  Soarer Central * Mechanical - Common * Unichip Info Previous Previous    Next Next
Open in new windowArchive through October 23, 2005Morgan Cross20
Sunday, October 23, 2005 - 11:31 am, by:  Benny Gammelmark (Oldfield) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Tyre pressure does effect the dyno results slightly but what you need (from memory) is lower pressure to get a better result so pumping them up wont help.
Also, turn off aircon and everything electrical in the car.
Kris Antczak
Sunday, October 23, 2005 - 11:37 am, by:  Kris Antczak (Lexus_v8) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Morgs:
I have driven one once before, when i was deciding which car to buy...the V8 or the TT....and i opted for the V8 as i was not too concerned about getting the big power output, and both cars being stock, didn't seem hugely different.
There weren't any modifications planned, but now that i saw what it read on the dyno, and getting accustomed to the current power output, im sensing that my foot has a tingly feeling for more power...hahaha
Benny:
I made sure all electrical components were turned off....
Alastair McPherson
London
Supercharged UZZ31 loaded V8
Sunday, October 23, 2005 - 11:42 am, by:  Alastair McPherson (Boosted_v8) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I'm running the unichip at the moment, its a great modification. My full writeup here:
http://www.toyotaimportsforum.co.uk/forum/showthread.php?s=&threadid=5987&highlight=unichip
Kris Antczak
Sunday, October 23, 2005 - 11:54 am, by:  Kris Antczak (Lexus_v8) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Nice write up there Alastair...
How much extra grunt did your charger give you?
Sunday, October 23, 2005 - 11:57 am, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Have you guys been reading the SA dyno day thread about yesterdays event?
Sunday, October 23, 2005 - 12:30 pm, by:  Benny Gammelmark (Oldfield) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I have now. Good job guys.
UZZ32 V8 Soarer #183
Tuesday, October 25, 2005 - 11:35 pm, by:  Dan McColl (Hoon) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Has anyone heard or know if the ecu mod that harry lemmins was working on is a go-er yet?
http://planetsoarer.com/ecu/ecu.htm
