  Soarer Central * Suspension * Anything to be wary of? Previous Previous    Next Next
Mike Bradberry
V8 UnLimited
Friday, September 12, 2008 - 09:51 am, by:  Mike Bradberry (Halflife) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Changing front right air strut. Anything I need to be wary of?
Is the air let out of all struts when I release the airline? Is so, does the car need to be supported?
Just a little concerned and thought I would check.
Yes, I have read as much as I could find on the subject, but want to be sure.
Peter Scott
qld
Reg: 08-2008
Friday, September 12, 2008 - 11:27 pm, by:  Peter Scott (Scotty) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
You would have to be careful mike that the Bag didn't go down on you ha ha ha.If it did you could take it to a plastic sergin and get it filed up with silicon. That would improve the ride.
Michael James
V8 UZZ31 Limited
Saturday, September 13, 2008 - 04:25 pm, by:  Michael James (Wildwizard) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
LOL x2
Pretty sure the air flow will stop from the solenoid, which each strut has it's own and therefore the rest should stay up.
Mike Bradberry
V8 UnLimited
Tuesday, September 16, 2008 - 07:38 pm, by:  Mike Bradberry (Halflife) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thank you Peter for that advise.
I did the job anyway, and found that the air stops at the valve which is on the end of the line that goes into the strut. So all is good.
Peter Scott
qld
Reg: 08-2008
Tuesday, September 16, 2008 - 08:04 pm, by:  Peter Scott (Scotty) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thats good Mike,you should be a micanic.Where did you get the strut from and how much.
Mike Bradberry
V8 UnLimited
Thursday, September 18, 2008 - 08:47 am, by:  Mike Bradberry (Halflife) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Peter, my sources are private and confidential, and as for the price, it was good.
I can sell you a right hand front strut with a slight leak for as little as $900.00.
If you want it, you can find it in this weeks wheely bin.
Thursday, September 18, 2008 - 09:20 am, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Mike Bradberry wrote on Thursday, September 18, 2008 - 08:47 am:
Dave Rose
wa
uzz31 v8
Thursday, September 18, 2008 - 09:53 am, by:  Dave Rose (Sand_groper) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Mike ..do you mean $90.....!!!!!
Mike Bradberry
V8 UnLimited
Thursday, September 18, 2008 - 02:29 pm, by:  Mike Bradberry (Halflife) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I mean who would buy a leaking second hand strut for $900.00.
This is why I said he could find it in the wheely bin.
BTW, I do know this guy and there is a certain banter between us, but thank you both for your concern.
Thursday, September 18, 2008 - 10:50 pm, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Mercedes Benz SLK230 Kompressor
Friday, September 19, 2008 - 05:25 pm, by:  Don Bagnall (Baggs) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Mike Bradberry wrote on Thursday, September 18, 2008 - 02:29 pm:
It's coz we care!
