  Soarer Central * Trim and Interior * Where to buy new door trims...mine are fugly Previous Previous    Next Next
Mike Biggs
GT-TL
Monday, December 19, 2005 - 11:47 pm, by:  Mike Biggs (Proph3t) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Howdy,
It is time I bit the bullet and spent some dough fixing my broken door trims. I remember someone had them new for sale. I think around the $200 mark each.
Are these still available? I dont wish to fix them ...I just want new.
Cheers guys.
1991 UZZ30 GT4.0 V8
Tuesday, December 20, 2005 - 08:52 am, by:  Don Bagnall (Baggs) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Neil, bless him, was doing a group buy, and that's where they came from
3.0 GT
Tuesday, December 20, 2005 - 09:11 am, by:  Matthew Sharpe (Madmatt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Min has a break in it halfway allong the window line - the vinyl is hanging on at the moment, but you can see it bubbling - its going to split eventually if I dont fix the break underneath, and will almost certainly split if I try and remove the whole trim... was thinking of injecting some kind of glue in there - any one have any bright ideas? Other than a broken right hand vent inlet, its the only bad spot in an otherwise immaculate interior.
Mike Biggs
GT-TL
Tuesday, December 20, 2005 - 10:02 am, by:  Mike Biggs (Proph3t) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Now that you mention it Don, it was Neil. I've contacted him, and :fingerscrossed: he can still get me a pair...and for hopefully less than a years wages.
Is there anyone here that bought some from Neil? What exactly did you get?
Cheers.
Ollie Ernst
Soarer V8 Limited
Tuesday, December 20, 2005 - 10:24 am, by:  Ollie Ernst (Oli_g) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I bought a drivers side door pocket from Neil which is the lower section of door trim which holds the window/door switches, speaker grill and map pocket etc. Best investment I ever made. Before I fitted it I reinforced the usual breakage area around the speaker grille with Araldite and used large(ish) washers under all fixing screws to spread the load nicely and prevent the screws pulling through the trim.
1991 UZZ30 GT4.0 V8
Tuesday, December 20, 2005 - 10:32 am, by:  Don Bagnall (Baggs) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
If Neilo-San does another group buy, I would entertain the thought of getting at LEAST the drivers side, and possibly the passengers side, although both mine have only got the split by the speakers, and are perfect in ALL other respects, so maybe getting them repaired would be the go
Mike Biggs
GT-TL
Tuesday, December 20, 2005 - 10:41 am, by:  Mike Biggs (Proph3t) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Ok...I'm gonna setup a Expression of Interest Thread that we can show Neil and he can get us a price if he wants, otherwise we'll source them ourselves.
Simon Triantafillou
Soarer Turbo
Tuesday, December 20, 2005 - 12:18 pm, by:  Simon Triantafillou (Soarer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hmm, I remember the group buy, but don't think it ever went through. There was something like a 6 month wait for the door trims, and I never heard anything since :-(
Super Charged UZZ31
Tuesday, December 20, 2005 - 12:35 pm, by:  Neil Griffiths (Aussiesc) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yep..My supplier dropped out of it because there was to many Part No's to contend with..
I can not do a group supply of these. :-(
I think it will be easier to just get em from
James @ Castle Hill Toyota
1800-111-388
Eldin Didic
UZZ30 V8
Tuesday, December 20, 2005 - 09:10 pm, by:  Eldin Didic (Dvine) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Spoke to Neil on email about this myself. My trims are goneskis.. He did suggest replacing the door pocket is what i need. Does anybody have pics of what the door pocket it exactly, does it have the back plastic backing, or is it only the vinyl cover for it? Could somebody shed some more light on what a door pocket is.
Thanks.
Super Charged UZZ31
Tuesday, December 20, 2005 - 10:05 pm, by:  Neil Griffiths (Aussiesc) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Its the big middle section that the handle sits on . the speaker cover screws to it as does the window switch..
It's the part that breaks (most of the time)
Eldin Didic
UZZ30 V8
Wednesday, December 21, 2005 - 11:14 am, by:  Eldin Didic (Dvine) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
ok, does it also replace where the door handles screw into. because the plastic where the door handles screw into the door are broken and when i pull the door shut, the entire middle section moves out towards me when closing the door.. i will not be surprised if it completely snaps on me anytime soon.
Super Charged UZZ31
Wednesday, December 21, 2005 - 02:12 pm, by:  Neil Griffiths (Aussiesc) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
YUP :-)
Norfolk Island
Wednesday, December 21, 2005 - 05:12 pm, by:  Mike Triggs (Mikeandimah) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
There's a LH grey trim on ebay at the moment- I wish he'd taken the wooden trim off though! (so he could sell it to me:-)) Bought a taillight off this guy last week- seems OK, he bought a half-cut or wreck for the motor (his other listings were Commode-related- I hope he isn't putting a Soarer donk in a Holden...)
Dave Storrie
Reg: 12-2005
Thursday, December 22, 2005 - 07:18 pm, by:  Dave Storrie (Casp3r) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Too late mate, i got that one :P now i just need a drivers door!
Nathan Sheehan
Soarer TT Manual
Reg: 12-2005
Monday, January 23, 2006 - 11:00 am, by:  Nathan Sheehan (Soarermad1) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I've been searching for a supplier of a full trim A pillar pod mounts, I can get one for $160 made up but I am just wondering if anyone knows of any that can be bought for cheaper or anyone who's done a good job making one.
Do Supra A pillar pod mounts fit snuggly to the soarer A pillar???
I really would like a factory look but if it's too expensive it wont be worth it.
Nathan Sheehan
Soarer TT Manual
Reg: 12-2005
Monday, January 23, 2006 - 11:01 am, by:  Nathan Sheehan (Soarermad1) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
oops, that's a mistake that last post ignore
Monday, January 23, 2006 - 12:21 pm, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
See the littel red cross at the top right of your post? That allows you to delete it.
