  Soarer Central * Mechanical - Common * Motor Parts Previous Previous    Next Next
Anthony Wah Day
Soarer GT V8
Sunday, August 28, 2005 - 03:53 pm, by:  Anthony Wah Day (Naastee) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hey guys and gals,
Just wondering is it possible to get after market parts such as timing belt, water pump and bearings, for the Soarer (LS400) or do we have to buy from Lexus. Or is there any Toyota Car that has similar components.
Rating:
Votes: 1 (Vote!)
Sunday, August 28, 2005 - 04:42 pm, by:  Benny Gammelmark (Oldfield) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
The timing belt is for the engine so if you've got a 1UZFE then it should be the same part as for Soarers. Toyota Part# 13568-59045.
I think they share the Water Pump as well.
Someone please correct me if I'm wrong.
Andrew Ferres
Cressida V8
Monday, August 29, 2005 - 12:42 pm, by:  Andrew Ferres (Peewee) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Bearings can be obtained from any bearing shop.
