Thursday, December 17, 2009 - 09:49 pm, by: Kevin Trac(Menty)
What are the fluids that need to be replaced? (Manual)
I want to do a full flush of the fluids. Diff fluid - 2L Brake fluid - 1L Power steering fluid - ???L (DEXIII) What fluids does the manual transmission use?
Is this it?
Scott Wilkes Goo Roo Tasmania 92 TT Factory Manual
Thursday, December 17, 2009 - 10:02 pm, by: Scott Wilkes(Scottywilkes)
bleed out the clutch and brake fluid (seperate systems) 1.5 to 2l brake fluid to do a good job of it
Engine oil x5 litres
Transmission oil x roughly 4 litres, i used castrol syntrans full synthetic oil, roughly 25 a litre, but cost me 10 a litre through my work
Diff oil x1.5 litres, i used castrol syntrax full synthetic oil, good stuff
Power steering fluid which is dextron III, remove the rreservoir return line and flush out the old oil, while pumping new stuff in while moving the wheels lock to lock. About 3 litres to do a good job (can be messy LOL)
Radiator coolant and inhibitor
So yeah, thats about it, i did all this about 6 months back
Kevin Trac TryHard 2141.sydney.nsw JZZ30MT, JZZ31AT
Friday, December 18, 2009 - 07:09 pm, by: Scott Wilkes(Scottywilkes)
piss easy mate, remove the fill 24mm bolt and then remove the drain 24mm bolt, replace drain plug, fill with new oil and refit fill bolt.
U fill until fluid starts to flow out of the fill hole. I think its 3 to 4 litres, cant really remember i just pumped away until i had the correct level
