  Soarer Central * Air Conditioning and Climate Control * No Heat In Car: Solenoid Replaced - Is it my control unit? Previous Previous    Next Next
Jonathan West
Wiltshire
TT 2.5 GTTL
Reg: 12-2005
Wednesday, December 14, 2005 - 08:00 am, by:  Jonathan West (Anduril) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
My heating is kaput. The garage replaced the solenoid cos that was kaput, but now there is apparently no ground feed to the solenoid ... could this point to the Heater Control Unit being faulty?
Is the heater control unit included in the AC/Heater LCD (unreadable in cold weather! display) and control assembly (I drive a 2.5GTTL)? Has anyone else had this problem?
I checked out the ruski parts site - if I need a new heater control unit to solve the problem, do I read the picture right that I will need part number 88601A? (And is this the full Toyota part number valid world wide?!)
UZZ-32 V8 Soarer #138
Wednesday, December 14, 2005 - 04:04 pm, by:  Dan McColl (Hoon) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I would check all the wires and vac lines to the solenoid, Mine has a dicky connection at the moment.
Wednesday, December 14, 2005 - 04:06 pm, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
That must be a bit of a prick. :-)
Delan Peiris
UZZ31 V8 LTD Black/Black
Wednesday, April 19, 2006 - 07:10 am, by:  Delan Peiris (Delanx) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Run the AC Diagnosis and get the errors it gives you. Maybe that will help you to identify the exact problem.
