Friday, October 26, 2007 - 02:15 am, by: Colin Couves(Colinc)
Hi all, Can't seem to find the answer searching, so thought someone might be able to help On my 1990 Celsior, on start-up my check engine light and traction control lights come on and stay on. This does not occur if I immediately put the car in drive and go. Diagnostics indicate "RPM sensor #2" Can anyone point me in the right direction? Where are the RPM sensors located? Any help or experience with this would be appreciated.
Saturday, October 27, 2007 - 06:50 am, by: Rich O'neil(Kiwiinaus)
I wasn't aware there was a RPM sensor let alone 2 of them ? There are 2 igniters , 2 cam position sensors , 2 ignition coils and an engine speed sensor . The ESS is down under the crank pulley slightly on the left side or your right side if you are standing at the front looking at the engine.
Monday, October 29, 2007 - 09:59 pm, by: Joe Nebl(Spineregy)
Colin, im sure what they mean by RPM sensor is the cam position sensor but not 100%. can check though...bear with me and i will see what the manual says cheers joe
