  Soarer Central * Suspension * UZZ32 suspension Previous Previous    Next Next
Anton Jones
Thursday, July 12, 2012 - 05:58 pm, by:  Anton Jones (Alj) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
So I have rebuilt my struts, upper and lower, bled the whole system before and after and I an having this exact problem:
http://www.soarerworld.com/forum/showthread.php?t=28343
Any help would be AWESOME.
Thanks,
Victoria (The Nazi State)
Pretty Red Thing and The Black Rattler
Thursday, July 12, 2012 - 10:39 pm, by:  Dan McColl (Hoon) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Try ecu reset (disconnect battery for a few mins)
I'm guessing one (or both) of the valve body accumulators is low on gas.
Also, maybe a sticky valve in the valve body.
SUS ecu's are known to cause issues as well, Perry probably has a spare that you could try, or I do if needed.
Anton Jones
Thursday, July 12, 2012 - 11:03 pm, by:  Anton Jones (Alj) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks Dan, catching up with Perry on Sat and doing his suspension. He said he will bring a SUS ECU. But I will try the reset first.
Robert Thomas
Soarer uzz32
Reg: 11-2008
Tuesday, July 31, 2012 - 02:57 pm, by:  Robert Thomas (Shaddow) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Where abouts id the ecu controlling active suspension?
Tuesday, July 31, 2012 - 04:46 pm, by:  Dan McColl (Hoon) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Just next to the FP ecu, in the panel beside the rear seat.
Robert Thomas
Soarer uzz32
Reg: 11-2008
Tuesday, July 31, 2012 - 05:43 pm, by:  Robert Thomas (Shaddow) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Are these commonly faulty? How do they interfere with the active suspension? Where can a replacement be found?
Lynton Scale
UZZ32 Active V8
Tuesday, July 31, 2012 - 06:04 pm, by:  Lynton Scale (Lscale) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I thought mine was faulty but it was just a bad plug connection, I disconnected it, then reconnected it - all ok.
Allan Langford
Reg: 05-2010
Tuesday, July 31, 2012 - 09:24 pm, by:  Allan Langford (Allan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
just get a new one....
89190 COMPUTER ASSY, HYDROPNEUMATIC SUSPENSION
89190‑24010 (05/1991 - 07/1991) 1 $4,323.09
89190‑24011 (08/1991 - 11/1991) 1 $4,323.09
89190‑24012 (12/1991 - 12/1993) 1 $4,323.09
comes with free tube of KY!
Robert Thomas
Soarer uzz32
Reg: 11-2008
Wednesday, August 01, 2012 - 07:06 am, by:  Robert Thomas (Shaddow) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Gosh, Might need 2 tubes of KY
BMW E36 Coupe 1UZFE V8 340i
Wednesday, August 01, 2012 - 10:33 am, by:  Mike Beck (Gold_40gt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I wonder how much stock Toyota Japan would have of these sort of rare UZZ32 parts...
Allan Langford
Reg: 05-2010
Wednesday, August 01, 2012 - 11:31 am, by:  Allan Langford (Allan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
my concern would be electronics don't last forever, there would be lot's of custom chips in that $4k box... trying to make a replacement would be almost imposable without a huge budget, a electronics nerd, a maths nerd and a hydrodynamics nerd (walk into a bar joke here somewhere)
would suck do have a lovely uzz32 with everything working besides the suspension ecu!
Ali Saeed
RSP GT-T
Wednesday, August 01, 2012 - 11:56 am, by:  Ali Saeed (Ali) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Not quite 4.3k
http://www.amayama.com/search/?q=89190%E2%80%9124012&cur=AUD
Wednesday, August 01, 2012 - 08:06 pm, by:  Dan McColl (Hoon) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
They aren't known to give problems, but I guess like everything else they are now 20 years old and well past their design life.
Changing out the electrolytic caps would be a good idea.
Robert Thomas
Soarer uzz32
Reg: 11-2008
Thursday, August 02, 2012 - 09:04 am, by:  Robert Thomas (Shaddow) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I was told by a mechanic that faulty software or ecu could be the cause of the humpy-bumps that occur when stopping. Any ideas?
Saturday, August 04, 2012 - 12:21 am, by:  Dan McColl (Hoon) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Do you mean the near violent bounce that can occur?? This is related to the nitrogen accumulator at the bottom of the struts.
Robert Thomas
Soarer uzz32
Reg: 11-2008
Saturday, August 04, 2012 - 10:06 am, by:  Robert Thomas (Shaddow) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Nope, mine is more a wriggle in the rear struts. Not violent at all. Possible occurs during driving, but very difficult to spot then. Mostly happens during stopping.
Jason Buttigieg
Soarer V8 UZZ31
Reg: 01-2007
Thursday, August 16, 2012 - 11:54 am, by:  Jason Buttigieg (Jason) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Rob,
Those little wiggles that it can do when stopped at lights is almost certainly air in your hydraulic fluid. Have you bled the system recently? I'd check it again anyway. I'm speaking from experience as it happens with mine a lot at the moment due to all the sus work I'm attempting to do.
Anton Jones
Sunday, January 27, 2013 - 10:51 pm, by:  Anton Jones (Alj) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
still having this problem, any ideas?
