  Soarer Central * Suspension * Bilstein shocks installed; 'TEMS Suspension' warning on. Previous Previous    Next Next
Karl Baladovciv
Soarer V8
Reg: 09-2008
Tuesday, November 18, 2008 - 04:44 pm, by:  Karl Baladovciv (S_t_a_r_3_3) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
The airbag suspension have been removed from my car, and replaced with bilstein shocks. Whilst driving, the 'TEMS Suspension' warning stays on.
Is there a way to have it disabled?
David Goldthorpe
UZZ31 GT-L
Reg: 11-2007
Tuesday, November 18, 2008 - 10:33 pm, by:  David Goldthorpe (Sprocket82) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Karl, I think there may be a fuse that needs to be taken out.
Did you put new springs and shocks in or use second hand parts? I'm currently in the same process but having a hard time trying to find top hats to suit the new shocks I bought.
Scott Casey
soarer v8
Reg: 02-2008
Wednesday, November 19, 2008 - 02:57 pm, by:  Scott Casey (V8soarer_1991) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
was doing some reading a while back. it said to remove the airbag computer/s.
which stops the warning messages, air pump from kicking in and a few other things
Karl Baladovciv
Reg: 09-2008
Wednesday, November 19, 2008 - 09:37 pm, by:  Karl Baladovciv (S_t_a_r_3_3) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
@David: I'll check the fuses and see if anything makes sense. Fuse from the engine bay? Or from the door?
Either way I'll eventually get it back to my mechanic and see if he can try some stuff.
Lance Moon
SC400 V8
Reg: 11-2007
Wednesday, November 19, 2008 - 10:11 pm, by:  Lance Moon (Lancemoon) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I also swap the suspension from airbag to coilovers, and i got same warning light was coming on. on me, just take out the from the engine bay. it call should be SUS.
cheers
Karl Baladovciv
Reg: 09-2008
Thursday, November 20, 2008 - 07:56 am, by:  Karl Baladovciv (S_t_a_r_3_3) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Oooh!! Thanks Lance, I'll have a look at lunch. Excited!
Karl Baladovciv
Reg: 09-2008
Friday, November 21, 2008 - 04:22 pm, by:  Karl Baladovciv (S_t_a_r_3_3) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
@Lance
The 'SUS' fuse had already been taken out. :S Hmmm..
Thursday, December 04, 2008 - 08:53 pm, by:  Daniel Lee (Son_gokou) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Guys I went to my mechanic to get the airbag suspension removed from my car, and replaced with bilstein shocks too.
I have no error coming on dash and he told me there are two fuses needed to remove.
One from the engine bay and one from the driver side kick panel.
Ron Bassett
v8 LTD
Reg: 04-2007
Monday, March 23, 2009 - 12:53 pm, by:  Ron Bassett (Ron) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
In your profile it says Bilstein Coilovers....you do mean shocks don't you?
Do you have details on the exact Bilsteins used and in what combo with springs eg your Soarer springs or Kings, Supra pre or post may '96, tein , ???? I would love to hear of your changeover details and impressions.
