  Soarer Central * Suspension * Spring rates for UZZ31 Coilover conversion to preserve ride quality Previous Previous    Next Next
Nem Jovanovic
Soarer - UZZ31 V8
Reg: 04-2012
Monday, July 16, 2012 - 07:19 pm, by:  Nem Jovanovic (Mrnamjama) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi folks
I have a '91 UZZ31 and would like to get the Air Suspension replaced with coilovers (various reasons - but mainly because I don't like the idea of driving on the highway with 21 year old air suspension under me...).
I've figured out a few things:
1) JustJap stock a couple of different sets that would suit. BR Type RS Series seems like a quality set
2) Requesting a different spring rate plus matched shock should be no problem
3) I don't want a spine shattering ride
4) I'm intending to drive at stock suspension height
So, given the above... from searching the forum I've found some figures for stock rates (
http://soarercentral.com/sc-forum/messages/30604/320199.html?1277815810) - "6 to 6.5kg/mm front and 3 to 3.5kg/mm rear" - I assume that's right for a UZZ30.
What I need some help with is understanding how that maps across to the Air suspension equipped models... What I'm after at the end is a level of stiffness comparable to the 'Hard' setting on mine - perhaps even a touch softer than that.
If 6/3 might be equivalent to 'Normal' on an air suspended 31, what would be 'Hard'? Is that comparison even valid?
I haven't driven another soarer, so your feedback would be much appreciated...
Nem
Scott Vim
Soarer (1uz) Chaser (1jz)
Reg: 12-2010
Monday, July 16, 2012 - 07:28 pm, by:  Scott Vim (1uz1jz) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I'm pretty sure that any coilover you use will be stiffer then the airbags. One car I've got buddy club coils and even on the softest setting they are more firm then the airbags. Depends what you like. I replaced the front airbags in my car and now should be good for another 20 years.
Victoria (The Nazi State)
Pretty Red Thing and The Black Rattler
Monday, July 16, 2012 - 07:49 pm, by:  Dan McColl (Hoon) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Put stock soarer coil spring suspension in it.
Nem Jovanovic
Soarer - UZZ31 V8
Reg: 04-2012
Monday, July 16, 2012 - 08:01 pm, by:  Nem Jovanovic (Mrnamjama) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Scott - I'm fairly sure both front struts have started to go (very slow leaks when it's very cold), and the right rear one has started weeping. I figure, I'm up for $2.5k delivered from the UK if I want to stick with air.
Dan - UZZ30 OEM shocks? Would this be part no 48510‑29135 from
http://www.toyodiy.com/parts/p_J_199105_TOYOTA_SOARER_UZZ30-ACPVK_4803.html?hl=48510 ?
I didn't really consider that option - would other parts be required other than the one above?
Boris Siljanoski
LS400 + Soarer.
Reg: 11-2007
Tuesday, July 17, 2012 - 01:48 am, by:  Boris Siljanoski (Z2tt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Fix the Air Suspension instead of Castrating it and making it less of a Car I reckon.
Failing that Dan's Idea can not be beaten, put V8 Non Airbag suspension on it.
If you want to Ride stock height, do not put coilovers on, ride quality will be bad.
Daniel Marshall
V8 UZZ31 X2
Reg: 07-2011
Tuesday, July 17, 2012 - 08:19 am, by:  Daniel Marshall (Ydass) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I have 12kg front and 6kg rear there soft.
Not as much as airbags ride wise though. If I have less then a 1iinch gap between gaurd and wheel they scrub going over bouncy small hills lol
Paul Drane
Tuesday, July 17, 2012 - 03:34 pm, by:  Paul Drane (Paulwd) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Boris Siljanoski wrote on Tuesday, July 17, 2012 - 01:48 am:
Have to disagree with you on that point Boris, depends entirely on spring rates, mine is low with 9kg fronts and 6kg rears and rides suprisingly good.
To be honest, I probably went a little soft on the spring rates, but I have my reasons, to me ideally something around 11 front and and maybe an 8 or 9 for the rear would be pretty good.
