Kim Hunt
Tinkerer nsw SC400 GT-L UZZ31
Posts: 58 Reg: 08-2007
| hi guys i'm really keen on getting the GReddy e manage ultimate. i know 2 soarers that have e manage's fitted (Peter Chriss's Emanage Blue Powered Twin Turbo UZZ31 ) and with the ultimate (Peter Taplin's Emanage Ultimate Powered Supercharged UZZ32 ) i would like to know if these people or anyone else can answer me a few questions. 1. Are you happy with the setup? 2. how much did it end up costing for item and installation? 3. who installed and tuned the computer?and what state?(i'm in NSW) 4. any things that you were/are disappointed about the e manage? thanks peoples |
Craig Allan
Tinkerer Lincolnshire Soarer TT
Posts: 61 Reg: 02-2008
| Ive just fitted an Ultimate to mine, with Rivals STOC backboxes, decat, 3" system from manifold back, ARC airbox, standard manifold and turbos. Previous power was 222 hp at the wheels, new power is 322 hp at the wheels running 1.1bar boost. Its got a few glitches that need ironing out but on the whole its good, even better on fuel on long runs lol. Car is auto btw. Cost me 350 gbp for the used set up including 3 bar MAP sensor and 425gbp to fit and map. Im only 1 of a few that has the ultimate on their Soarers in the UK (that I know of) |
Kim Hunt
Posts: 59 Reg: 08-2007
| Jeese 100hp is pretty impressive! Oh and i should tell every1. My soarer is a supercharged 1uz early gen. The eaton m90 is running 10psi with w2a intercooler with 315cc injectors and a catback exhaust. Thought it might help |
Craig Allan
Posts: 62 Reg: 02-2008
| You should see some healthy gains from that setup Kim, best to speak to Peter Id say |
Moderator www.etuner.com.au JZZ30
Posts: 2445 Reg: 07-2005
| Kim i've replied to your email mate. Looking forward to another ultimate + S/C 1UZFE install, these engines respond so well! |
Kim Hunt
Posts: 60 Reg: 08-2007
| Ok thanks. When i get home ill check my email. Really looking forward to the install. Thanks |
Melnikov Yaroslav
Newbie Samarskaya UZZ30
Posts: 3 Reg: 02-2008
| Cihan Aday who installed e-manage ultimate 1UZ-FE |
Kim Hunt
Posts: 64 Reg: 08-2007
| was that a question or a statement? |
Melnikov Yaroslav
Posts: 4 Reg: 02-2008
| Sorry. Question |
Steven Anderson
TryHard NSW UZZ31 Manual
Posts: 237 Reg: 05-2006
| Kim, dont be disappointed if you dont get massive numbers out of your setup. It will put down some good figures, but dont expect it to be up there with the vortech kinda range. However! Make sure you take a good look at the dyno sheet, it will be an absolute stomper down low and up the mid range, it will just run out of puff a but in the top end and not produce huge peak hp number. You will find this out when you drive it through some twisty roads anyway |
Kim Hunt
Tinkerer nsw Supercharged SC400 GT-L UZZ31
Posts: 69 Reg: 08-2007
| thanks steve i have notice the torque in low and mid rang already. i just want to get a decent figure. soarers seem to put out a lower power figure than other v8's but i think its due to the cubes |
Steven Anderson
Posts: 239 Reg: 05-2006
| you probably wont get a decent figure, low 2xxrwkw is a guess. But the car will be about as fast as a 250rwkw vortech blown car. Peak figures mean squat. |
Posts: 3288 Reg: 03-2006
| You have to remember though, during most acceleration its mostly from about 4000+ rpm, except for the launch. |
Kim Hunt
Posts: 71 Reg: 08-2007
| car pulls pretty hard up high aswell but i know with the blower i have it runs out of puff up high but can't really feel it.the gear change into 2nd and 3rd make you pull so much harder so it shows that the blower is giving good low and mid but less high. all very fun and the torque is monster. i pulls you back in your seat like its no body's business
Gianni Matrogiannis
TryHard nsw SC400 V8
Posts: 176 Reg: 08-2005
| hmm i somehow doubt that a low 200rwkw eaton would be anywhere near as fast as a 250rwkw vortech setup. Although a lot of people here have their theories on why this would be so, the drag strip says different. My car with just over 250rwkws can run a high 11 sec pass,I somehow dont see any eaton setup doing this. Now to really put a spanner in the works, on 5 psi my car made 205rwkws and it ran a 13.1 sec pass at 110mph. Now again i havent seen an eaton setup with 200rwkws run faster that a 13.1. Now to settle this i know i have to find my dyno sheet and post it, but keep this in mind. My air temp never goes above 32 degrees, the cooler air from the vortech means that it will make more power with less boost. |
Steven Anderson
Posts: 241 Reg: 05-2006
| At 4000rpm a vortech is only making 1/2 max boost. Reference our old mate neil. "I pulled a 13.5 in my V8 with 176Kw / open diff / street tyres / auto with shift kit and stally." The main point I was trying to make is that with the eaton, it will not sound as impressive if he just looks at his peak numbers but I can guarantee that what it does outside of the last 1000rpm will be a lot more impressive. Anywhere outside the drag strip, this will be a great setup and will punch above its 'peak hp'. Gianni, I would love to see the dyno sheet. |
Paul Drane
DieHard QLD V8 Limited
Posts: 577 Reg: 07-2005
| Steven, can you can you give me your thoughts on my dyno results. Blown V8 with a shift kit, stock ecu, Walbro F/pump and a rising rate fuel reg. Exhaust has been done too.
rev limit cuts in at 5900 revs for some reason. |
Goo Roo NSW I have a Cadillac and a Supercharged Manual V8
Posts: 4531 Reg: 07-2005
| I pulled 11.77 with an Eaton on 10psi ! In the SilV8 of course 220RwKw. Will soon see what an Eaton M112 can pull |
Steven Anderson
Posts: 245 Reg: 05-2006
| Paul, it will come alive with a new ecu. The whipple has the nice benefit of keeping efficient all the way to redline so you wont see a power drop off like an eaton (thats why you pay 5x the price for a whipple ). You will be able to bring the a/f ratio up to 12:1 throughout most of the rev range giving it a bit more mid range kick and also raise the rev limit to about 7000rpm and it will still make power all the way up. You can see from the dyno its still going up when the cut is hit. The slope of the graph (or more the lack of change in the angle of the slope) says that you have a _very_ flat torque curve, this will probably translate into the car not feeling as fast as it actually is, just a constant shove in the back. Get an adaptronic on that mo-fo. |
Posts: 3294 Reg: 03-2006
Steven Anderson wrote on Friday, April 11, 2008 - 01:35 pm:"I pulled a 13.5 in my V8 with 176Kw / open diff / street tyres / auto with shift kit and stally."
I think you will find that Neils car was Dynoed in 2nd gear, which actually would make it equate to the 195-200rwkw mark when dynoed properly in 3rd gear using the 1:1 ratio Have seen it done.. Same car ,2nd gear made 187rwkw, Then in 3rd 206rwkw Also, neils Stally would have been worth a couple of tenths getting out of the hole. |
Paul Drane
Posts: 578 Reg: 07-2005
| Ecu is a toss up between Adaptronic and Haltech, either way I am looking for some good improvements. A few more lbs of boost and I will be satisfied. |
Posts: 4539 Reg: 07-2005
Daniel Clarke wrote on Saturday, April 12, 2008 - 05:35 pm:Neils car was Dynoed in 2nd gear
3rd gear Dano ... Was just to check the AFR back then.
Paul Drane wrote on Saturday, April 12, 2008 - 10:33 pm:Ecu is a toss up between Adaptronic and Haltech
I pick the Capitol A |
Posts: 3296 Reg: 03-2006
| All good Neil , My bad |
