  Soarer Central * Suspension * I think my diff is gone or on it's way out, suggestions? Previous Previous    Next Next
James Tims
Reg: 11-2008
Saturday, December 08, 2012 - 10:34 pm, by:  James Tims (Timzy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi guys,
Driving home tonight and had to overtake some slow ass driver off the lights before the parked cars ahead so of course you floor it, anyway out of nowhere it felt as if I had been hit by a car but later on the diff I believe was like locking up randomly and making a really loud noise as I drove the car, this was on and off. Are these the usual symptoms or a gone diff or does it need and oil change?
Matt Newman
soarer tt
Reg: 11-2007
Saturday, December 08, 2012 - 11:53 pm, by:  Matt Newman (Soarersrock) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
if you drop the diff oil i bet you find a few teeth in there. at a guess id say the diff is gone but drop the oil to make sure
Auckland
95 UZZ31 with R154
Reg: 03-2009
Sunday, December 09, 2012 - 05:17 am, by:  James Johnson (Jimbo) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Sounds like it is doing what my old diff did. Pretty sure you have very few Kms left in the diff, mine lasted about 500Kms when I noticed the noise until it fully seized and snapped the yoke bit that connects to the drive shaft. Was a good excuse to buy a LSD tho...
James Tims
Reg: 11-2008
Sunday, December 09, 2012 - 08:55 am, by:  James Tims (Timzy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yeah I'm 99% sure it's the diff since I did a quick drive up the street and shifted through the gears and it sounded fine but then when I floored it every so often you'd hear that crunch. Bloody loud haha Anyway probably should invest in something short term to get me going and save for an LSD.
James Tims
Reg: 11-2008
Sunday, December 09, 2012 - 09:26 am, by:  James Tims (Timzy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Also out of curiousity, how hard is it to change over with just another open LSD in the mean time? Would it take long?
Jeff Smith
GT30/37r Single T 5 speed
Monday, December 10, 2012 - 09:47 pm, by:  Jeff Smith (Mozzie) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Not hard mate when you've got the right tools.. You need a large Allan key set and a long extension bar to help with undoing the diff mounts out of the cradle.. Other then that should take no more then an hour comfortably ...
Daniel Marshall
V8 UZZ31 X2
Reg: 07-2011
Monday, December 10, 2012 - 11:30 pm, by:  Daniel Marshall (Ydass) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
As long as someone hasn't attempted the Allen key bolts before and them :/
Auckland
95 UZZ31 with R154
Reg: 03-2009
Tuesday, December 11, 2012 - 05:44 am, by:  James Johnson (Jimbo) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
10mm and 12mm Allen key bits, big long power bar and I think 17mm and/or 19mm sockets and a trolley jack and someone to let the handbrake on and off for you when you are under the car....
The amount of times I have pulled a Soarer diff out and put one in, I got the whole technique down pat.
