  Soarer Central * Test Post and Forum Issues * Need help Previous Previous    Next Next
Nicolas Perras
quebec
soarer 2.5tt
Reg: 04-2007
Monday, April 16, 2007 - 03:24 am, by:  Nicolas Perras (Nick_insane) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
i just bought a soarer tt 1991 from japan and i'm in canada. now me clutch seem to be slipping.
need advice on what should i do and what clutch and flywheel should i put in. and if you guys have the stock part number that would help too.
no modification on car except for the BOV and dropped suspension.
thank guys for you help
Monday, April 16, 2007 - 03:40 am, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Nicolas.
If you post up your VIN number, Don (parts guru) may be able to help with the numbers you require.
Nicolas Perras
quebec
soarer 2.5tt
Reg: 04-2007
Monday, April 16, 2007 - 08:55 am, by:  Nicolas Perras (Nick_insane) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
JZZ300010036
Monday, April 16, 2007 - 06:13 pm, by:  Don Bagnall (Baggs) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Here ya go Nicolas
I have a Cadillac and a Supercharged Manual V8
Monday, April 16, 2007 - 08:21 pm, by:  Neil Griffiths (Aussiesc) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
A stock W58 ( NA JZA80 Supra ) FRICTION PLATE will work if needed..Pressure plate is different.
Search over there also for JZA70 Supra ( Was sold to North America. )
Have your Pressure Plate RECONDITIONED.. Expensive to buy NEW..
Nicolas Perras
quebec
soarer 2.5tt
Reg: 04-2007
Monday, April 16, 2007 - 10:24 pm, by:  Nicolas Perras (Nick_insane) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
thanks Don (parts guru) loll your the best
Scott Ferguson
Alberta
Soarer GTT-L
Reg: 07-2006
Monday, April 16, 2007 - 10:40 pm, by:  Scott Ferguson (Scott_ferguson) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
The Canadians are invading!!!!
Good to see another Canadian here Nicolas.
Nicolas Perras
quebec
soarer 2.5tt
Reg: 04-2007
Monday, April 16, 2007 - 11:58 pm, by:  Nicolas Perras (Nick_insane) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
thanks man have an other question for you guys
maybe scott can help what get i put for brakes
pad caliper and disk cause it seem that the part number from the toyota database on this website is discountinued and stupid people in canada from toyota don't want to search for an engine number to get the part. when you say a have a toyota soarer they go crazy they don't know what it is
and when you say it on the same frame model than the lexus sc300/400 they go mad and tell you to call lexus
Scott Ferguson
Alberta
Soarer GTT-L
Reg: 07-2006
Tuesday, April 17, 2007 - 12:02 am, by:  Scott Ferguson (Scott_ferguson) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Lol I know that situation pretty well Nicolas.
Brakes are an issue but after a bit of research you can find the part numbers, what kind of brake pads and rotors are you looking for, just regular smooth rotors or something drilled and/or slotted?
Nicolas Perras
quebec
soarer 2.5tt
Reg: 04-2007
Tuesday, April 17, 2007 - 01:45 am, by:  Nicolas Perras (Nick_insane) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
both of them depending on the price I'll make my choice
for the complete set rear and front
thank scott
Nicolas Perras
quebec
soarer 2.5tt
Reg: 04-2007
Tuesday, April 17, 2007 - 01:47 am, by:  Nicolas Perras (Nick_insane) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Don is there a way i could get a hold on that software your using ...
even for some money in this case i could be the backup part guru for the rest of the owners loll
Tuesday, April 17, 2007 - 02:52 am, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
There is an online catalog - first entry here:
http://soarercentral.com/sc-forum/messages/281/281.html?1175713462
This may also be handy: http://www.1jzgte.com/tech/JZA70%20Parts%20Reference.html
Or there is a CD here: http://soarercentral.com/sc-forum/messages/1812/107179.html?1161328824
Nicolas Perras
quebec
soarer 2.5tt
Reg: 04-2007
Tuesday, April 17, 2007 - 03:31 am, by:  Nicolas Perras (Nick_insane) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
will a toyota supra 87-92 clutch will fit cause someone want to sell me one cheaper then the retail price at toyota
Scott Ferguson
Alberta
Soarer GTT-L
Reg: 07-2006
Tuesday, April 17, 2007 - 03:39 am, by:  Scott Ferguson (Scott_ferguson) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
EBC PN GDI781/GDI782 for their slotted and D781/D782 for their plain rotor. Then brake pads I believe are the same as the NA MKIV supra.
