - 02:05 pm, by:  Mitchell Comfort (Bombercomfort) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi Mate,
If you want to change the colour. You will need to clean it with Prepsol and then use some vinyl paint or dye. I did this with mine and was very happy. Then I changed my mind and went a purchased one of those handbrake covers off ebay. They fit any soarer and looks great on mine. I got a black one.
http://cgi.ebay.com.au/WOOD-GRAIN-LOOK-HANDBRAKE-KNOB-VIP-CEFIRO-929-LEXUS_W0QQitemZ370150667291QQcm dZViewItemQQptZAU_Car_Parts_Accessories?hash=item370150667291&_trksid=p3286.c0.m14&_trkparms=66%3A2% 7C65%3A1%7C39%3A1%7C240%3A1318
or
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=190042691226&ssPageName=MERC_VI_RSCC_Pr4_PcY_B IN_Stores_IT&refitem=370150667291&itemcount=4&refwidgetloc=active_view_item&usedrule1=StoreCatToStor eCat&usedrule2=CrossSell_LogicX&refwidgettype=cross_promot_widget&_trksid=p284.m184&_trkparms=algo%3 DDR%26its%3DS%252BI%252BSS%26itu%3DISS%252BUCI%252BSI%26otn%3D2
They are really cheap and yes fit no worries. Just need some double sided tape to stick it down. Or you can get them from import scene if you want the high end ones.
Thursday, January 29, 2009 - 02:57 pm, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Break or Brake. Spot the difference.
Paul Fitzsimmons
12/96 vvti single
Thursday, January 29, 2009 - 06:08 pm, by:  Paul Fitzsimmons (Oztif) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
You can also make your own.
The rubber under the leather is moulded to the metal below, so it is pretty much a case of destroying it to get it off.
This one I machined out of stainless steel.
Mal Nicholson
W.A
Reg: 01-2009
Thursday, January 29, 2009 - 09:02 pm, by:  Mal Nicholson (Soarermal) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
how did you attach it?
Lawrence Ostle
tt
Reg: 12-2005
Friday, January 30, 2009 - 03:29 pm, by:  Lawrence Ostle (Lawrence) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Picture is a bit small, but I bought this SAAS handbrake cover from Supercheap. I whittled down the factory rubber handle with a Stanley knife until it just fitted over. I slipped the SAAS cover over and used the screws provided to secure it, but glue would have worked too.
Lawrence Ostle
tt
Reg: 12-2005
Friday, January 30, 2009 - 03:35 pm, by:  Lawrence Ostle (Lawrence) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Note: the SAAS cover was originally wood and brushed aluminium, but while the wood was a reasonably close match, the aluminium did not match any other part of the interior, so I covered it with gray pleather. It was around $30 if I recall.
Soarer VVTi
Saturday, January 31, 2009 - 09:49 am, by:  Jose-Antonio Castillo (Ahh_soarer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Nice interior Lawrence, love the steering wheel... where'd you get it?
Michael Bradshaw
TT GT-TL
Reg: 03-2009
Saturday, November 14, 2009 - 08:27 pm, by:  Michael Bradshaw (Bradsm01) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
so, did you end up getting your handbrake off mal?
i'm thinking of retrimming the leather but i'm un sure how to remove it. i can't see any easily accessible screws
cheers
