  Soarer Central * Trim and Interior * Smoke smell Previous Previous    Next Next
Damian Ware
Camry
Friday, May 05, 2006 - 09:40 pm, by:  Damian Ware (Frozenpod) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Can the smoke smell be removed from the interior?
I found a really nice TT except it has a very slight hint of cigarette smoke. I was thinking a steam clean. Will that work, has anyone been able to remove the smoke smell.
Peter Burrett
2.5 VVTi ST
Saturday, May 06, 2006 - 06:52 am, by:  Peter Burrett (Burrett) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Clean the aircon filters thoroughly. You'll probably find them to be filthy. There's a tute on the forum maybe on the ALSC archive
V8 manual
Saturday, May 06, 2006 - 08:50 am, by:  David Vaughan (Davidv) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Check also whether you have an air purifier. If you have, throw away the cartridge and consider replacing it ($155). If your A/C filters are do not come up smelling of Chanel No 5 after cleaning, then replacement cost is $98 a pair. A steam clean of the carpets might then help but you should be OK after doing the filters. My car was truly awful when I got it but filter replacement fixed it and others have the same experience.
Sam Schreck
vvt-i JZZ31
Saturday, May 06, 2006 - 09:24 am, by:  Sam Schreck (Schreck300) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Filters are a must. Once you've got new ones it's a 3 minute job to replace. It will also improve your air-con by 200%.
Damian Ware
Camry
Saturday, May 06, 2006 - 11:45 am, by:  Damian Ware (Frozenpod) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
The current owner has replaced the filters.
The slight smell which remains in mostly in the roof carpet as far as I can tell.
Would a steam clean remove the remaining smell.
If not I will keep looking buy another TT.
Saturday, May 06, 2006 - 12:07 pm, by:  Don Bagnall (Baggs) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Damian,
I would suggest a spray on odour neutraliser type product, such as commercial cleaners use, or you may even find a simmilar product on the supermarket shelf.
But don't use an odour masking type spray, as it will only last short term.
The stinky tobacco smell is usually always in the hood lining & sun visors.
Damian Ware
Camry
Saturday, May 06, 2006 - 01:14 pm, by:  Damian Ware (Frozenpod) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks guys
Decided to give that car a miss as the owner is not happy to have a mechanical inspection.
The information has been very helpful, I'm looking at 3 other soarers tomorrow, hopefully one of them will be what I'm looking for.
Saturday, May 06, 2006 - 03:26 pm, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
For what it's worth, I bought the 2 A/C filters last week from CMI Toyota in Adelaide - $90.00 for the pair.
