  Soarer Central * Test Post and Forum Issues * CD Stacker Error Code? Previous Previous    Next Next
Wess McManus
v8
Tuesday, October 09, 2007 - 06:12 pm, by:  Wess McManus (Bar) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Has anyone had experience with cd stacker error codes? my unit was working fine until it refused to play cd and sign displayed on upper emv.
" CDI(jap script)3" the jap script is a horizontal line over another thats attached to the lower third of an S.It seems to load through disc O.K, i've tried reset to no avail.
Most appreciative for help on this matter.
CHEERS
Wess McManus
v8
Wednesday, October 10, 2007 - 08:14 pm, by:  Wess McManus (Bar) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Well i found a post with identical problem there was no definitive answer but seemed to indicate laser was stuffed after only owning the vehicle for a fortnight!! a....are these available?? can anyone advise?? am i posting in the correct area?? thanks
Wednesday, October 10, 2007 - 10:52 pm, by:  Daniel Lee (Son_gokou) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi Wess,
You can contact Damian Ware and he can repair the cd stacker for you.
Also have a read on this page too!!
http://www.planetsoarer.com/mark/index.htm
Wess McManus
v8
Thursday, October 11, 2007 - 08:11 am, by:  Wess McManus (Bar) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Cheers mate!
Wednesday, October 17, 2007 - 11:08 am, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Same with this one.
Shyam Purushothman
Dorkland
2jzgte toyota Soarer
Wednesday, October 17, 2007 - 01:46 pm, by:  Shyam Purushothman (Zulu24) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
are we there yet...are we there yet
Natasha Schmidt
sa
v8
Reg: 03-2008
Sunday, March 16, 2008 - 03:01 pm, by:  Natasha Schmidt (Freestylergirl) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
hi everyone. i've just recently had my air bag suspension replaced by coils and after I picked her up to take her home I noticed the lever inside that opens the boot does not work and the cd stacker doesn't work either. japanese text comes up on the screen but i can't read it. does anyone know what i could do. or who i can take her to in adelaide? }
Wess McManus
v8
Sunday, March 16, 2008 - 07:18 pm, by:  Wess McManus (Bar) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hey Natasha,
have you checked the lock near the boot release?
Its a "valet "option that prevents opening of the boot.
I had the error code "japscript 3".
Because mine failed at once(without previous skipping)I suspect laser died.
My understanding is it could be a number of faults,I ended up just replacing stacker.
Good luck with it.
By the way ,hows she go with the coilovers?
Natasha Schmidt
sa
v8 uzz31
Reg: 03-2008
Monday, March 17, 2008 - 07:17 pm, by:  Natasha Schmidt (Freestylergirl) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
cool I will look for it. Coil's feel good, just got to fix the active suspension error that comes up when she does a system check.
Wess McManus
v8
Monday, March 17, 2008 - 07:52 pm, by:  Wess McManus (Bar) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I've heard that turning the active suspension (switch in the boot left side)to "off" will eradicate nuisance warning/error messages...can anybody confirm?
