  Soarer Central * Z10/Z20 Soarer Chat * NEW New Zealand gz10 owner Previous Previous    Next Next
Mike North
Glen Innes
Tuesday, March 13, 2007 - 06:45 pm, by:  Mike North (Slipwayz10) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hey howsit just came accros the site, not alot of info on the z10 i see.
Ive just got a 1uzfe and w57 box and looking to chuck it in to the z10, any one run into any probs doing this?
Andrew Ferres
'86 Cressida V8, '84 Soarer V8, '90 C-F Celsior V8
Wednesday, March 14, 2007 - 09:45 am, by:  Andrew Ferres (Peewee) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Nah mate.
It all bolts in with the right parts.
Fun to drive too.
Mike North
Glen Innes
Wednesday, March 14, 2007 - 05:18 pm, by:  Mike North (Slipwayz10) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
hey are you the guy that made those mounts? anychance you could send me the drawings?
Cheers dude
Justin Camilleri
Had a 85 MZ10, 92 TT, Now 91 TT
Wednesday, March 14, 2007 - 07:25 pm, by:  Justin Camilleri (Just) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Andrew do you have any more videos of your car?
Andrew Ferres
Wednesday, March 14, 2007 - 07:51 pm, by:  Andrew Ferres (Peewee) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yes, I make the mounts, and no, I don't send out the drawings.
A vid from a while back. Nothing new though sorry.
http://www.conceptual.net.au/~peewee/uzzio/uzzio_13.92.avi
Mike North
Glen Innes
Friday, March 16, 2007 - 04:36 pm, by:  Mike North (Slipwayz10) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks for being so helpful, what you guys doing for suspensions for z10? homemade coilovers? i was thinking of going full s13 gear.
Any idea of what sorta power the 1uz can make NA
Andrew Ferres
Friday, March 16, 2007 - 04:49 pm, by:  Andrew Ferres (Peewee) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Suspension is identical to MA61 Supra.
So custom coilovers with the coilover sleeve kit.
As for power NA, depends what you want to spend.
Spend a lot (10k+) and you'll make a lot.
Spend a little (<3k) and you'll make fvck all over stock.
Mike North
Glen Innes
Sunday, March 18, 2007 - 03:57 pm, by:  Mike North (Slipwayz10) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
like what sorta things can be done?
I was thinking nice extractors and a link ecu for now, then a cam grind and ITB
Andrew Ferres
Sunday, March 18, 2007 - 04:15 pm, by:  Andrew Ferres (Peewee) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yeah, extractors are a good first step.
Need to be custom though, as nothing factory and decent fits in the engine bay.
Aftermarket ecu is a must if you are chasing more power than factory.
Kelfords do aftermarket cams for them, and A1Turbos to ITB's.
Expect about 4k NZD just for cams and ITB's though.
Mike North
Glen Innes
Wednesday, March 21, 2007 - 04:25 pm, by:  Mike North (Slipwayz10) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
yea thats alot of coin , might just stick with semi stock. should be plenty for drift
Andrew Ferres
Friday, March 23, 2007 - 07:23 pm, by:  Andrew Ferres (Peewee) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Tight LSD, stiff suspension and manual gbox and she'll have more than enough for drift.
