  Soarer Central * Suspension * Anyone using Maxxis MAV1? Previous Previous    Next Next
Ali Saeed
Thursday, June 04, 2009 - 07:10 pm, by:  Ali Saeed (Ali) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
ive got some Maxxis MAV1 235/40/R18 on my car. when i bought it they were pretty much on the way out. because i never got to see these work when they were newer, i am wondering if these are good enough tires to use again, or should i go with some other ones? they are rated W, so the speed rating is pretty good, and they cost about 200 bucks a tire, which is also pretty good.
Chris Round
Soarer TT JZZ30
Reg: 06-2008
Thursday, June 04, 2009 - 07:17 pm, by:  Chris Round (Hermie) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hey Ali,
They are the same tyre I have on the rears. I find they are great for the price - no noticeable road noise, good traction too.
I suppose it depends on what you plan to do - just daily drive they would be fine, but track days or drags or something - probably need a better tyre.
I hope to get my right rear replaced on Saturday - for free - considering I went to a different place to get an alignment - and they got it spot on with a substantial difference in the visual angle of camber. Hopefully they last longer than 5 months this time!
Ali Saeed
Thursday, June 04, 2009 - 07:27 pm, by:  Ali Saeed (Ali) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
yeh nah daily driving tyre. im thinking of buying a separate set of track tires.
Scott Wilkes
Tasmania
92 TT Factory Manual
Reg: 10-2008
Thursday, June 04, 2009 - 10:18 pm, by:  Scott Wilkes (Scottywilkes) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
i have these all around, 265 rear 235 front on 18s, i find them a great tyre, done about 5K on them and no noticible wear yet. Great grip, found them nearly impossible to spin up, and thats with a manual HAHA.
They have broken in now and settled down, and i couldnt be happier
Andrew Ferres
'90 C-F Celsior V8, '84 Soarer V8, '91 Supra V8
Monday, June 08, 2009 - 02:00 pm, by:  Andrew Ferres (Peewee) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
MAZ1's are supposed to be a lot better than the MAV1's and not much more expensive. I don't know if the MAZ1's are available in your size though.
I've had MAZ1's before and they are one of the best value tyres around.
Scott Wilkes
Tasmania
Reg: 10-2008
Monday, June 08, 2009 - 08:39 pm, by:  Scott Wilkes (Scottywilkes) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
i went in wanting Z1 victra tyres, but due to the fact they didnt make 265/35RZ18 tyres, i resorted to buying the V1s, later to find out that they are listed on there website :-(, so the tyre shop told porkies to me.
Not that happy with that, but they are great tyres for the price, even if they are not the Z1s
Andrew Ferres
Monday, June 08, 2009 - 09:15 pm, by:  Andrew Ferres (Peewee) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Bob Jane doesn't bring in every Maxxis tyre they make, only whats popular.
I wanted 235/45/17 on the front and 255/40/17 on the rear, but had to settle on 235/45/17 all round as they didn't bring the 255/40/17 into the country.
Scott Wilkes
Tasmania
Reg: 10-2008
Wednesday, June 10, 2009 - 06:20 pm, by:  Scott Wilkes (Scottywilkes) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
ah, wish they could of got the Z1s though :-( much better looking tread design, not so blocky.
Ali Saeed
Thursday, June 11, 2009 - 02:16 am, by:  Ali Saeed (Ali) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
offtopicish, whats the minimum rim width for 245s and 255s? ive got some 235s on the rear, but i really need 245 or 255...
Andrew Ferres
Thursday, June 11, 2009 - 09:17 am, by:  Andrew Ferres (Peewee) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
They don't really stipulate a legal minimum rim width, only a maximum rim width.
Just use the manufacturers recommendations for minimum width.
Personally though, for 245's I'd want 8" rims, and 255's, 9".
