Tuesday, December 29, 2009 - 08:55 am, by: Nathan Hlad(Jackpot)
will trd sway bars made for the jza80 supra fit onto my jzz30 tt 1jz ??
Item #: trd sway bars
These are the newly released TRD front and rear sway bars for the JZA80 Supra. 27% stiffer than stock, providing just that much control. Perfect for street cars that want to have a tout suspension for the street and road racing or Auto-X.
Tuesday, December 29, 2009 - 08:13 pm, by: Nathan Hlad(Jackpot)
cheers matt.
so the front bar will be a simple task but the rear will require a little modification. will a skilled 'mechanic' or 'tuner' be able to put the rear one in without needing any new parts or will i have to buy new mounts for the rear ??
if anyone has trd sway bars i am very interested in knowing how you went with the rear.
Wednesday, December 30, 2009 - 07:30 pm, by: Nathan Hlad(Jackpot)
cheers heaps matt, so all i need is the sway bar kit and new rear mounts for a supra from toyota. it is a pretty easy job yeah ?? sorry i dont know too much about this type of thing.
Thursday, December 31, 2009 - 11:17 am, by: Matt Petersen(Mattmannz)
You will need the physical mounts, bushes for these mounts, worth doing new end links as well.
It's a pretty straight forward job. The old endlinks can be hard to get off so soak them in wd40 or whatever overnight and clamp them with visegrips to prevent them from spinning.
Thursday, December 31, 2009 - 07:22 pm, by: Matt Petersen(Mattmannz)
Not sure if there are any aftermarket end links available. They are effectively a solid connection so no possible improvement in the aftermarket area that I could see.
Saturday, January 02, 2010 - 12:32 pm, by: Nathan Hlad(Jackpot)
so matt just to double check before i purchase all this stuff, all i need is the sway bars, jza80 rear mounts, bushes for the mounts and new end links ?? also im thinking of painting the links some obscure colour before i put them on, does it sound like a good idea or do you know of anyone who has had problems with painted links ?
Monday, March 08, 2010 - 08:40 am, by: Nathan Hlad(Jackpot)
i read that link about the trd sway bars and just wanted to know if the part numbers listed were applicable here in australia ? i gave those part numbers to the guy at toyota and he had a little trouble finding them. just to clarify i purchase the 2 rear subframe mounts with the bushes for them included ?
Thursday, May 06, 2010 - 09:23 am, by: Nathan Hlad(Jackpot)
i now have the sway bars, the over priced rear subframe mounts and the front links. will i need to get new rear links too ?? they just look a bit different from the front ones. if so do i get jzz30 or jza80 rear end links ?
