  Soarer Central * Suspension * A-SUS again Previous Previous    Next Next
Yuri Suleimanov
Moscow
uzz32
Reg: 09-2008
Saturday, March 20, 2010 - 11:23 pm, by:  Yuri Suleimanov (Sheitan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I'd finally found the hydromaster here, in Russia, and gave him two front struts to rebiult.
Unfortunately master said, that struts rebuilt everything is ok, but system doesn't work and don't know why. something like "the fluid doesn't come into struts, maybe something with the pump"
I've run the diagnostics and foud errors:
#16 Low Oil Level (LOIL)
Symptoms
Oil level sensor registers below 0.3V for more than 1 minute continuously
Check Points
(1) Active Control Suspension Fluid no good (contaminants).
(2) Oil leak
(3) Oil level sensor broken
(4) Oil level Sensor Wiring harness is shorted or broken, connector has come loose
#51 System pressure does not reach minimal level [PACC]
Symptoms
System pressure is less than 70cm3 for more than 10 seconds continuously
Check Points
(1) Accumulator Pressure Sensor broken
(2) Suspension control pump V belt stretched too long
(3) Oil leak
(4) Suspension Control Pump Broken
So how can I fix this?
Victoria (The Nazi State)
Active V8 and the Beast.
Sunday, March 21, 2010 - 12:46 pm, by:  Dan McColl (Hoon) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Maybe you need to top up the suspension fluid.
Yuri Suleimanov
Moscow
uzz32
Reg: 09-2008
Monday, March 22, 2010 - 01:33 am, by:  Yuri Suleimanov (Sheitan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I'll try it. But I'm worried about one thing - I've tried to do suspension test and it doesn't work. And I didn't hear any sounds of fluid bleeding. So I'm afraid there is something with the pump... Or does lack of fluid explain everything?
