  Soarer Central * Trim and Interior * Air Conditioning Filters Previous Previous    Next Next
Matthew Tai
JZZNABoB
Sunday, May 10, 2009 - 02:16 pm, by:  Matthew Tai (Matttai) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
So I decided to check them out today...
LOL
Do people usually just replace these or clean them out? Any tips for cleaning. I've tried running it through water and doesnt do much so I think just straight replacements may be in order.
GT Starlet
Sunday, May 10, 2009 - 02:31 pm, by:  James Harris (Haro) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
They are pretty hexy i think to buy new ($80??) ....
mine were not THAT bad but i used some 'handy andy' and a scrubbing brush to get mine cleaned up a bit.
Then i sprayed them with some nice perfume so they would always smell good haha
Matthew Tai
JZZNABoB
Sunday, May 10, 2009 - 02:37 pm, by:  Matthew Tai (Matttai) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I just found this
http://soarercentral.com/sc-forum/messages/10/31.html?1150259642
my bad :-)
90 for the pair is abit exp. for what they are. but knowing im now breathing pristine pure air might be worth the cost.
Mike Dobkin
Essex
Reg: 10-2008
Sunday, May 10, 2009 - 05:48 pm, by:  Mike Dobkin (Razman) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Mine were in a similar state and I found the best way to clean them was to put them in the sink with a 1" deep strong solution of carpet cleaner, 'slapping' them into the solution. You can try using a stiff brush too, but mind that you don't damage the paper fibres. The muck that comes out is quite amazing - I had to change the solution three times before it was clean.
I then dosed them with some air freshener and popped them back in.
Supercharged & Intercooled V8
Tuesday, May 12, 2009 - 11:36 am, by:  Adam Peterson (President) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I put mine through the washing machine and then the drier. They came up a treat !
