  Soarer Central * Suspension * Different driveshaft for A02B? Previous Previous    Next Next
Jason Cheah
Monday, July 12, 2010 - 12:11 am, by:  Jason Cheah (Freaky) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Just wondering if a different length driveshaft is needed when switching from an open diff to an A02B from another soarer?
I am guessing no? But just want to confirm.
Matt Petersen
NA
Reg: 01-2008
Monday, July 12, 2010 - 05:47 am, by:  Matt Petersen (Mattmannz) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Nope they are all the same from a Supra and Soarer.
Matt.
Jason Cheah
Monday, July 12, 2010 - 11:41 am, by:  Jason Cheah (Freaky) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Cool. Thanks Matt.
I read that only the NA JZA80 is the same? the TT would be different as its mating to a Getrag?
Matt Petersen
NA
Reg: 01-2008
Monday, July 12, 2010 - 01:10 pm, by:  Matt Petersen (Mattmannz) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yep that's correct Jason - the rear diff housing from a TT is actually physically different so to fit the centre you need the different rear housing etc.
matt.
