Saturday, May 23, 2009 - 10:44 pm, by: Avin Luther(Lex_luther)
I swapped my airbags for springs a while back and have had no probs with errors etc. I have removed the 60amp fuse.
However!.. today while trying to clean up the flow of air in my BFI and reduce some weight i removed the splitter for the air lines. the little thing that sits behind the drivers side fog light, just in front of the compressor. I had to unplug the wire that leads to it and now i have "TEMS suspension" error.
Everything else in the car is working fine. Is there anything i can do, apart from plug the stupid think back in, to remove the error?
Did the 60amp come from the engine bay fuse box? I believe you also need to remove a fuse from the driver's footwell fusebox, someone should chip in to confirm fuse position
Daniel Lee Goo Roo Victoria Soarer GT Limited UZZ31 V8
