  Soarer Central * ICE - In Car Entertainment * ICE Chat * Aftermarket Single Din Headunit Install 91 Limited GT (EMV) Previous Previous    Next Next
Deven Solanki
Auckland
Soarer V8 GT Limited 1UZFE
Reg: 06-2018
Monday, June 18, 2018 - 08:31 am, by:  Deven Solanki (Deven1uz) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Had a mate around, and we attempted to install a single din headunit into my 91 GT Limited and replaced the cassette player unit. Managed to connect it with the (toyota to iso) (Iso to pioneer). The aftermarket headunit works, but cannot output sound, the volume control on the headunit doesnt affect the sound at all. It comes up with "AMP Error" on the aftermarket headunit screen and we are assuming it is because the volume control is seperate from the controls for the aftermarket headunit as it has an EMV screen. Anyone have any advice?
Shaun Vallance
South Lanarkshire
Reg: 03-2019
Wednesday, July 03, 2019 - 07:40 pm, by:  Shaun Vallance (Shaunv90) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
From what I've read it's more likely to do with the standard wiring to amp now being redundant. AFAIK you have to now run your own speaker wires to have this work and bypass the stock amplifier.
