Sunday, November 08, 2009 - 11:39 am, by: Paul Bell(Bello)
Just fitted my diff yesterday and went out today and put about 100ks on it, got home and got underneath to check for leaks etc and i noticed the casing is pretty warm! I can only hold my hand on it for about 3-5 seconds before it gets painful.
I did do my research and put the right oil in, is it normal for torsen diffs to get pretty hot?
cheers
Kevin Trac TryHard 2141.sydney.nsw JZZ30MT, JZZ31AT
Sunday, November 08, 2009 - 02:09 pm, by: Paul Bell(Bello)
i used 80w-140 gl-5/gl-6
Yep its an easy swap, literally unbolt old diff bolt up new one. Only awkward thing is wrestling the new diff into postion. You'll definately be a happy man once you've got it in though
Neil Griffiths Goo Roo NSW I have a Cadillac and a Supercharged Manual V8
Sunday, November 08, 2009 - 10:35 pm, by: James Johnson(Jimbo)
Hmm just put 80w/140 in mine and it is a Torsen from a TT soarer. By the looks of things it has not had the oil replaced before. Neil would you recommend 75/90?
Monday, November 09, 2009 - 09:58 pm, by: Daniel Clarke(Dieseltrain)
IM running 75/90 in a Diff i got from Neil a couple of years ago !!!
Still runs fine . That 140 is too thick and will get too hot fellas.
Oh, Always UNDO the FILL nut before undoing the DRAIN NUT . Some guys have had the Fill nut strip and couldnt open it to fill her up , Always after they drain it !!! Not pleasant,lol .
Friday, December 18, 2009 - 07:25 pm, by: Paul Bell(Bello)
hmmm i think i'm going to go for something thinner then, i only put it in as it says on the container that its best suited for high heat and heavy load applications
Ben Lipman Goo Roo NSW Soarer TT manual, plus TT track car
Saturday, December 19, 2009 - 12:48 pm, by: Ben Lipman(Ben12a)
Kevin Trac wrote on Friday, December 18, 2009 - 06:30 pm:
Is it Okay to run Castrol VMX80 in the Torsen? How many litres will I need?
I have for years. I can't remember exactly how much it was, but I had some left over from a 1L bottle, so maybe 1.5L?
I recorded all the wet capacities when I did a major service a few years back and put them on a laminated card. Unfortunately this is neatly stowed in my glovebox, and I'm nowhere near the car...
