  Soarer Central * Z10/Z20 Soarer Chat * 1g-ge turbo Previous Previous    Next Next
Oscar Davies
s.a.
1g-gte
Reg: 07-2009
Wednesday, July 22, 2009 - 12:59 pm, by:  Oscar Davies (Yinyang) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I need to replace my engine and trying to cut costs tried to put a 1g-ge engine in my gz-20 and bolt the turbos from my old engine on.
Do not try and do this anyone as the injectors for the turbo engines do not bolt in and the 1g-ge also has no oil line connections for the high pressure turbo oil feed.as well as other small nusances.
Christopher Stevens
JZZ20 Soarer / JZX90 Mark II / GDB Impreza WRX
Reg: 04-2007
Friday, April 09, 2010 - 12:50 am, by:  Christopher Stevens (Hamgatan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
...not to mention the compression ratio. even if you did get it started you'd be playing piston shotput the second you came on boost..
Boris Siljanoski
Soarer GZ20 TT
Reg: 11-2007
Friday, April 09, 2010 - 12:17 pm, by:  Boris Siljanoski (Z2tt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Maybe, Maybe not. Unless you turned the boost way up beyond stock. NA-T Conversions always are complicated as you need to modify certain things it's always better to buy a turbo engine and drop it in.
Jerzy Stopczynski
Westarn Australia
jzz20
Reg: 12-2006
Friday, April 09, 2010 - 01:43 pm, by:  Jerzy Stopczynski (Stomps) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
firstly NO SHI.... KIDDING
not to mention for the price of a 2nd hand 1ggte.. why bother with farking around with getting a ge..
i bought my last 1ggte for $400 with gearbox, loom, ecu, turbos etc... etc...
my bro just bought one for $450 including gearbox, tailshaft, mounts, turbos, loom, ecu, dump pipe etc... etc...
Stomps
