  Soarer Central * Suspension * Height conttrol sensor Previous Previous    Next Next
Yuri Suleimanov
Moscow
uzz32
Reg: 09-2008
Sunday, June 05, 2011 - 07:35 pm, by:  Yuri Suleimanov (Sheitan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Good day.
I found out, that height control sensor on my uzz32 on front left leg is broken. I guess huge pothole or something.
And also the pipe which supplying fluid to the front left leg is leaking.
Can I repair this? Or should I just replace this parts? Can you give me the the parts number please?
Thank you in advance.
Paul Drane
Monday, June 06, 2011 - 07:41 pm, by:  Paul Drane (Paulwd) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
If you know some one with a UZZ31 that is being wrecked for parts or has had the air suspension removed, the height sensors are the same for UZZ32's.
The leaking hydraulic hose should be able to be repaired, but I could be wrong about that.
Damian Ware
UZZ32
Wednesday, June 08, 2011 - 07:09 pm, by:  Damian Ware (Frozenpod) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Where is the leak from exactly?
