  Soarer Central * Suspension * I need help. Previous Previous    Next Next
David Hill
Tuesday, August 21, 2007 - 08:37 pm, by:  David Hill (Davesrave24) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hey all, please help me before I crack the sh..s big time!
I live in Adelaide and I have just put my car in to get the speed sensors and rear left brake line fixed, and they have been. Before I sent the car off I raised the Airbags up, turned the switch off in the boot, and thought that would be fine.
9 days later, I get my car back and fark me if it doesn't look like a dragster. Amusing at first, but I can neither get the rear to drop, or the front to raise.
I have looked through the posts and read the extensive post by Gregg and Mark etc.
What i'm wondering is:
Do I persist with getting the bags fixed?
If I do, who in Adelaide (as close to Gurney's as possible as that is where it is now, and I'm not sure that it can move far in it's current state) could I trust to get them fixed quickly and cheaply?
If not, do I look at converting to springs?
I've got no idea and so many thoughts running through my head, but most of them lead back to frustration.
CAN ANYONE HELP????
Tuesday, August 21, 2007 - 11:48 pm, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
They might not be stuffed. Try pulling a battery terminal off for 15 minutes, then gently going for a drive, it might start working again.
It sounds more like a controller issue with the rears being up. Also, the chance of 2 or more bags failing at the same time is very minimal.
Coming to the Adelaide Soarer Fixit day in September?
David Hill
Wednesday, August 22, 2007 - 06:19 pm, by:  David Hill (Davesrave24) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
When is that???
I'm off to WA on Friday for 2 1/2 weeks for my sisters wedding and then I'm off from work for the 2 weeks after that. So if it's after the 10th, and before the 26th, I'll be there.
I'll give the 15 minutes thing a go. I wen't back to Gurney's today and they said they have no idea what to do to fix it, so I've got it back now. I guess it's now play time.
Thanks for getting back to me,
Dave.
