Friday, December 02, 2005 - 09:54 am, by: Tom Richards(Tomr)
at what KMs should you look at repacking the front wheel bearings?
the hub looks different to a "normal car" where you remove a dust cover, split pin and nut to access the bearings. How do you remove the bearings on a soarer?
Friday, December 02, 2005 - 10:12 am, by: Brian Laws(Asian_warrior01)
us a press i tried to hammer mine out using a mini sledge and a brass bar wasn't successful the bears are 50mm wide and a very tight fit. i dont know how many km's they should be down at but as soon as start squeaking another way of testing them is to jack the car up and see if there is any play in the wheel. to check one and on top and on hand on the bottom of the tyre and rock it to and from the car and you can feel if the bear needs replacing.
