  Soarer Central * Mechanical - V8 * Suspicious tick at idle... Previous Previous    Next Next
BMW E36 Coupe 1UZFE V8 340i
Friday, August 03, 2012 - 02:52 pm, by:  Mike Beck (Gold_40gt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I've become increasingly more suspicious of this tick my 1UZ has at idle.
I thought it sounds like a crank related noise, it seems to come from around the oil pan area of the car and disappears once the engine gets up to revs above 1000rpm or so
My exhaust welder reckons it could be a crank bearing on its way out...
Take a listen to this clip.
Ali Saeed
RSP GT-T
Friday, August 03, 2012 - 03:55 pm, by:  Ali Saeed (Ali) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
bottom end knock shouldnt just go away with RPM
Dave Rose
wa
UZZ31 / ML320 CDI
Friday, August 03, 2012 - 05:03 pm, by:  Dave Rose (Sand_groper) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Mick , remove acc belt and run it . ?
Daniel Marshall
V8 UZZ31 X2
Reg: 07-2011
Friday, August 03, 2012 - 08:10 pm, by:  Daniel Marshall (Ydass) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
exhaust leaking? when did you last change oil?
Victoria (The Nazi State)
Pretty Red Thing and The Black Rattler
Saturday, August 04, 2012 - 12:22 am, by:  Dan McColl (Hoon) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Possibly harmonic balancer.
Monday, August 06, 2012 - 09:14 am, by:  Matthew Sharpe (Madmatt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
It's a BOMB! Like in Cars 2...
Monday, August 06, 2012 - 01:14 pm, by:  Mike Beck (Gold_40gt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
haha!
Maybe its the stainless steel pipe extension on the sump oil feed pick up contracting...
Oh well I shall just keep my eye on it whatever it maybe... It runs too well to worry!
Lynden Phillips
Soarer UZZ31
Reg: 05-2006
Sunday, August 12, 2012 - 05:21 pm, by:  Lynden Phillips (Malicia) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I have noticed a loud knocking noise on mine after supercharging, was very concerned I had knock problems but after searching I found the Accessories belt tensioner is "bouncing" and making a loud knocking sound when it returns to position, The pulley isn't all the way in the return position so I'm hoping a longer belt will sort the problem.
