Saturday, July 10, 2010 - 09:06 pm, by: Joshua Baldwin(Celsior101)
over the past couple of days i've been losing power in my car when driving around town dash lights go dim. waring lights appear in dash once i put the foot back down the lights go bright and its back to normal. (these warning lights are obviously appearing due to power loss to module, sensor etc) what i mean by driving around town is that it happens when i slow down for traffic, red light etc and there is not much load on the engine.
i drove on the freeway yesterday and it was fine because i was at a constant speed and wasn't stop/starting etc
to me it sounds like a alternator/battery problem. what are your thoughts? note: its not just the dash that loses power its a range of things from ac unit lcd back-light going dim and head-unit turning on and off.
Saturday, July 10, 2010 - 10:15 pm, by: James Harris(Haro)
Yup alternator or battery problem, that would be my bet.
Check your battery terminals are clean and secure. Could also be your alternator dying (hopefully not though)
I recently changed my alternator on my Starlet after having the same issues. I considered getting my one rebuilt for a few hundred but then just pulled a similar one off another Toyota from the wreckers and installed that. Works a charm and i only paid 30 bucks!
I know HEAPS of parts are interchangable with Toyotas so i would be pulling it off and then comparing a few if you run into dramas finding one... but plenty of soarers being wrecked also and they may fit?
Sunday, July 11, 2010 - 09:50 am, by: Joshua Baldwin(Celsior101)
thanks for your post James. yeah im hoping its not the alternator dying but i have this sad feeling that it is. and yes there are lots of 1uz soarers been parted out so i should be able to find a replacement alternator without much trouble (hopefully) if need be. i will check the battery terminals today and will let you know how i go. also the battery needed for the celsior is the same size as what would fit into a 4wd (larger car) im guessing because of all the electrics it has. i at the moment only have a regular size battery in the celsior at the moment its been in there for a year now its been working fine but could this also be the problem?
Wednesday, August 18, 2010 - 07:47 pm, by: Craig Webber(Soarr)
I'll put money on it that it's the alternator. Had the same ting happen to the wife. Change the battery all was fine for a short time, then bang all the light's went out. Long way from home and in the middle of no where. Get look it to before you get stuck.Trust Me
