  Soarer Central * Suspension * Tyre size placard Previous Previous    Next Next
Open in new windowArchive through July 27, 2005Steve Millward10
Wednesday, July 27, 2005 - 08:09 am, by:  Peter Nitschke Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Bigger radius rims usually reduces the ride quality a bit as there is less tyre sidewall to absorb the shocks.
Greg Manson
Wednesday, July 27, 2005 - 10:00 am, by:  Greg Manson Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Manny pushing my luck here but you wouldnt have a part number for me to go and order one?
Soarer GT Limited (4.0L V8) and is300 (3.0L il6)
Wednesday, July 27, 2005 - 06:07 pm, by:  David Vaughan Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Greg
For JZZ30 Oct 1992 to Jan 1994 the part is "Plate, Tire Pressure Caution", part number 42661-24101 for the standard plate or 42661-24131 for the optional tyres (225/16). The latter is appropriate to your TT.
1 x JZZ30,2 x UZZ31,1 x UZZ32,1 x UZZ Track Car,1 x AeroCabin,1 x Crown V8,1 x Celsior
Wednesday, July 27, 2005 - 06:22 pm, by:  Neil Griffiths Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
You cant use the Genuine Plate..Must be an Aussie one..
Easiest to ask a RAWS shop for one.
Emanuel Spinola
JZZ30 1.5JZ 6 Speed+++
Wednesday, July 27, 2005 - 08:23 pm, by:  Emanuel Spinola Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
There's a online Russia based Parts Catalogue in English which I've seen Don point to in the past.
The placard I've seen used was from a US/Euro 1993+ JZA80 2JZ-GTE 6 speed Supra - factory 17x8 / 235/45/17 front and 17x9.5 / 255/40/17 rear wheels/tyres.
Wednesday, July 27, 2005 - 09:15 pm, by:  Don Bagnall Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Manny the on-line catalogue is on this site.
If you go "Test Post" area, it's in my post about 3 or 4 down.
Perhaps the url could be moved to the Soarer "useful Info" dept?
Wednesday, July 27, 2005 - 09:38 pm, by:  Don Bagnall Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Correction, I've shifted it to the "Soarer Specifications and Useful Information" section.
Greg Manson
Thursday, July 28, 2005 - 12:42 pm, by:  Greg Manson Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Don and Manny, Thanks again for the info i appreciate it!
Neil, I have tried a couple of RAWS workshops and if they didnt comply the car they dont want to part with one.
Thursday, July 28, 2005 - 06:00 pm, by:  Neil Griffiths Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Greg..Just make one mate...
Find someone car to take a pic of theres..
Then print one out..Laminate it..stick it on.
Easy Peasy :-)
Jan Christiansson
Soarer V8
Thursday, July 28, 2005 - 08:38 pm, by:  Jan Christiansson Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Here you have one.
application/mswordUpload
tyre placard.doc (74.2 k)
Greg Manson
Friday, July 29, 2005 - 02:25 pm, by:  Greg Manson Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks heaps guys i owe you one!
Oki Zoubari
south australia
Reg: 03-2010
Wednesday, April 14, 2010 - 08:59 am, by:  Oki Zoubari (Oki) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hello
On my Soarer Limited V8,
I have 235 45 ZR17 on the rear,
yesterday, I put 2 new 215 45 R17 on the font for the sake of vehicle identity check inspection.
The tire placard on the vehicle was chipped away, so couldn't tell what is the factory recommended tire size.
should I leave it as it is, i.e.
215 45 R17 on front and 235 45 ZR 17 at the rear or should I match the rear by putting 235's at the front.
For the best Soarer performance / experience,Any suggestions for the best tire size on my supposed factory genuine Toyota 17" rims.
thanks
Wednesday, April 14, 2010 - 01:11 pm, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
V8's came with 15" rims.
The 32 and TT came with 16" rims.
No Soarer came with 17" rims.
What you fit would also depend on the size of the wheels, are they all actually the same?
Oki Zoubari
south australia
Reg: 03-2010
Wednesday, April 14, 2010 - 01:39 pm, by:  Oki Zoubari (Oki) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Actually, the seller in his listing quoted
"genuine Toyota 17” wheels"
so I assumed they were the original.
yes, all 4 wheels looks the same to me.
I already have the 235 on the rear.
I possibly could either leave the 215 on the front or put 225 or 235.
mine is the Toyota Soarer/Lexus SC400 GT Limited V8 Coupe.
thank you
Wednesday, April 14, 2010 - 01:53 pm, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yours is a Toyota Soarer model UZZ31 - V8 Limited Coupe if it has air bag suspension.
Lexus SC400 only ever had coil suspension.
Not to mention it was also only ever left hand drive.
Victoria (The Nazi State)
Active V8 and the Beast.
Wednesday, April 14, 2010 - 07:42 pm, by:  Dan McColl (Hoon) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Put 235's all round. Makes it simpler to do tyre rotations if nothing else.
Thursday, April 15, 2010 - 06:22 am, by:  Matthew Sharpe (Madmatt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I use 225 on the front and 245 on the rear.
No particular reason other than it feels a bit nicer turning in with the smaller width on the front.
I run directionals so other than not being able to swap front to back rotation isn't an issue, and my tyres always seem to wear pretty evenly up front anyway.
Ali Saeed
Thursday, April 15, 2010 - 01:02 pm, by:  Ali Saeed (Ali) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
yeh if your suspension set up is good tyre wear shouldnt be much of an issue anyway
Joe Russell
Manawatu
4.0 V8 GT-L (UZZ31)
Reg: 10-2008
Thursday, April 15, 2010 - 02:27 pm, by:  Joe Russell (Joe_r) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Peter Nitschke wrote on Wednesday, April 14, 2010 - 01:11 pm:
Actually Peter weren't BBS RG II's offered as an option from factory?
Thursday, April 15, 2010 - 03:50 pm, by:  Dan McColl (Hoon) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
In a 16".
Christian Somerville
UZZ31 V8 LTD
Reg: 03-2009
Wednesday, April 21, 2010 - 09:52 pm, by:  Christian Somerville (Csomers) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
So putting 18s on my car is illegal? Stupid government.
I thought V8 rims were 16s!
Ali Saeed
Thursday, April 22, 2010 - 02:07 am, by:  Ali Saeed (Ali) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
no its not illegal, as long as you have correct tire sizes
Relaxed
IS300
Thursday, April 22, 2010 - 09:51 am, by:  David Vaughan (Davidv) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
There are laws about changing offset, width and total (wheel+tyre) circumference. There are no laws about wheel size provided the tyre size changes to keep total circumference more or less the same.
The principal illegality I see committed by forum members is in the offset, although it is only a subset of the follies.
