Wednesday, January 30, 2008 - 01:47 am, by: Brad Penniment(Gaikokujin)
After running through the fuses (rear set gadget fuse blew & playing around under the drivers footwell) it seems that my air suspension is no longer responsive in fact the air pump doesnt even make a noise
What we have tried so far..
Wired up the pump manually, runs! Suspension ECU reset Unplugged the harness for the Aftermarket height control swapping with the original harness! Replaced the fuses & relay Checked the standard Height Controller switch
At the moment im not really sure where to go next except for replacing the suspension ECU? Does anyone know if the Soarer ECU can replace the Celsior ECU? Also interesting is that the dash on the Celsior for the height control flashes "Normal" and is unresponsive to changes in the standard height controller!
If any has a 90 Celsior Suspension ECU for sale, consider it sold!
Wednesday, January 30, 2008 - 05:26 pm, by: Rich O'neil(Kiwiinaus)
Ok try this , switch the suspension switch off in the boot while the engine is running , after that switch car off . Disconnect the earth lead on the battery for 15 mins , after that reconnect the battery , before doing anything else go and set the boot switch to on , when you do this you should hear a noise from the other side of the boot where the valve block and ECU are . [the rear valve block is bottom right side of fuel tank ] . Then start the car up and let it idle for at least 5 mins and see what happens .
