  Soarer Central * Test Post and Forum Issues * Manual twin turbo? Previous Previous    Next Next
Andrey Collantes
Reg: 12-2007
Monday, May 05, 2008 - 11:22 pm, by:  Andrey Collantes (Dre86) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hey guys,
I've had a v8 91 for around 6 months and have gotten used to the power it puts out. I've wanted to mod it but have always had the thought of getting a manual twin turbo and then moding that seeing as it has more potential in the long run.
I was wondering if there is anything to look out for if you are looking at manual twin turbos. Also, for around 2 grand what mods would be best to increase performance for the twin turbo..
exhaust?
intercooler?
IFT chip?
Cheers guys
Jeff Smith
GT30/37r Single T
Tuesday, May 06, 2008 - 07:00 am, by:  Jeff Smith (Mozzie) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Well for 2k,Exhaust,intercooler,Fcd and do the Bfi (yourself
http://soarercentral.com/sc-forum/messages/67/81.html?1098303234 ) should see you close to 180rwkw's depending on what boost you run.Raise the boost too 15psi and you will be nocking on 200kw's.
