  Soarer Central * Celsior Chat * Suspension contoller wanted Previous Previous    Next Next
Glen Lomman
south australia
celsior
Saturday, September 20, 2008 - 01:54 pm, by:  Glen Lomman (Pimp20z) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
hi all as the title says i want to purchase a suspension controller but dont know where to look or start. how much would a cheap one be and where from any help would be appreciated thanx.
Glen Lomman
south australia
celsior
Saturday, September 20, 2008 - 02:01 pm, by:  Glen Lomman (Pimp20z) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
it a 1990 model celsior i forgot to mention that
David Barnes
Celsior V8
Reg: 06-2008
Saturday, September 20, 2008 - 03:02 pm, by:  David Barnes (Toyota_celsior) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Depends if you want one new or 2nd hand. Brand new your look at around 450bucks, They pop up all the time tho for much less 2nd hand. My mate had one up forsale for 300 but not sure if he still has it. I can find out for you if you wish.
Send me an email.
toyota_celsior@inbox.com
Chris Lock
sa
Reg: 03-2008
Saturday, September 20, 2008 - 05:19 pm, by:  Chris Lock (Sledge) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I've been told they ruin the bushes though... so be careful
Ryan Posselt
Celsior V8
Reg: 08-2006
Saturday, September 20, 2008 - 07:00 pm, by:  Ryan Posselt (Yakusaryan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I'm after the same thing.... posibility of a group buy perhaps :-)
Saturday, September 20, 2008 - 07:33 pm, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Chris Lock wrote on Saturday, September 20, 2008 - 05:19 pm:
The trick is, pick your most used ride height, then get the control arm bushes released and re-tightened along with a 4-wheel alignment. That will have the bushes centred at your desired height and reduce the twisting stress on them.
If you don't and then eg drive with the car dumped all the time, then even when standing still the bushes are being stressed badly, then more so when you go over bumps.
Rich O'neil
90 Celsior
Reg: 05-2006
Sunday, September 21, 2008 - 08:19 am, by:  Rich O'neil (Kiwiinaus) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
The suspension controller I have is one of the older type , I like as it gives you 3 pre-sets plus individual control as well , best of all though is it has a TEMS switch on it which can harden it up again over the sport mode , very handy !!
They can be had for a bit less than the later models and in my opinion they are better .
Have sourced two of these for mates so far .
Andrew Smith
vic
v8
Sunday, September 21, 2008 - 11:03 am, by:  Andrew Smith (Bt1323) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
i've got one with 2 pre sets pm me and we can arrange something
David Goldthorpe
UZZ31 GT-L
Reg: 11-2007
Wednesday, September 24, 2008 - 10:00 pm, by:  David Goldthorpe (Sprocket82) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I'll be converting from airbags to springs within the next month and putting my height controller up for sale if your not in a hurry Glen (or Ryan). Its a DataSystems ASG-63x:
http://www.r-spec.com/electronics/asg/asg.html
I would assume it is compatible with the Celsior as well.
Ryan Posselt
Celsior V8
Reg: 08-2006
Wednesday, September 24, 2008 - 10:28 pm, by:  Ryan Posselt (Yakusaryan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Anyone know if these are actually compatible??
David Barnes
Celsior V8
Reg: 06-2008
Thursday, September 25, 2008 - 07:07 am, by:  David Barnes (Toyota_celsior) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
They are, but the wiring harness isnt. Why don't you just lower the car yourself with out the height controller by adjusting the height sensors.
Glen Lomman
south australia
celsior
Tuesday, September 30, 2008 - 07:00 pm, by:  Glen Lomman (Pimp20z) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
David Barnes wrote on Thursday, September 25, 2008 - 07:07 am:
i tried adjusting mine once before and it did nothing. any idea why nothing happened i put the back and fronts exactly the same to the millimetre but still nothing changed. the suspension controller is my last resort
Ryan Posselt
Celsior V8
Reg: 08-2006
Thursday, October 02, 2008 - 06:13 pm, by:  Ryan Posselt (Yakusaryan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hey do you reckon a second hand controller for $180 is a bargain??
David Barnes
Celsior V8
Reg: 06-2008
Friday, October 03, 2008 - 07:18 am, by:  David Barnes (Toyota_celsior) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yes and no,
Depends on the model.
Ive seen them go for less then $50 on ebay many times.
Rich O'neil
90 Celsior
Reg: 05-2006
Sunday, October 05, 2008 - 08:37 am, by:  Rich O'neil (Kiwiinaus) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Glen i can get you an air controller in , there's one for sale at the moment with the TEMS extra hardness and 3 preset plus individual adjustment setting and with freight would be around the $200.00 mark .
Ryan Posselt
Celsior V8
Reg: 08-2006
Sunday, October 05, 2008 - 09:45 pm, by:  Ryan Posselt (Yakusaryan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi all!
Does anyone know anything about a data systems AST 517? does this unit have the TEMS switch? what are its other functions? I can get this unit for $200 including shipping from SA to Sydney. What do you lot think???
David Cassells
TT Soarer \ V8 Celsior
Friday, November 07, 2008 - 09:50 am, by:  David Cassells (Davetoyostar) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I have tried almost every model of air controllers in my celsior, the best ones of the Data Systems ones are the new models (normally able to tell as the covers are silver) if there black they are the older models and don't have all the functions as the newer ones do.
Another good brand which you don't see much which I am currently using is a Field Controller.
Glen Lomman
south australia
celsior
Wednesday, November 26, 2008 - 05:16 pm, by:  Glen Lomman (Pimp20z) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Rich O'neil wrote on Sunday, October 05, 2008 - 08:37 am:
just wondering rich or anyone else if you can still get hold of a controller i want one asap
Robert Timson
Celsior
Reg: 05-2008
Thursday, November 27, 2008 - 06:04 pm, by:  Robert Timson (Rjet) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi Glen, I have the same controller as Rich (refer above post) with the TEMS extra hard mode and the 3 presets. I will part with this controller for $250 (delivered) as i am looking to buy a controller with the speed presets ie car will vary height based on speed. This controller fits '89 - 92 (early year) models. With our dollar unfortunatly all gear from Japan is costing about 60% more than 4 months ago. I can send pics if you like. regards Robert
Ryan Posselt
Celsior V8
Reg: 08-2006
Thursday, November 27, 2008 - 10:13 pm, by:  Ryan Posselt (Yakusaryan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Rob,
Where do you get all these parts from!? dead set you a veritable spare parts shop for celsiors!
So welcome to the forum!
Tuesday, December 09, 2008 - 08:00 pm, by:  Daniel Lee (Son_gokou) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Guys,
I have R Spec Height Controller for sale too.
Simple plug and play, 3 programmable heights from a selection of 16, speed sensitive setting & Super Low Mode!
http://soarercentral.com/sc-forum/messages/292/272447.html?1228794880
But does anyone know this controller can fit in a 90 Celsior?
Cheers!!
Simon Martin
1UZ MX73 Cressida 5spd
Reg: 06-2007
Monday, December 15, 2008 - 10:31 am, by:  Simon Martin (Commander) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I would say it will most likely be a different wiring harness, but I'm not 100% sure.
and aftermarket controllers beat the hell out of using factory button + lowering height sensors. Cause if you wanna jack it right up you can with a height controller. Very handy for roadside repairs, when you need to get under the car without a jack :-). Only had to do it once, but boy was it handy ;)
Robert Timson
Celsior
Reg: 05-2008
Tuesday, December 16, 2008 - 07:02 pm, by:  Robert Timson (Rjet) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hey guys, I am selling 3 controllers on ebay. Possible early Christmas present.
Mark Tierney
Soarer GTT, Celsior, Ducati
Sunday, October 04, 2009 - 11:48 am, by:  Mark Tierney (Mark_t) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I have a Data System AS165X RSpec height controller that I purchased from Ali Yazici a few months ago. I changed to coilovers just after buying, so I never installed it. (Thanks anyway Ali)
Sales price is $140. Comes with harness. Ali said it came from guy that had it working in his 1990 Celsior. Pm me for bank details. No dibs, goes to first person who deposits.
Ryan Posselt
Celsior V8
Reg: 08-2006
Tuesday, October 06, 2009 - 11:46 am, by:  Ryan Posselt (Yakusaryan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Check ebay mine is ending soon - was only $49 last time I checked :-)
Luke Gomer
Dorset
Uzz31 LTD
Tuesday, October 06, 2009 - 08:07 pm, by:  Luke Gomer (Luke) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I have one for sale too
http://jkwebdesign.net/lsocbb/viewtopic.php?t=8142
Robert Timson
Celsior
Reg: 05-2008
Saturday, October 10, 2009 - 07:22 pm, by:  Robert Timson (Rjet) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=120476736491&ssPageName=STRK:MESELX:IT
High spec unit
Ryan Posselt
Celsior V8
Reg: 08-2006
Wednesday, October 14, 2009 - 03:31 pm, by:  Ryan Posselt (Yakusaryan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Mine sold on ebay for $55. i don't think they're fetching as much as they used to. Less Celsior's on the road blah blah blah :-(
