  Soarer Central * Suspension * Air strutts Previous Previous    Next Next
Peter Arnull
SC400 (V8)
Reg: 02-2013
Monday, July 29, 2013 - 03:05 pm, by:  Peter Arnull (Boyscout0_2) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I have a Lexus SC400 Limited and I have recently noticed that if the car has not ben used a few days the front seems to drop a little. I suspect that I may be loosing air from the strutts. I notice that there are a number off threads about replacing the air strutts with coil over units. I am wondering if this is the way to go and the timing of doing the work. Any advice.
Peter
Vincent Chan
v8
Reg: 12-2010
Monday, July 29, 2013 - 04:15 pm, by:  Vincent Chan (Vincent191) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Buy some second airbags from here. With coilovers, if you get the good ones it is great. If you get the wrong ones (as I did) it is a disaster and a waste of money. It is really up to you and what turns you on.
Joshua Rao
TT (for sale $5.2k), 97 Blk UZZ31, 97 JZZ30 vvti turbo white manual, 96 vvti turbo manual, Legnum VR4, MR2 sw20, Alfa 156
Reg: 09-2006
Monday, July 29, 2013 - 05:13 pm, by:  Joshua Rao (Soaren1) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I have some second hand front airbags if u need
Jan van Berendonk
Reg: 08-2012
Monday, July 29, 2013 - 07:19 pm, by:  Jan van Berendonk (Janjen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Look into purchasing new airbags from NZ.
Remember most of these units are over 20 years old, while the air bag may be perfect the shockers are usually stuffed.
Ian Johnston
1995 UZZ31, BA XR6Turbo Ute. 2007 VE GTS.
Monday, July 29, 2013 - 08:23 pm, by:  Ian Johnston (Ted) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
What Jan said. Thats what I have found on 2 of my Soarers.(shockers stuffed)
Peter Arnull
SC400 (V8)
Reg: 02-2013
Tuesday, July 30, 2013 - 12:57 pm, by:  Peter Arnull (Boyscout0_2) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks for all the info. It would appear that the right front is the worst for sagging. Just wondering if I have an air leak. I would like some information about the contact in N.Z.
Jan van Berendonk
Reg: 08-2012
Tuesday, July 30, 2013 - 04:20 pm, by:  Jan van Berendonk (Janjen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Contact Marty,
marty.burnside@rbond.toyota.co.nz
He will provide pricing and availability.
