  Soarer Central * Trim and Interior * GROUP BUY - Ebay "Leather" seat covers * Archive through December 20, 2007 Previous Previous    Next Next
Julia Almond
SC300 / 2jz N/A
Reg: 12-2006
Monday, December 10, 2007 - 12:13 am, by:  Julia Almond (Juelz) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Dyed my carpet to black last night - but I promise I will post photos as soon as I feel that I am satisfied with the look of everything!
94 UZZ31 (V8) / 96 JZZ30 (TT) / 97 JZA80 (TT)
Monday, December 10, 2007 - 09:03 am, by:  Vinh Bui (Hyudsjk) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Alan, I started doing mine over the weekend. Didn't realise how much fkn hard work involved in getting these covers to fit when using the white strings!
Only managed to do the back seats on the Saturday afternoon. Looks pretty neat so far though...
P.S. Thank you Lawrence for the instructions. They really did help me out.
Alan Chow
GTT-L
Reg: 12-2006
Monday, December 10, 2007 - 01:23 pm, by:  Alan Chow (Alanchow) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Took me 2 1/2 days. bout 12 hours of work to do bot h the front and back. Was worth it though.
Monday, December 10, 2007 - 02:10 pm, by:  Vinh Bui (Hyudsjk) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
What did you use to get the white strings through the seats Alan? I used this really big needle I had laying around haha
Julia Almond
SC300 / 2jz N/A
Reg: 12-2006
Monday, December 10, 2007 - 07:04 pm, by:  Julia Almond (Juelz) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Man what a mission it was to install them. I'm glad no small children were around in my building cause there was a lot of swearing involved. I could not find a big enough needle so I sewed mine on a different way that worked somewhat effectively I think it only took about 9 hours all up.
Alan Chow
GTT-L
Reg: 12-2006
Monday, December 10, 2007 - 11:25 pm, by:  Alan Chow (Alanchow) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
i made do with a paper clip:-)
Carl Johnson
93 LTD UZZ 31 Manual 1UZFE
Sunday, December 16, 2007 - 09:08 am, by:  Carl Johnson (Carlos) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Lads, now that you have em on may be the wrong time for me to share how I'm doing mine.......but for those that haven't done em yet.
There is only ONE WAY.
Get a small crochet hook......(go ask you mum what it is if you dont know) Camera went over the side on a harbour cruise this week so sorry no pics of a crochet hook, sorry.
It is about 2.5mm dia about 100mm long, has a rounded hook on one end & a flattened section in the middle (flat section is perfect for grabbing with pliers)
The other end is blunt, go get your grinder out & sharpen the blunt end to a sharp point...I didn't have any metal blades so I just sharpened it by rubbing on concrete... it only took a minute the hook material is very soft.
Wont bother describing how to use it its pretty obvious.
Took me under an hr to do the entire back seat once it was out.
Passenger just over an hr once it was out.
Piece of piss mate
Christian Zimmer
Reg: 09-2006
Monday, December 17, 2007 - 09:52 am, by:  Christian Zimmer (Zimmi) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thats what I used as well. Picked them up from spotlight. Works awesome.
Grab them with pliers on the other end. I didnt even sharpen mine, just used a flat screwdriver to push it through and hold it down, while I grabbed it on the other side. Plus if you dont sharpen it, you can poke around trying to find it without getting stabbed.
Carl Johnson
Monday, December 17, 2007 - 12:17 pm, by:  Carl Johnson (Carlos) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Dont need to poke around if you have the seat out already...you can see it.
Carl Johnson
Monday, December 17, 2007 - 12:19 pm, by:  Carl Johnson (Carlos) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Having a majorly hard time getting the lid of the center console. Have removed the 10 small screws + the 3 big screws. Its lifting at the back but the front is held firm.
What am I missing?
Christian Zimmer
Reg: 09-2006
Tuesday, December 18, 2007 - 12:28 pm, by:  Christian Zimmer (Zimmi) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I want to get my front seats out but they wont budge.
Whats the trick? Do I have to remove the seat rails as well, or does the seat come off?
I fitted my centre console cover without removing the lid, slipped it over the top, then used a flat screwdriver to push the material in the sides, fits perfect and hasn't budged in over 2 months now.
Nik Gacomi
Reg: 05-2006
Tuesday, December 18, 2007 - 01:23 pm, by:  Nik Gacomi (Snoopie) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Christian can you find out how much your guy can do just two front seats for? I only need the front. Its a two tone interior - light grey and charcoal grey - with the crinkle effect. I also wanted the L logos in the head rests if possible.
Thanks Mate.
Nik
Julia Almond
SC300 / 2jz N/A
Reg: 12-2006
Tuesday, December 18, 2007 - 08:37 pm, by:  Julia Almond (Juelz) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hey Christian.. I just unscrewed the five bolts underneath the plastic covers and made sure the wiring or anything underneath were taken out and then tadaa yanked them out. I took out the centre console properly and even sewed it underneath and tried reinstalling it back as it was but I have given up.
Carl Johnson
Tuesday, December 18, 2007 - 10:16 pm, by:  Carl Johnson (Carlos) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Agree with Julia, getting the seats out is easy. Like she says pop the plastic covers off where the seat rails mount to the floor. Under the covers are the bolts. Undo all 5. Unclip plastic connector for power heater etc (assuming you have these) which is under the seat toward the front in the middle & lift the seat out. You don't have to remove seat from rails or anything like that.
I'm seeing Niall tomorrow, hope he can show me the center console lid removal process. Will post dets when I have em.
Keen to dye my carpet as well. Heard many recommendations on what is best to use. What have you used Julia?
Julia Almond
SC300 / 2jz N/A
Reg: 12-2006
Tuesday, December 18, 2007 - 10:21 pm, by:  Julia Almond (Juelz) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hey Carl,
I just used black VHT Carpet/Vinyl Dye - worked well. I just took the seats out and masked up the vinyl bits near the carpet and sprayed it all. Took about an hour and a half and dried really quickly. But as it says on the can use a stiff brush and you will need about 5 cans all up to do a decent. I used 4 and just made it but I would use 5 for a proper job. Next I will try dying some vinyl bits when I get some courage. Hope all goes well and it is all worth it in the end! Enjoy!
Carl Johnson
Wednesday, December 19, 2007 - 02:01 pm, by:  Carl Johnson (Carlos) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Umm I was originally planning to replace my carpet with via an after market co that do them for our cars. I saw it somewhere on this site. Was only $160 delivered from memory which I thought was pretty cheap. Getting the seats out is childs play but the console is an big job from what I hear. Maybe I will dye instead after all!
Carl Johnson
Wednesday, December 19, 2007 - 02:04 pm, by:  Carl Johnson (Carlos) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Still haven't heard from Niall about how to get the lid of the center console, will see him this arvo & will post instructions then
Lawrence Ostle
tt
Reg: 12-2005
Wednesday, December 19, 2007 - 05:08 pm, by:  Lawrence Ostle (Lawrence) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Carl, I bought charcoal grey carpets from E-Bay, $205 delivered. Took an afternoon to fit, taking the console out is not hard.
The lid of the console - I recall there were lots of small screws to undo and three larger ones. Then it comes out - you must have just missed a few......
I'd have a look but I'm on my way out. If you don't get sorted, PM me and I'll take a few photos etc.
Brett Moloney
Supercharged UZZ31
Wednesday, December 19, 2007 - 05:53 pm, by:  Brett Moloney (Lxsv8) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
So how good a fit are the carpets Lawrence?
Julia Almond
SC300 / 2jz N/A
Reg: 12-2006
Wednesday, December 19, 2007 - 06:47 pm, by:  Julia Almond (Juelz) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hey carl, I was planning on doing the same as you and getting the aftermarket carpet from the internet. But when I saw a few photos of them installed I chose to just dye the carpet instead. That's just me though, the aftermarket ones come in two pieces and sometimes it looks rather funny when you can see the join through the middle. But each to their own view and good luck with whatever you choose.
Lawrence Ostle
tt
Reg: 12-2005
Thursday, December 20, 2007 - 06:17 am, by:  Lawrence Ostle (Lawrence) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Brett, the fit is good, takes a bit of wrestling to get them in though, but worth the effort.
The join is not really an issue, as it is only 2 inches or so and not that conspicuous.
Anuradha Vithanage
2JZ-GTE
Thursday, December 20, 2007 - 12:19 pm, by:  Anuradha Vithanage (Lankanrascal) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hey guys, planning to do the seats finally this weekend. Just wondering does anyone have any photo's of how to take the front and rear seats out? Cheers guys
Lawrence Ostle
tt
Reg: 12-2005
Thursday, December 20, 2007 - 06:01 pm, by:  Lawrence Ostle (Lawrence) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
written instructions are earlier in this thread.
Anuradha Vithanage
2JZ-GTE
Thursday, December 20, 2007 - 06:16 pm, by:  Anuradha Vithanage (Lankanrascal) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Cheers Lawrence i'll have a proper read of it this time. Cheers mate
Brett Moloney
Supercharged UZZ31
Thursday, December 20, 2007 - 07:42 pm, by:  Brett Moloney (Lxsv8) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Lawrence did you have to cut all the holes for bolts etc?
