Monday, October 17, 2016 - 11:05 am, by: Mark Donovan(Mark_donovan)
I'm having some work done on my Soarers diff (A02A) next month, and would like to use the opportunity to also replace all the diff bushes, as well as any bushes in the subframe which may become accessible.
I've searched through all discussions here, and have found some useful info, but no part numbers, or total count of bushes that will need to be done.
Does anyone have a good idea of the part numbers, or know of a link where someone has documented this?
Monday, October 17, 2016 - 12:43 pm, by: Mark Tierney(Mark_t)
Gday Mark,
Ive just been through the same scenario....but yet to fit.
Some of these i grabbed from Amayama (justin), and some from Elmhurst Toyota in the US (Contact is Stanley Hopper - nice bloke)
I've attached a pic for you as well. I grabbed the bolts and all, which were just a couple of bucks. id hate to wreck one on the way out and be held to ransom for a $2 bolt.
Pls recheck the part numbers, as id hate to give you the incorrect info, but im pretty sure these were the finals i came up with after a plethora of research, both from toyodiy.com jpParts.com, and other assorted sites in US with the diagrams.
I'm a 91 GTTL turbo, so my ref in Amayama is e-jzz30-acpzz
Part No. 41651-24030 Description CUSHION, DIFFERENTIAL Quantity. x 1
Part #: 41651-24020 Description: CUSHION, DIFFERENTIAL Quantity x 1 (cross-reference - also used in JZA80 Supra)
Part #: 90110-14003 BOLT, HEXAGON SOCKET Replaced by: part # 90110-14007 Quantity: x 2 (cross-reference - also used in JZA80 Supra)
Part #: 90201-15020 Description WASHER, PLATE Quantity x 2 (cross-reference - also used in JZA80 Supra- 05/1993-07/1998)
Part #: 41653-24050 Description: STOPPER, DIFFERENTIAL Quantity x 2 (Cross reference - Also used in Lexus Gs300/400 - 08/1997-12/2004, and Lexus LS400 10/1994-07/2000)
Part #: 41654-24010 STOPPER, DIFFERENTIAL Replaced by: part # 41654-24030 Quantity x 2
Part #: 90105-12218 Description: BOLT, WASHER BASED H Quantity: x 2 (cross-reference - also used in JZA80 Supra- 05/1993-07/1998)
Good luck mate. I'll give another update once i do mine, but yes, pls recheck the parts for accuracy. i hope this sets you in the right direction.
I've got lots of updates, tasty ones at that, for SC still to come, but just haven't had the time. i'll try in the coming weeks. plenty of stuff on compliance and engineers certification in NSW.
