  Soarer Central * Test Post and Forum Issues * Admin Assistance Previous Previous    Next Next
Grant Weymouth
UZZ31 V8 Ltd
Reg: 12-2005
Tuesday, December 13, 2005 - 08:26 pm, by:  Grant Weymouth (Grant) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Sorry to be a nuisance but could someone please explain why every time I open a forum discussion a pop up appears asking me to select a user to be entered on this forum with a choice of grant or grant. Likewise when I went to start a new thread to type this note I was aked to choose a username which was a list of previous thread headings I have used? These are pissing me off ....
How do I get rid of these pop ups pllleeeeaaaaassssseeee
1991 UZZ30 GT4.0 V8
Tuesday, December 13, 2005 - 08:32 pm, by:  Don Bagnall (Baggs) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
That sounds like a weird one Grant , Peter should be along shortly to get you sorted
Grant Weymouth
UZZ31 V8 Ltd
Reg: 12-2005
Tuesday, December 13, 2005 - 08:39 pm, by:  Grant Weymouth (Grant) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks Don I tried inputing username different with Capital G now it has added this to the list of apparent usernames i can choose from????
Most annoying.... Damn computer more trouble than wife and car put together!
UZZ-32 V8 Soarer #138
Tuesday, December 13, 2005 - 08:41 pm, by:  Dan McColl (Hoon) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
It sounds maybe like windows remembering usernames and passwords.
Tuesday, December 13, 2005 - 08:45 pm, by:  David Vaughan (Davidv) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Grant, you say 'every time you open a forum discussion". Do you mean whenever you start a thread, or when you use Search, or when you click on a topic?
Do you have cookies set to allow your computer to store your identity for the forum? What platform and browser are you using?
Jason Kingsmill
UZZ31 Soarer V8
Tuesday, December 13, 2005 - 08:51 pm, by:  Jason Kingsmill (Jason_k) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I assume you are using Firefox?
I have had it happen before.
In the menubar, go to Tools>>Options>>Privacy>>Saved Passwords>>View Saved Passwords.
Look for soarercentral.com and check that there is only one entry. If there is more, just delete them all and then try logging on again, and it should save the password correctly again.
Chances are, you have entered the username with a space before or after it, or the password differently.
See how you go.
Grant Weymouth
UZZ31 V8 Ltd
Reg: 12-2005
Tuesday, December 13, 2005 - 08:58 pm, by:  Grant Weymouth (Grant) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I'm using Netscape 7.1 on windows XP Prof and the popup appears when I open a discussion thread, for example I have opened the forum for test posts etc.. no popup now I click on this thread to open it and after it opens up comes the box asking for username????? Dan I think that windows does remember my password this could be problem.
Grant Weymouth
UZZ31 V8 Ltd
Reg: 12-2005
Tuesday, December 13, 2005 - 09:05 pm, by:  Grant Weymouth (Grant) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hey guys I think I have solved the prob I looked at your advice Jason and went into preferences in Netscape found stored passwords and deleted all the idiot ones, seems to have worked but I will see how it goes.
Thanks everyone for your input....
1991 UZZ30 GT4.0 V8
Tuesday, December 13, 2005 - 09:07 pm, by:  Don Bagnall (Baggs) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Cool!.......another satisfied customer
Tuesday, December 13, 2005 - 11:25 pm, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Good way to get off newbie status too :-)
