  Soarer Central * Mechanical - TT * Turbo Talk Previous Previous    Next Next
Open in new windowFactory manual overboostingChris Koszo
Open in new windowCt12 rebuild helpChristopher Hosking
Open in new windowCt20s kit for 1j soarer.Kurt Atzmuller38
Open in new windowStarting my compound turbo setup!Kurt Atzmuller91
Open in new windowTwin ct20's custom projectKurt Atzmuller13
Open in new windowAir leakDarren Bak
Open in new windowForward Facing Rear CT12ACasey Perkins17
Open in new windowTurbo wheel dimensions comparison.Tai Johnsen
Open in new windowTurbo max psiScott Vim16
Open in new windowVvti turbo oil leakScott Vim
Open in new windowHey guys who do you think like of this?? Air intake??Boris Siljanoski
Open in new windowVVti turbo on its way out?? Peter Nitschke
Open in new window1JZ Cast Iron Single Turbo ManifoldCamron Garcia
Open in new windowAir whoosh when turbo kicks in - limited boost. Help please.Nathan Sopeer
Open in new windowLol could this be real?Scott Vim
Open in new windowInternal or external waste gateCasey Perkins
Open in new windowPossible dump pipe ManufacturerJeff Bedsor118
Open in new windowNeed help installing blitz turbo timerCrystal Moss
Open in new windowSingle turbo question, ECUBoris Siljanoski13
Open in new windowMy TT's engine is running very flat but no smoke. Could it still be...Trevor Marsh11
Open in new windowTurbo setups for 1.5j...Kurt Atzmuller39
Open in new windowCT12B's on a 1JZBlake Gloyn10
Open in new windowMore powerTai Johnsen
Open in new windowHyperGears billet SS2 Roller bearing VNT turbochargerTao Shangguan26
Open in new windowExternal Wastegate Fluctuating Open EarlyKurt Atzmuller17
Open in new windowDon't askMatt Newman
Open in new windowNot sure on what size wastegate to useJay Asghari
Open in new windowSpool IssueGlenn Munro
Open in new windowTurbo on its way outDaniel Clarke
Open in new windowWhats really wrong with the GTX3076R?Ali Saeed25
Open in new windowFuel cut defender Zac Clare
Open in new windowCracked CT12a Turbo Housing???Glenn Munro
Open in new windowAftermark Oil Feed / Return kitsWalter Gillmore
Open in new windowManual boost controller questionZac Clare11
Open in new windowSome Single Turbo Help!Ezekiel Vozzo18
Open in new windowOnly 5 psi stock ttAdam Day10
Open in new windowDD turbochargersRoss Pesina
Open in new windowFirst upgrade? G-Force IIEthan Rodda
Open in new windowHELP coolant lines on turbo sidePeter Nitschke
Open in new window1.5j t3gs with gt2860rs cores resultsTony Nguyen18
Open in new windowBest single turbo for 300 - 350 rwkwJames Tims55
Open in new windowStock Ct12a's, 16psi, stock injectors/pump, FCD, SAFC 2, recipe for...Boris Siljanoski
Open in new windowSingle turbo kitTai Johnsen
Open in new windowWater lines feed and returnJohnny Brasche
Open in new windowGoing to up my boost soonRobert Day17
Open in new windowPrecison 6262 Dyno resultsRobbie Rashleigh17
Open in new windowCT12a 1JZGTE High flow. Bit fancier then just steel wheel. Tao Shangguan
Open in new windowStock BOVWeisong Zhang23
Open in new windowNotice turbo questionJulian Mazur12
Open in new windowRebuilt turbos?Jamie Deakin
Open in new windowOnce Again! Turbo replacementDaniel Clarke16
Open in new windowStill over boostingMatthew Weaver
Open in new windowBOV question/helpDaniel Clarke
Open in new windowBaided turbo coolant lines?Layton Molenaar
Open in new windowASK CIHAN : build tipsBlake Gloyn31
Open in new windowGT3582r worth it on the 1jz?Daniel Clarke28
Open in new windowCt12a rebuild time need infoDaniel Clarke
Open in new windowBoosting issuesMatthew Weaver
Open in new windowTurbo help neededSanjeewa Jayasekara16
Open in new windowBudget single turbo conversionMichael Sinay26
Open in new windowT3G rebuild options / questionsSebastian Grant28
Open in new windowE85 / LPG 1jz TO4Z buildAllan Langford28
Open in new windowGreddy Profec B Spec 2 - Not Holding Boost at any levelJames Tims18
Open in new windowTurbo smart fuel cut defender 2Blake Gloyn
Open in new windowHelp turbo highflow optionsDaniel Clarke
Open in new windowIn need of a hi-flow service in Geelong/MelbourneAlistair David
Open in new windowFront mount intercoolerJames Buchan10
Open in new windowTurbo Rebuild Mechanic Melbourne RecommendationsJay Asghari18
Open in new windowNoisy turboJosh Barnes
Open in new windowSmoke at idle after boostingDaniel Clarke
Open in new windowBoost, How much can 1jz handle?Enzo Seidl24
Open in new windowCT15b replacementJacob Thomas
Open in new windowT3/T4 T04E TURBOCHARGER 480HP T3 TURBO only $204 Brand New???James Tims
Open in new windowTuning Greddy Spec 2 Profec B for stock turbosJames Tims18
Open in new windowBlown turbo or something elseRobbie Rashleigh19
Open in new windowWhole bunch of questions.....Kurt Atzmuller11
Open in new windowPossible to disable turboBoris Siljanoski19
Open in new windowWhat should I do to get turbo sound louder/longer?Kurt Atzmuller17
Open in new windowStock SetupBoris Siljanoski
Open in new windowBest Turbo upgrade for the 1jz-gteJohnny Brasche46
Open in new windowSingle hidden turbo...is it possible?James Tims21
Open in new windowWeird turbo sound...turbo flutter...Fabian Bordon10
Open in new windowOil return lineDaniel Clarke
Open in new windowJZZ30 Intercooler kit?Enzo Seidl
Open in new windowVery weird turbo problems.Jack Lloyd
Open in new windowTurbos very noisy - car safe to drive on highway?Dan McColl
Open in new windowGTX3576R Tai Johnsen
Open in new windowTwin turbo manifoldsDavid Watt34
Open in new windowSingle water feed linesDaniel Locke
Open in new windowTurbo sound, Need Help!James Buchan27
Open in new windowDump pipe overboostingJeff Bedsor
Open in new windowSingle turbo recommendations?Aaron Mead
Open in new windowT-58 QuestionsEzekiel Vozzo
Open in new windowGood time to set turbo timerJames Tims24
Open in new windowNeed some parts identified under the bonnet, also how to connect st...Alistair Moorby
Open in new windowTurbos need replacing - what are my options?Matt Sartori
Open in new windowCan I run two devices off the same vacuum line?Aiden Cheese
Open in new windowHELP - Which turbo GTX 3076 or GTX 3540 - both with 0.63 rear housingsTai Johnsen24
Open in new windowBoost Controller Problem - Solenoid or Main UnitHakan Pasha
Open in new windowTURBOSMART SOARER TT 1JZ BOV BLANKING KIT AVAILABLE NOW!Matthew Smith40
Open in new windowStock Return LinesGary Poloskei
Open in new windowHigh flowed steelies from 1JZ onto 2jzDaniel Clarke
Open in new windowShell V-Power FuelTai Johnsen33
Open in new windowTurbo/wastegate/boost controller setup correctly? Seems to be stuck...Luke Tongs
Open in new windowCeramic or Steel Wheel Turbo's?James Tims
Open in new windowNot making boostDaniel Renahan24
Open in new windowGarrett GT3788R opinions??Daniel Clarke
Open in new windowPopping noise?Daniel Clarke
Open in new windowCT12A Compressor side lock nutGary Poloskei
Open in new windowReplacing tt for single does this look safe?Veronica Mead14
Open in new windowHi flow, steel wheel CT12a questionJames Tims25
Open in new windowBoost Gauge Install - Please helpDarren Bauer31
Open in new windowWeird Boost IssueHakan Pasha14
Open in new windowSteel wheel or single? opinions..?Luang Thokbuom44
Open in new windowEbay intercoolerDavid Grima
Open in new windowHow to read a Compressor Map + Conversion TableTai Johnsen
Open in new windowStock turbos, harsh rattle under boost ??Robbie Rashleigh29
Open in new windowGizzmo helpHakan Pasha10
Open in new windowFront or back oil feed for single turbo, does it matter?Matthew Weaver
Open in new windowCT12A GasketsMatthew Weaver
Open in new windowAlright guys. Its $$$ TimeMark Pattel 10
Open in new windowAnother blown turbo post.Matthew Hamono
Open in new windowStock Soarer defected for white smoke, thinking turbo seals.Chris Lock17
Open in new windowTurbo Smart FCDChristian Perez
Open in new windowT04Z with 0.68AR responseChris Papadopoulos
Open in new window1JZ GT35R single turbo kit for $2300 landed from USAAaron Mead
Open in new windowCracked Back Housing (Single) - Take a lookCamron Garcia
Open in new windowOVER BOOST!Walter Gillmore41
Open in new windowStock 2jz turbo'sWalter Gillmore
Open in new window1JZ aftermarket BOV and adapter kit ?? suggestions ??Tai Johnsen19
Open in new windowBOV AdaptorWalter Gillmore
Open in new windowThis is new type of CT12A setup Walter Gillmore19
Open in new windowBlack Smoke?Justin Hughes
Open in new windowGt3271?Chris Milner
Open in new window1JZ sounds like a tractor... exhaust leak ??Justin Prewett
Open in new windowWhich is the better option??James Wilson28
Open in new windowWhat RPM should my standard 1991 TT soarer hit full boostYang Luo11
Open in new windowWhat do I need for a single turboRoss Pesina41
Open in new windowHelp to id a turboWalter Gillmore28
Open in new windowHelp!! turbo Ross Pesina11
Open in new windowGT35R & Internal wastegateRoss Pesina
Open in new windowWhich GT3076R?Brett Harrison12
Open in new windowSard R2D2 problemRichard West
Open in new windowWastegateBrett Harrison
Open in new windowLeaking coolant lineJohn O'Brien
Open in new windowAny one's interested to get their CT15B turbo high flowed at half p...Chris Nguyen12
Open in new windowIntercooler pipesWalter Gillmore
Open in new windowTurbo side part numbersLayton Molenaar
Open in new windowAre these the good dumps?Daniel Salt
Open in new windowWould 17psi hurtMatthew Weaver12
Open in new windowWhat is this pipe and where does it connect to?Nick Okeeffe12
Open in new windowGT 3076R ?Austen Menze55
Open in new windowLews dump piupe gasketsDaniel Clarke
Open in new windowTurbo spooling problemMatthew Hamono
Open in new windowUrgent Turbo Question!!!!Matt Sartori
Open in new windowNew CT12A'sCosta Tsimiklis107
Open in new windowMy Single Turbo Soarer - VidsEvan Nguyen
Open in new windowPicture Request - Black Turbo Piping.David Barnes
Open in new windowTurbo Vibration / Upgrade / QuestionCosta Tsimiklis14
Open in new windowTwin tdo6Matthew Sharpe58
Open in new windowThought I'd share this interesting pageAaron deVisser
Open in new windowсt12b On 1jz-gte TTAlex Krasnikov
Open in new windowFound some brand new genuine CT12A'sAlex Krasnikov29
Open in new windowNew soarer owner, Modified with some problems help needed Costa Tsimiklis
Open in new windowAre my turbos buggered?Walter Gillmore25
Open in new windowTurbo upgradeHarley Jones11
Open in new windowKnow of an adaptor to fit an aftermarket Bov to stock position ??David Duffell
Open in new windowForced upgrade time. help!Aiden Cheese16
Open in new windowNeeding advice on upgrading...Rob Rojo42
Open in new windowExternal wastegate selection help!Costa Tsimiklis
Open in new windowCheapest bang for buck mod!Gary Poloskei
Open in new windowCt12 with Garret Centre needing oil line info etcLew Radbourn24
Open in new windowHow to go singleMatthew Weaver
Open in new windowTurbo housing to exhaust manifold gasketScott Wilkes18
Open in new windowSmoke from exhaust. Was told turbo seals gone.Matthew Weaver
Open in new windowVids of my supra (NAUUGGHHTTT)Chris Prak
Open in new windowTurbo specs - rough ideaDavid Tra
Open in new windowIs running boost controller safe on stock turbo?Shadi Sabbagh25
Open in new windowFlutterLayton Molenaar19
Open in new windowGREDDY T78Aaron Casey47
Open in new windowNew TurboJeff Bedsor18
Open in new windowSingle turbo adviceMark Bryant
Open in new windowBoost Boost BoostEvan Kaio
Open in new windowCT15b UpgradeBrett Callaughan
Open in new window1JZ modification guideJames Wilson34
Open in new windowWill i hit boost cutIan Clifford46
Open in new windowCT15b highflow/rebuildDavid Tra25
Open in new windowHaltech Platinum 1000 PnP 1JZ-VVTICihan Aday
Open in new windowToyota Soarer 1jzgte TT to singe using Std Turbo Manifolds - EbayJeff Bedsor15
Open in new windowProblems with overboosting!Scott Wilkes15
Open in new windowHelp with oil line length for single conversionSpencer Cameron
Open in new windowGatting turbos checked out James Wilson
Open in new windowNeed help removing lews dump pipesDavid Wojcik
Open in new windowBoost issuesJeff Smith
Open in new windowShuddering when backing off accel.Rob Rojo
Open in new windowStarted the removal..James Wilson20
Open in new windowTurning off when boostingCihan Aday29
Open in new windowHigh flows & head workNathan Hlad
Open in new windowAdj Cam gear settingsLayton Molenaar12
Open in new windowGetting a gt35Costa Tsimiklis
Open in new windowWhich turbo is this?David Tra
Open in new windowMs-Ibc barely increase boostMarc Hoffmann
Open in new windowAlternative turbo upgradesChris Milner13
Open in new windowBoost GaugeAaron Mead10
Open in new windowMy turbos sound bad =[Natasha D'Abreo10
Open in new windowDo I need an E-Boost??Sari Rabadfi
Open in new windowGOING SINGLEAaron Mead
Open in new windowKilled my TurboRhys Salmon
Open in new windowOver boostingMarc Hoffmann
Open in new windowHelp - With my BOOST leakShane Van Ross14
Open in new window9psi feels same as 15.5Austen Menze18
Open in new windowSingle conversionJeff Smith
Open in new windowHks t3g heat shieldSebastian Grant23
Open in new windowBang bang antilag questionAusten Menze28
Open in new windowIssue raising boost Scott Wilkes13
Open in new windowRemoved BOV gave me a huge increase in power!Ryan McDonough
Open in new windowOIl in turbo'sElizabeth Hogan
Open in new windowSpare Turbos, Compressor WheelTy Mackay18
Open in new windowWhat are these markings on my turbo?Austen Menze
Open in new windowIs going single, street legal...Lew Radbourn17
Open in new windowHybrid HKS T3G'sAntonio Hunt15
Open in new windowGoing well and then it all went horribly wrongSebastian Grant57
Open in new windowChanging Stock TT Turbos - VF8 TurbosBoris Siljanoski16
Open in new windowIncabin boost controllerChristian Perez
Open in new windowCt12a Replacement questionRob Rojo
Open in new windowLets Talk external wastegatesChris Driver
Open in new windowSurely this isnt normal?Jeff Bedsor
Open in new windowManual Boost ControllerJames Harris
Open in new windowLooking to go single turbo Asmat Saleem16
Open in new windowCleaning out actuatorsScott Wilkes
Open in new windowVVTI 1JZ TURBO BOOST CONTROLLERAndrew Stewart
Open in new windowScreamer block plateScott Wilkes
Open in new windowEBay Boost ControllerSupadej Akrawichien22
Open in new windowAre my turbos leaking or just f<<kedJames Wilson
Open in new windowStandard TurbosNicolas Andrushenko
Open in new windowVacuum LinesMichael Keen10
Open in new windowOil drain/feed lines?James Wilson
Open in new windowHelp with Blitz ID3 not holding constant boostAusten Menze
Open in new windowTurbo mount bolts hard to get to placesMarc Hoffmann11
Open in new windowCan the stock ECU run a BOOST Controller?Sari Rabadfi14
Open in new windowFuel Cut Debate - Simple Fix WantedRob Rojo22
Open in new windowTurbo removalScott Wilkes
Open in new windowWill it fit?David Grab
Open in new windowHow much boost with my T3/T4?Tim Hutchings
Open in new windowRaise that boost!Walter Gillmore
Open in new windowRegarding Trefs smoking turbos.......Scott Wilkes
Open in new windowAnyone got the AEM Wideband?Austen Menze
Open in new windowStrange Boosting Problem.Dale Holan25
Open in new windowDisconnect turbos?David Barnes25
Open in new windowSingle Turbo Manifold Adapters....Daniel Clarke15
Open in new windowLoosing boost bad...Sebastian Michalski36
Open in new windowGT3582R .63 exhust housingGrant Rowan75
Open in new windowMy New SingleRob Rojo35
Open in new windowMax boost...stock turbosHarley Jones74
Open in new windowHelp/AdviceChris Prak13
Open in new windowEBC Solenoid mountingScott Wilkes
Open in new windowFitting ct20'sScott Wilkes
Open in new windowGt3582 + 6boost manifold 1jzGary Poloskei34
Open in new windowRemoving the turbos from a 1J - any how-to's or special tools neede...Daniel Clarke41
Open in new window1JZ EXTERNAL GATE INSTALLATIONAaron Casey
Open in new windowLower boost. And best place to get GT35R turbo?Aaron Casey
Open in new window2jz with gt3076r??Aaron Casey10
Open in new windowWhat's this on my turbos???Sebastian Grant
Open in new windowSteel wheelCihan Aday30
Open in new windowWhat's a great twin setupBobby Green
Open in new windowUpgraded Turbo Problem.Cameron Laufer22
Open in new windowGizzmo MS-IBC help. Duty settings.Dale Holan
Open in new windowSingle Turbo HelpDaniel Clarke35
Open in new windowLe sigh... coolant in the pipesWalter Gillmore25
Open in new windowHKS T3G SETUP COMPLETE.. + couple questions :-)...Mark Tierney59
Open in new windowGIZZMO EBCDale Holan21
Open in new windowSAFC II reduces boost cut? Is it true?Dennis Weglehner50
Open in new windowFound a way to get usdm supra turbos on a soarer....Robert Day15
Open in new windowOpinions on which turbo?Michael Keen53
Open in new windowTurbonetics turbo kitDavid Key
Open in new windowSoooo im going to put these onCharlie Ters
Open in new windowAnother 'Whats This' Pic.Michael Liang
Open in new windowReplacement for CT12AJames Harris
Open in new windowHow much to...Michael Lucas
Open in new windowHow to inspect CT12a turbos?Scott Wilkes
Open in new windowWTB Single turbo 1jz ManifoldDave Cazes
Open in new windowGizzmo IBCCihan Aday
Open in new windowGT35R rebuild?Daniel Clarke12
Open in new windowFlooded TurboMichael Keen
Open in new windowCt15 turbo?Andrew Stewart27
Open in new windowTR43 HYPERGEAR TURBOTao Shangguan34
Open in new windowMy fun morningTy Mackay12
Open in new windowTurbo issues? Black smoke.Ty Mackay12
Open in new windowAmerican Steel Wheel 1jz TurbosCosta Tsimiklis
Open in new windowGizzmo ms ibc help!Ryan Rankovic
Open in new windowHeat management- manifold very close to compressor outletGeorge Funa
Open in new windowUp the boostManual Kalianis53
Open in new windowPinging Engine. Blake Gloyn
Open in new windowFloating V's Bearing?Andrew Stewart10
Open in new windowTurbo Help: looks like Led balancing weights have been exposedGrant Rowan36
Open in new windowTurbos not spooling!Tim Hutchings32
Open in new windowChinese turbos??Lionel Trotea
Open in new windowBoost Pressure?Ben Lipman
Open in new windowJAYCAR fuel cut defender... WA PEOPLEMatthew Standage
Open in new windowPlumbing up external gate.David Tra11
Open in new windowWhistling Noise, Not blown turbos??Joel King31
Open in new windowWastegate ActuatorsJeff Bedsor
Open in new windowCT12A from JapanKyle Wathen22
Open in new windowTurbo oil feed studs / nutsDaniel Treadwell
Open in new windowStock turbo manifold upgrade questionMaurice Diggler
Open in new windowBudget turbo kitGary Poloskei11
Open in new windowI'm going SINGLE!!! Some advice needed please :-)...Mal Nicholson43
Open in new windowCT20'sMal Nicholson
Open in new windowI'm new to turbos, somewhere I can learn more?Kane Chan11
Open in new windowHow do you identify Chinese Copy CT12a'sCameron Laufer12
Open in new windowCT12A Oil Leak. Need adviceJoel King13
Open in new window1uzfe turbo setup, what do i need?/to know (lots of questions ;)...Robert Day
Open in new windowTurbo problems?...Christian Molenda
Open in new windowSingle turbo conversion Need info please!!!Nathan Sheehan11
Open in new windowGizzmo MS-IBCJames Harris
Open in new windowReplacing/ changing boost GaugeJames Harris
Open in new windowIs my turbo gone!!!Cameron Laufer12
Open in new windowTurbo - I think im losing boost???...Tim Hutchings12
Open in new windowHelp me in choosing the right boost controller. Please.Luke Streat19
Open in new windowIs my turbo cactus?Luke Streat21
Open in new windowHeads up on FCD/EBC/ECU options/benefitsDaniel Burns17
Open in new windowBoost Controller AdviceMike Dobkin
Open in new windowSingle Turbo coming, last minute advice?Rob Rojo10
Open in new windowTurbo TroubleTim Hutchings14
Open in new windowIndividual intakes for each turbo?Daniel Clarke29
Open in new windowDO I NEED TO REPLACE OIL FEED FOR TURBO?Ben Socratous12
Open in new windowBoost levelBrian Kelly
Open in new windowT4 turboGarth Williams
Open in new windowHypergear TR44HF tuning impressionsTao Shangguan131
Open in new windowEBC TroubleMike Dobkin
Open in new windowTurbo sizing advice on a 2JZDanny Dinh
Open in new windowLoud spooling noiseBarry Main16
Open in new windowName this dump pipe?Steven Nanevski27
Open in new windowWANTING TO UPGRADE TWINS WITH TWINSSteven Nanevski
Open in new windowInstalling a boost controller - Instructions for noobsDanny Dinh11
Open in new windowGt30/40r with a hks t25 rearLew Radbourn23
Open in new windowWhat is Boost Cut?Chris Prak
Open in new windowOil water linesBen Socratous
Open in new windowStock ecu, no FCD able to run 20psiCihan Aday
Open in new windowCA12 turbo help????Scott Wilkes18
Open in new windowDump valve open at 2400 then the noise from the turbo...... Brett Harris
Open in new windowGready T67 Single turbo kitJason Jon
Open in new windowStrange thing has got me puzzledCameron Laufer
Open in new windowGt30\40 1.06? v's .82Cameron Laufer18
Open in new windowEbay purchase advice pleaseDaniel Clarke
Open in new windowSteel Wheel Turbos?Brett Harris
Open in new windowTurbos loud on cold startAndrew Magee
Open in new windowGizzmo MS - IBCCihan Aday10
Open in new windowRefitting rebuilt turbos, need advice.Don Bagnall21
Open in new windowGFB Mach 1 AdaptorScott Gates
Open in new windowExperience or advice on which electronic boost controller to get?Shaz Pervez14
Open in new windowTurbo problemsEdward Salem14
Open in new windowReccommended boost for my carTony Nguyen
Open in new windowAre turbos meant to rattle? or is it something else? :-(...Dixon Won14
Open in new windowPlease help a fellow out (turbo talk)Simba Jon34
Open in new windowStock BOV questionSteven Roduner
Open in new windowSingle Turbo = $$$, maybe not?Cameron Stanley23
Open in new windowSingle Turbo Kits? Or purchase items separate?Michael Keen30
Open in new windowFuel cut defenderDanny Dinh12
Open in new windowAre HKS EVC boost controllers any good? Mario Jayawardena
Open in new windowAnother 'cheap' Hypergear conversion.....or is it?....Maurice Diggler164
Open in new windowTurbo / Manifold weight / dimensions for postage...Charlie Ters
Open in new windowStock turbo replacementsJames Cahir
Open in new windowCT12a GT28 Roller bearing TurbosJames Johnson46
Open in new windowInstalling ssqv Mario Jayawardena
Open in new windowExternal wastegate queryDavid Tra10
Open in new windowTURBO HELP PLS ON SPECS Karim Tabbouch
Open in new windowHDI Super Electronic Boost ControllerSebastian Grant
Open in new windowSmall oil leakRyan McDonough
Open in new windowBoost ajustmentDaniel Clarke
Open in new windowBoost spikesJames Johnson14
Open in new windowNewbie needs adviceKaloy Szyd
Open in new windowT-Piece boost controller problems...Luke Burt
Open in new windowStuffed Turbo?!!!Matthew Werner
Open in new windowHitting boost.Ken Tran
Open in new windowTurbo storageCihan Aday
Open in new windowGood deal or cheap and nasty?Michael Keen14
Open in new windowFaulty PCV Valve = Turbo Failure?James Harris
Open in new windowWonky power curve - running overly richSean Fair
Open in new windowTurbo Boost help!!Scott Gates
Open in new windowOil pressureJosh Brown
Open in new windowFront vs Rear TurboBraden Murdoch
Open in new windowMy PFC finally tunedSami Ansari14
Open in new windowHas anyone seen or used this turbo kit???Christian Molenda
Open in new windowElectronic Boost Controller = No fuel cut defender?Daniel Clarke12
Open in new windowJaycar Independent Electronic Boost Controller KitCharlie Ters
Open in new windowNo wheelspinChris Davey30
Open in new windowBoost increase...or not?Brad Knudsen
Open in new windowBoost issues!? Tim Hutchings
Open in new windowStuck wastegatesSteve Zourkas
Open in new windowMax psiCharlie Ters
Open in new windowRaising boost levelsLuke Burt
Open in new windowBirthday UpgradeRobert Whitbread159
Open in new windowVariable vane turbosMatthew Werner
Open in new windowTurbo replacemantDaniel Clarke38
Open in new windowTurbo bladesPeter Nitschke15
Open in new windowWhats the difference (CT12A)Shane McInnes
Open in new windowTurbos howling suckingJason Thornton21
Open in new windowHKS To4z opinionShyam Purushothman
Open in new windowT04z Hot Side QuestionMaurice Diggler
Open in new windowSingle turbo oil drainAnton Jones15
Open in new windowHKS T3G ActuatorsSteven Nanevski14
Open in new windowSleeping beast Luke Cairns17
Open in new windowDoes the 2JZ turbo set up bolt up to the 3-to-1 1JZ set upLuke Bell
Open in new window91 TT - Turbos not boostingKyle Wathen
Open in new windowHKS T3GRoshan Jay22
Open in new windowWhat are these vacuum lines?Joshua White
Open in new windowTurbos suddenly stopped boostingLuke Nieuwhof
Open in new windowPorting a stock BOV? Possible?Russell Rohde
Open in new windowDirty PipesRussell Rohde
Open in new windowHowlin' Wolf!Jeff Smith15
Open in new windowCeramic or steelBraden Murdoch16
Open in new windowHose off bov?Shannon Mobbs
Open in new windowNew Turbos - big problem!Mustafa Akgul41
Open in new windowI can't raise my boost levelBlake Gloyn
Open in new windowOpinions on turbo kitAaron Holland
Open in new windowWhat is the CT20 single turbo equivalent to?Andrew Stewart
Open in new windowGT3076R OR GT3082RLew Radbourn10
Open in new windowWhat turbo should I GoBlake Gloyn30
Open in new windowGt35r too big?Aaron Mead
Open in new windowHelp with stock BOV Piping?Maurice Diggler
Open in new windowQuestions about hooking up a boost controllerJake Laing
Open in new windowJust a quick question~~Aska Liu15
Open in new window1jz single turbo kitMicheal Males11
Open in new windowBoost problems, HELP!!!Tim Hutchings12
Open in new windowBlitz boost controler Phil Stuart14
Open in new windowBoost tapTim Hutchings
Open in new windowOne way valve on BOVBrian Timms
Open in new windowFcdRaymond Bardrick
Open in new windowStock boost levelTim Hutchings
Open in new windowHow hard is it to change an exhuast housing?James Harris
Open in new windowBooost problems with (DSBC)Rob Rojo
Open in new windowJaycar FCD (fuel cut defender) to use or not to use???Benn Glover10
Open in new windowSingle turbo sizeDaniel Clarke
Open in new windowSteel wheel upgradeDaniel Clarke
Open in new windowRear turbo is gone after changing rocker cover gasketBraden Murdoch
Open in new windowSingle turbo overboostShyam Purushothman
Open in new windowSINGLE TURBO CONVERSION. SOARER 2.5TTVinh Bui
Open in new windowWHAT DO I DO, WHAT DO I DO, OH MY GOD, WHAT DO I DO? Patrick Robinson16
Open in new windowWhat do you think of this kit?Will Schultz
Open in new window1JZ GTE Compression testEdward Salem16
Open in new windowCan I run 13s with more boost?Daniel Clarke47
Open in new windowHypergear TR44 HF installed (no leaks!)Grant Rowan52
Open in new windowWhats peoples opinion on kkr turbos,like 480Adam Holloway15
Open in new window problem with greddy profec b spec 2 Adam Holloway18
Open in new windowNothing is easy for meDaniel Clarke37
Open in new window$3000 for a single turbo conversionJeff Smith89
Open in new windowHELP HELP PLEASEJake Laing16
Open in new windowI need some serious help with my TTWill Sanguins13
Open in new windowHelp needed, T3G's not boosting over 7psiMustafa Akgul20
Open in new windowGarret TO4bRory Pipprell
Open in new windowRunning Rich at Start up / Under Boost bit of smokeDaniel Clarke
Open in new windowBov adapter.....What type of weld to use???Jeff Smith
Open in new windowIs this a manual boost controller?Charlie Ters
Open in new windowPics of my single turboAdam Holloway12
Open in new windowI have gone to single turbo nowAdam Holloway26
Open in new windowHELP, WITH HKS BOV INSTALLATIONShane Haverkamp
Open in new windowWhat the frick?!Ken Tran
Open in new windowTurbo Torque...hahahaRob Andreacchio13
Open in new windowEBC'SChris Prak21
Open in new windowAnyone using a Greddy Profec B spec II?Scott Ferguson18
Open in new windowHKS T3G'sDaniel Clarke
Open in new windowFuel cut cancel?Shaun Stephenson
Open in new windowPlumbing into Vacume hoses, that have already been plumbed intoChris Prak
Open in new windowBov HelpDale Holan
Open in new windowPicture needed from installed solenoid for a ebc (APEXI AVC-R)Rob Andreacchio
Open in new windowWhat flange isMichael Keen
Open in new windowBlow Off Valve PlateShane McInnes
Open in new windowGarrett gt17'sMichael Keen
Open in new windowGizzmo Ms-IbcCara Joseph
Open in new windowA single turbo for drift any ideas?Brendan Angee
Open in new windowRecommended turbo workshops in SA?Edward Salem14
Open in new windowHKS JZX100 turbo kit on a Soarer?Jon Edwards
Open in new windowWhat are peoples opinion on a IHI apexi C7 turbo 650hp setupDaniel Clarke20
Open in new windowNew Steel Wheeled Turbos, boost issuesDaniel Clarke15
Open in new windowHKS T3G'sLuke Burt
Open in new windowSTOCK BOV PICTURES ANYONE?Jeff Smith
Open in new windowInfo on TD06S 20G-12cm2Jeff Bedsor17
Open in new windowTurbosmart Dual Stage Boost Controller Install Braden Murdoch
Open in new windowAnother blow off valve question...Jake Laing
Open in new windowAdvise on upgradeAlen Sadikovic
Open in new windowDont buy just jap manifold for 1jAdam Holloway
Open in new windowBraided oil and water lines for TT turbosAdrain Parsons10
Open in new windowNeed help for boost controller asapPatrick Tran
Open in new windowMelbourne Turbo shopsCara Joseph
Open in new windowTurbos swap, stock to after marketBraden Murdoch23
Open in new windowPrice on going single Chris Davey12
Open in new windowSteelwheeled supra ct20aMatthew Crawford
Open in new windowGreddy profec b spec 2 are they hard to install and are they any good.Adam Holloway11
Open in new windowHelp Needed! Please Read!, Turbo Whine..Jeff Smith12
Open in new windowInstalling boost gauge on manualPatrick Tran
Open in new windowDo i need new turbos? if not wats wrong?Kim Anthony21
Open in new windowWhere to mount manual boost controller?Kurt Porter
Open in new windowFactory turbos about to kick it - Highflow or not?Daniel Clarke18
Open in new windowMaximum boost pressure on ceramics?Braden Murdoch18
Open in new windowBoost GaugeKurt Porter20
Open in new windowTurbo Timer-where to get one?Yang Luo10
Open in new windowCt12a options???Jeff Smith10
Open in new windowTurbo's getting stripped and rebuilt - opinions on kkk wheelsMatthew Crawford17
Open in new windowBoost cut...David Henderson13
Open in new windowHKS T3g do you have them?Christian Molenda
Open in new windowLeaking Oil DrainGrant Rowan
Open in new windowAre they gone????Edward Salem20
Open in new windowBoost GaugeMaurice Diggler21
Open in new windowInstalling CT12AsBen Daniel10
Open in new windowI'm Going To Buy A New Turbo...But Which One?Luke Yates36
Open in new windowInstalling boost controler Ben Socratous
Open in new windowDifference between GCG turbos and stockiesTodd Williams
Open in new windowDifference between front and back turbo?Peter Abdelmessih
Open in new windowAbout the steel wheelies on ebay?????Nilay Bhikha23
Open in new windowBoost Controller, Which vacuum line?Alex Ross13
Open in new windowTurbo manifold compatibilityBen Daniel
Open in new windowTwin Scroll Setup'sMarc Vipond
Open in new window400rwkw+ what else?David Eberhart50
Open in new windowSingle turbo & LPG, ECU questionChris Davey
Open in new windowHow much quicker will my turbo spool...Benjamin Burgess12
Open in new windowDumps with stock exhaust, FMIC, boost - any point?Paul McConnell
Open in new windowUpgraded twins with Subaru VF10 turbosDaniel Clarke49
Open in new windowSingle turbo conversion or just replace turbosMustafa Akgul21
Open in new windowTurbo noise issuesMatthew Sharpe12
Open in new windowHelpm please my soarer wont boost over 10psiBrian Timms
Open in new windowHow can i can set up the turbo boost on my soarerYang Luo
Open in new windowWhere to get turbos??Ross Pesina43
Open in new windowNot on boostAslan Kuyucu12
Open in new windowTurbonetics GT-KLew Radbourn
Open in new windowBoost Controller, Intercooler, Detonation...Cihan Aday
Open in new windowWhat do i need to go single....on a budget ??Benjamin Burgess12
Open in new windowFCD and Boost CutCihan Aday
Open in new windowWhat kind of hosing for a boost gaugeChristian Molenda
Open in new windowMethods of prolonging your turbo lifeBraden Murdoch
Open in new windowHow to tell if you have steel wheelsJustin Cook22
Open in new windowTurbo not bossting everything is fine but no boostBrian Timms
Open in new windowThere's a lot of talk about this, and it now has my interest.Todd Williams12
Open in new windowTurbo rebuildJustin Camilleri
Open in new windowTurbo whistle w/ upgraded exhaustEdward Salem32
Open in new windowNew toys for me!!!Ben Socratous18
Open in new windowFinding a t section for boost gauge/steering column q?Christian Molenda
Open in new windowOverdrive Turbo?Stephen Hurst10
Open in new windowLeaking oil from rear turbo oil line after refitting steel wheelsDamien Barnes
Open in new windowWhen to replace Turbos...Daniel Czechowski27
Open in new windowWhen turbos break it's a great excuse to UPGRADE!Joe Radisic
Open in new windowHELP: Smoke from turbo!Christian Molenda
Open in new windowGT3076R more responsive after tune and gearbox rebuildBenjamin Burgess
Open in new windowGREDDY TD07S-25G Charlie Ters
Open in new windowJJR TurboChris Davey
Open in new windowTurbo responseCihan Aday56
Open in new windowTurbosDaniel Clarke54
Open in new windowTurbo Removal.Jeff Smith19
Open in new windowAcceptable Boost to be run on stock turbos.Daniel Clarke17
Open in new windowHKS T3G dump pipeStasi Christo
Open in new windowDual Stage Boost ControlerTim Eacott
Open in new windowBoost loss, from 12.5 psi to 10 psiCihan Aday10
Open in new windowSurging when boost comes on and no real power Dennis Weglehner16
Open in new windowWhistling turbosBraden Murdoch57
Open in new windowPower fc boost control kitBenjamin Burgess18
Open in new windowCar misses and builds boostChris Prak
Open in new windowCheap turbos on EbayChris Davey
Open in new windowWhats this Single Turbo kit like?Dan Humphreys14
Open in new windowSingle turbo manifolds, what about this one?Benjamin Burgess
Open in new windowGT3040; T04S Compressor vs GT40 Compressor Benjamin Burgess
Open in new windowInstall Help!: HKS EVC IV Electronic Boost ControllerCallum Finch
Open in new windowFitting supra turbos to a soarer?Cihan Aday12
Open in new windowI'll never mess with wussy twins again! :-)...Brian Timms
Open in new windowTurbos in your passenger seat anyone!Jeff Wilkins11
Open in new windowTurbotech manual turbo boost controller - Opinions?Toan Nguyen
Open in new windowXR6 Turbo spec GT35RMaurice Diggler30
Open in new windowA few questions - boost + BoV.. need informationAka Abedin17
Open in new windowT3 or TD05Peter Suridge
Open in new windowDump pipes = boost rise + boost cut ?Maurice Diggler34
Open in new windowHKS T04R response on a 1JZGTE Chris Davey21
Open in new windowTurbocharger QuestionAaron Mead26
Open in new windowBoost problemYang Luo
Open in new windowGreddy Bolt On Turbo Upgrade KitSean Yost48
Open in new windowJaycar Boost controllerBrendan Hax13
Open in new windowTurbo oilTom Cousin
Open in new windowTurbo's needing to be explained....Vinh Bui
Open in new windowQuickest 60' on stock turbos and convertorDaniel Clarke36
Open in new windowFew questions - turbo's / things to look for / upgradesDean Carsen27
Open in new windowHigh Pitched Scream coming from turbosVinh Bui34
Open in new windowSingle TurboChris Davey
Open in new windowTurbo chatterDaniel Czechowski16
Open in new windowPicking up the turbos tudayBraden Murdoch15
Open in new windowUsing mechanical Boost controller as a Pneumatic FCDCihan Aday12
Open in new windowBoost issueBraden Murdoch14
Open in new windowTurbo upgrade option that is not what I was expectingRichard Johnson14
Open in new windowOther Direct Fit Twin Turbo applications perhaps??Adam Olsen
Open in new windowTurbo gaskets?Daniel Czechowski
Open in new windowHybrid Turbos vs Reconditioned Steel Wheeled TurbosVinh Bui89
Open in new windowCT12B's on a 1jz???Braden Murdoch
Open in new windowStock 1jz pulls 144rwkwJoel Moore11
Open in new windowTrust T67 25G- 8cm or 10cm?Aaron Mead
Open in new windowLoss of boost and less power all of a sudden :|Luke Nieuwhof14
Open in new windowThink my turbo seals are gone, now what?Matthew Sharpe11
Open in new windowCT12a turbo gasket part numbersBen Daniel19
Open in new windowTurbo lifeMichael Keen15
Open in new windowTwin TD05 Turbo MX73 Cressida projectAdam Olsen
Open in new windowCompressor mapsCihan Aday10
Open in new windowBoosting a mostly stock TTGraham Dollisson27
Open in new windowQuestion regarding TurbosDamian Ware19
Open in new windowTurbos on its wayFrank Sarkozi11
Open in new windowBoost ControllerBraden Murdoch47
Open in new windowSteel wheel turbo Vs hks t3g twin bolt on turbo Dan McColl119
Open in new windowManifold help. experiance people need only to read.Dan McColl
Open in new windowEbay boost controllersBen Socratous23
Open in new windowQuestion about the HKS or TD04 turbos??John Tibbs
Open in new windowIts time for a single.....Richard Johnson52
Open in new windowBoost Controller Settings (eboost)Simon Triantafillou11
Open in new windowI need turbo'd back pressure help!Trent Toovey23
Open in new windowUsing boost controller without SAFCLuke Nieuwhof
Open in new windowMy AVC-R got problemJordon Codd31
Open in new windowHks t3g turbo'sDave Stevanovic
Open in new windowTurbo Troubles?Callum Finch14
Open in new windowGone single near finnished what next?Cihan Aday
Open in new windowCT12 weight?Daniel Czechowski
Open in new windowTurbo swap.Danny Dinh
Open in new windowCoolant temperature rises after single turbo put inBen Socratous
Open in new windowCheapest turbo upgrade help???Paul Brockbank
Open in new windowWhat kind of lag is everyone gettingCallum Finch57
Open in new windowHow long turbo seals last???Matthew Sharpe14
Open in new windowWhat turbos fit directly onto the stock cast manifolds?Simon Triantafillou
Open in new windowTurbo died and gone to heaven?Jero Evans12
Open in new windowKinda nervous about turbo whine after reading the forums!!!!George Check11
Open in new windowFINALLY got the HKS t3g's in!!!Christian Molenda26
Open in new windowTurbo Death Whine.Ben Daniel13
Open in new windowRebuilding turbosYang Luo
Open in new windowTurbo recondition $3000 startAndrew Meiers10
Open in new windowGarret gt28 ballbering Daniel Drury17
Open in new windowSingle turboDanny Dinh
Open in new windowHow much life at 14psi ?Luke Nieuwhof21
Open in new windowStandard BoostDaniel Salt10
Open in new windowLabour cost of replacing one stock turboBraden Murdoch13
Open in new windowCost of Turboing a NA 2JZVinh Bui
Open in new windowStock turbo conversionAnthony Mare24
Open in new windowScreamer PipePaul Brockbank
Open in new windowAnyone know how to use the Blitz Dual SBC Spec S boost controller?Peter Nitschke
Open in new windowWhat to do what to do ( turbos)Matt Toll85
Open in new windowBoost dies, chocks at high rpm and bunny hopping, wtf?Sebastian Boyd13
Open in new windowSequentials on a 1JZ?Cihan Aday
Open in new windowSingle Turbo ConversionBrett Lauria28
Open in new windowGT45RMarc Vipond26
Open in new windowWeird Whining noise in turbos when cold?Callum Finch
Open in new windowAnother single turbo question...Peter Ha44
Open in new windowStandard turbo equivilants?Callum Finch11
Open in new windowSuper charger for TT soarerMarc Vipond44
Open in new windowWhat size of the turbo wastegate to fit in ct12aLew Radbourn14
Open in new windowHow to tell if they have steel wheels?Don Bagnall18
Open in new windowOver boosting/boost controller troubleJames Johnson
Open in new window25psi overboost on JZX83Phil Melvin
Open in new windowHeard a snick..have I lunched a turbo?Ben Socratous12
Open in new windowTurbo removalMatthew Sharpe20
Open in new windowSteel Wheeled Turbos?Jeff O'Rourke19
Open in new windowCould only get 8psi from my turbos while tuning safc2Daniel Drury
Open in new windowTurbo??Sam Lofts
Open in new windowSingle turbo setup done finally...Benjamin Burgess64
Open in new windowSingle turbo related questionPaul Brockbank20
Open in new windowTurbo Kit on Ebay. VERY NICEJames Harris10
Open in new windowCt12a vs t3gCihan Aday30
Open in new windowTriple turbo ???Don Bagnall29
Open in new windowReplacement trurbo's(what to look for?)Michael Sztyk
Open in new windowCt12a and ct12Peter Nitschke
Open in new windowOpinions on these turbosLew Radbourn
Open in new windowSingle Turbo Soarer! Need ideas on what to do next!Ben Evans32
Open in new windowChemical cleaning turbos, exhaust manifold etcSteven Nanevski
Open in new windowNeed advise on possible turbo setupCihan Aday11
Open in new windowStandard Turbo Boost SettingChris Davey
Open in new windowBig Single Turbo Whats your thoughts?Dave Storrie19
Open in new windowWhat size wastegate should i use?Chris Davey
Open in new windowCT12B'sCihan Aday19
Open in new windowYet Another Turbo Upgrade Thread...Rob Andreacchio18
Open in new windowSteel/stock turbo picsTodd Williams
Open in new windowT61 turboChris Davey111
Open in new windowTurbosMorgan Cross
Open in new windowLeaking turbo manifold - Duh..Andrew Meiers11
Open in new windowTurbo QuestionTodd Williams
Open in new windowSteel wheeled ct12A'sLindsey Swan
Open in new windowTurbo Pipes and Throttle Body...Shane McInnes14
Open in new windowBig Single Vs High Flow The Stock Turbo'sShane Hayter31
Open in new windowCT12a Steelies what PSI?? MAX?Cihan Aday
Open in new windowIs a T28 turbo too small?Lew Radbourn10
Open in new windowTurbo questionsTroy Tappenden
Open in new windowWhat size TurboBenjamin Burgess
Open in new windowTrust TD06-20G Single Turbo conversionSteven Nanevski
Open in new windowY-Pipe Single turbo conversion.Chris Davey
Open in new windowTurbo's againHayley Rafati19
Open in new windowBigger Turbo ConversionJared Martin21
Open in new windowTurbo oil linesSimon Roberts
Open in new windowLarger (GT40-67) turbo installed nowTim Eacott21
Open in new windowTRD TurboSam Sulley
Open in new windowTwin 2530's on a 1JZ-GTE?Troy Tappenden
Open in new windowSteel Wheel rebuildShane McInnes
Open in new windowLate model single turbo soarerMike Verrinder56
Open in new windowSingle Turbo 90 Degree Bend!Cihan Aday10
Open in new windowBig singleLouie Drossos
Open in new windowNo Turbo SpoolGraham Dollisson16
Open in new windowTurbo..boost.. how much does it run?Cihan Aday33
  Start New Thread
