  Soarer Central * Celsior Chat * Transmission mount or driveshaft damper Previous Previous    Next Next
Chris Wheatley
qld
Reg: 03-2011
Monday, May 16, 2011 - 11:54 am, by:  Chris Wheatley (Lowcelsior) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Im having a vibration either coming from worn trans mounts or drive shaft damper has anyone had these issues as i thorght it was a bad wheel bearing but its not and the transmision is fine. can any help on the matter
James Walker
Reg: 12-2008
Tuesday, May 17, 2011 - 08:26 pm, by:  James Walker (Jimmywalker) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
me also
Chris Wheatley
qld
Reg: 03-2011
Wednesday, May 18, 2011 - 12:28 pm, by:  Chris Wheatley (Lowcelsior) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
i have found if the rear drive shaft or cv joint is worn that can cause a vibration check the cv boots and axles.
