  Soarer Central * Aristo Chat * Yet another Problem... The list doesnt stop growing... Previous Previous    Next Next
Open in new windowArchive through March 30, 2007Brad Newman34
Lindsey Swan
GTT-L
Friday, March 30, 2007 - 07:23 am, by:  Lindsey Swan (Banzaibattlecrazzzy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yeh exactly they all do.. except for bens...
Yeh but would they be the same number? over there they are lexus gs300.. maybe different numbering system..
http://foreigncarpartsonline.com/
What about on here?
Ben Evans
ARISTO YO!
Friday, March 30, 2007 - 09:33 pm, by:  Ben Evans (Sbyder) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks to all for your replys.
I contacted a few shops that do the injection moulding, but they said its not a fix for stuffed ball joints, just ones with a little play. I stopped into STZ on the way home from work (night shift - yuck!) and they had some celsior arms in perfect nick (just minus the boots) just sitting there. Grabbed them ($80 each) nicked over to repco and bought some boots and high temp grease and threw them on this morning!
You have got no idea how rooted the old ones were. I can move the ball at least 5-10mm in each direction, theres no grease left and the balls are rusted out. And to think, the boots looked in good nick as well!
Anyway, i'll see if i can track down a rebuilder for the old ones, as eventually these celsior ones will fail, so i'll have a backup pair.
I'll also be chasing the bottom ball joints in the near future. As they are readily available from the UK for about £80 each.
Ben
Steve England
Reg: 01-2007
Wednesday, April 04, 2007 - 11:14 am, by:  Steve England (Stevee) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi all,
Replaced both front lower ball joints in January. Part numbers as per Brad's post above - $123 ex from Castle Hill Toyota (had to come from Japan). Replaced upper right arm with a very good unit from a front cut (Hondwreck - Clayton 3169).
Steering and noise now as new, and I thought it was all fair value.
Steve
Ben Evans
ARISTO YO!
Wednesday, April 04, 2007 - 07:05 pm, by:  Ben Evans (Sbyder) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
$123!!! OMG!
https://www.autopartswarehouse.com/ has them for around $200 delivered ($69US each + postage, but if i can get them for almost the same amount through toyota i'll try them!
Thanks heaps
Ben
Ben Evans
ARISTO YO!
Thursday, April 05, 2007 - 09:49 am, by:  Ben Evans (Sbyder) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Called Castle hill today. The cheapest they can do is $140 each plus GST and postage. Price must have gone up since January :-(
Bruce at Raws has got some, but Ive gotta wait on a call back to see if they've lost them in the move they did yesterday. Should be interesting, lol.
Ben
Michael Sukahar
Brisbane
Monday, April 09, 2007 - 09:52 am, by:  Michael Sukahar (Rx3_ip) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I just bought an Aristo TT ( grade 4 ? ) today looks very nice and with 6 months rego , be the 1st owner in Aust , hope that I don't get too much problem with it .
Wayne Koh
Aristo 3.0V
Wednesday, April 18, 2007 - 09:06 pm, by:  Wayne Koh (Teknoboi) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I'm getting this vibration as well, especially over 90km/hr.... got wheel alignment and balanced multiple times.... put a new set of rims on with ball locators so they fit tight, also got them aligned and balanced multiple times but still vibrating at speeds over 90km/h.
Also noticed the car tends to steer left too..
any ideas guys?girls?
Michael Sukahar
Aristo TT Soarer TT
Thursday, April 19, 2007 - 05:50 pm, by:  Michael Sukahar (Rx3_ip) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
check the drive shaft for alignment & balance , it may be slightly damage/bent
Ben Evans
ARISTO YO!
Friday, April 20, 2007 - 07:31 am, by:  Ben Evans (Sbyder) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
check your ball joints! and make sure you brake discs arent warped.
