  Soarer Central * Mechanical - V8 - Supercharged * Unchip Previous Previous    Next Next
Joshua White
SC400 GT V8 Supercharged
Reg: 11-2006
Thursday, February 15, 2007 - 09:16 pm, by:  Joshua White (Joshua_88) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
hey guys, wanting to know if a unichip will make a noticeable difference and if so where to buy and look for
Rob Andreacchio
Supercharged VT Calais & 1991 JZZ30
Reg: 01-2005
Thursday, February 15, 2007 - 09:25 pm, by:  Rob Andreacchio (Reepa) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Use the search function.
Monday, February 19, 2007 - 03:11 pm, by:  Maurice Diggler (Mau_rice) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
http://www.airpowersystems.com.au/companyprofile.html
Air Power Systems in Croydon, Melbourne can supply / fit a Unichip for you mate.
About $1600 fitted and tuned. Give them a call. Cheers.
Monday, February 19, 2007 - 03:32 pm, by:  Daniel Clarke (Dieseltrain) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
ONe guy up here in Sydney has had nothing but problems wth his Unichip on his Blown V8 soarer. He is gonna remove it very shortly for a full aftermarket ecu:-)
Gianni Matrogiannis
SC400 V8
Wednesday, February 21, 2007 - 07:07 pm, by:  Gianni Matrogiannis (Gianni) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
go for a microtech thats what i am running and it works fine. if you need someone to install and tune it let me know
