Thursday, January 18, 2007 - 02:05 pm, by: Andrew Ferres(Peewee)
MS65 front hubs. MS123 rear hubs.
All use the same bearings, so its bolty/bolty.
Stock front discs will not bolt to MS65 hubs. MS65 hub centre is 67mm, GZ10 is 60mm. There is plenty of fat in the MS65 hub to machine the centre down to 60mm though (mine has this done) MS65 hubface sits ~2mm further out compared to GZ10 hubface.
Stock rear disc and calipers bolt up after being redrilled to 5 stud, and having the centre machined out to 67mm (from 60mm) OR you could machine the centre down to 60mm. (I have done this too).
Its a perfect time for a Nissan brake upgrade too.
